Old Jul 17, 2012, 09:33 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Got a couple of 306b's
Any advantage of moving from 24 to 32 volts? The input voltage lists it up to 38 volts but the specs say 1000watts at 24volts.
stgdz is offline Find More Posts by stgdz
Old Jul 17, 2012, 10:06 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
None at all.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jul 17, 2012, 10:45 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
TheWoodCrafter, are you sure?
I would have thought lower current on the input (one advantage), and less likely to run into problems at 30 amps on 6S as Vout nears Vin, something I've noted on my 3010b with a power supply charger. If the same issues for the 206b, it would be a second advantage.
I haven't tried it, but I was thinking the same thing.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jul 17, 2012, 11:16 PM
RC Helicopter Pilot
Joined Mar 2010
The 306B and the 3010B both give their maximum output at 24V input.
You will never get any more output no matter what.
Raising the input above 24V will not do anything.
I am positive.
Old Jul 17, 2012, 11:28 PM
stgdz is offline
stgdz's Avatar
Joined Jul 2011
I am positive.
yeah thats what I figured, the 1000watts at 24v told me there would be no advantage but I figured I would ask anyways.
so when are going to see the 36 and 48v chargers?
Old Jul 17, 2012, 11:49 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Raising the input voltage at the charger terminals above 24V will not increase the available output power but it will reduce the input current for any given output power. This will reduce voltage drop across the leads from the PS to the charger and increase efficiency in the input stage.
Pragmatically, it has no significant in terms of charging our packs.
kgfly is offline Find More Posts by kgfly
Old Jul 18, 2012, 12:35 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Sorry guys, I'm not convinced. Charging at 6S at 30 amps, and as your lipos get near 25.2 volts, the server power supply I have is drooping down to 25.1 volts. So the charger is either going from buck to boost mode around 25.1 volts, or the charger can't produce an output voltage higher than the input voltage. (I am not sure about the 6, but I think the 10 can operate in boost mode). Either way, I get a charger error around here.
I haven't tested this out, but I suspect that this problem will disappear if I float two supplies, run three in series, and use ~36.4 volts on the input to the charger. Somebody else earlier in this thread had a similar problem, and Junsi recommended that he try using Pb battery on the input, and that solved it for him, too. If I charge 6S at 24 amps, I don't have this charger error problem, and so I've been charging at 24 amps max when I need to parallel charge my 4000 mah 6s packs.
I'm not trying to maximize output power, though I think charger efficiency may improve with a higher input voltage.
I am trying to reduce input current and eliminate an error I have with my power supplies by keeping the charger running in buck mode only.
If you don't have this problem charging 6S, it's probably not worth the trouble.
So, charger efficiency may go up, and I am pretty sure my 6S at 30 amp on server supply error will also disappear by going to nominal 36 volts.
Old Jul 18, 2012, 01:34 AM View Post
icando
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Jul 18, 2012, 02:55 AM
kgfly is offline
Joined May 2006
The iChargers can indeed charge packs to higher voltages than the input voltage,. after all you can charges a 10S (42V) pack from a 12V supply, just not at full power.
Charging 6S @ 30A means pulling around 33A (avg) from a 24V supply. Peak current draw could be somewhat higher, If your PS is struggling under the load then sure, going to 36V and about 22A may well help.
Old Jul 18, 2012, 04:16 AM
LeszekJ is offline
Find More Posts by LeszekJ
LeszekJ's Avatar
Poland
Joined Nov 2010
What error specifically?
Every iCharger is supposed to be buck-boost converter.
BTW I use iCharger 3010@36V just to limit input current.
LeszekJ is offline Find More Posts by LeszekJ
Old Jul 18, 2012, 08:52 AM
Gtaris is offline
Find More Posts by Gtaris
Joined Jul 2012
iCharger 208B Err: FLASH Memory
Hi,
I wanted to use my new charger today but got a nasty surprise as it’s not working.
It reboots every 2-3 seconds and shows a message : “ERR: FLASH Memory”.
I flashed the firmware and tried the following ones : 3.12, 3.13, 3.14
3.14 : charger simply reboots with the error message and hangs (push buttons don’t work)
3.12,3.13: charger doesn’t reboot, the buttons and menu work, but when trying to start charging, after “Battery Check, Wait Please”, I get “ERR: FLASH Memory” again.
Diagnostic => DOA (Dead On Arrival) ???
As I bought it from HobbyKing, and already had top pay over 40euro's to customs for it + shipping costs. I would like to know if there's any other way to fix it ?
As an electronic engineer student, I think it's probably briked but still. I know the memory used for the firmware and memory settings work fine. So it's probably the 16Mbit logfile memory with is causing error but the problem could be elsewhere.
(I did only find one single post reporting this error)
Does anyone have any ideas or suggestions for me ?
Gtaris is offline Find More Posts by Gtaris
Old Jul 18, 2012, 11:27 AM
Bigster is online now
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Originally Posted by AndWho View Post
Hi All, A small warning.
Do NOT connect your 106B+ to a 12v output of a gas generator.
I did and got an "Input Overvoltage" warning. Checked the generator output with my DVM and it read about 16V. Strange I thought... and connected via an known good 12V ACDC adapter instead. Then I got the dreaded "Connection breakdown" msg when trying to start a Lipo charge. The 16v DC output of the generator must have been really dirty with a lot of high voltage peaks, destroying one of my two 106B+.
Thanks to Google and RCG I quickly found the cure, replaced D16 (20V zener BZV55-B20) and Q26 (BC807-40 ) and all is well again.
Beware. the 106b+ seems to be sensitive to input over voltage.
/A
My 106B+ fell victim to either a bad power supply, or someone accidentally plugging it into a 24v source. I now have a 206 on the way, so I figured I could attempt a repair.
I found Q26, but I can't seem to find D16. It isn't under the LCD is it? Edit: Found it
Edit: Is this the one people are using?
http://www.mouser.com/ProductDetail/...9mb0NhwAMH4%3d
And is this Q26? Is the package SOT-323? Or SOT-23?
http://www.mouser.com/ProductDetail/...AcSI9QFAnks%3d
Edit: Got the back off and it looks like U8 is a goner. Is it worth pursuing a repair, Junsi?
Bigster is online now Find More Posts by Bigster
Old Jul 18, 2012, 12:26 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I would guess that the charger does not switch between buck and boost during the charge cycle. I would go ahead and add an extra power supply if your input voltage is hovering too close around the output voltage. It can't hurt anything right?
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 18, 2012, 12:31 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Of course it will toggle from buck to boost as it transitions through Vin = Vout. It should ride right through this with little fanfare though and the user should not be aware of it in any way.
Really curious to know the error that N6145k is experiencing. I'm sure Junsi is curious as well.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jul 18, 2012, 02:05 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Mark
Others have seen it too. control error.
For me it only shows up when I am charging 6S at 30 amps as the battery voltage gets near the power supply voltage.
I suspect it is a problem with charger not liking the voltage regulation on the power supply as it goes from buck to boost. I believe it is at least possible that this is simply a firmware threshold issue in the 3010b. I.e., the firmware is declaring a control error because the voltage fluctuation exceeds some pre-programmed threshold, which may or may not be too conservative.
The problem doesn't happen when I charge 6s at 24 Amps.
Have you charged 6s at 30 amps on a 3010b, and if so, what power supply are you using?
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
