Old Jul 09, 2012, 03:57 PM
Raehm is offline
Find More Posts by Raehm
Raehm's Avatar
Charleston, SC
Joined Jul 2006
first time charge 2200 30c 4s
Question...
My first charge on a new lipo using my iCharger 106b resulted in a total charge of 16.85 volts, which my meter read as "overcharged".
I was charging three 2200 30c 4s lipos at 6.6volts.
What is the max volts for this Lipo.
I used auto settings, which correctly detected the cell count and 14.8v
Any thoughts would be appreciated.
Raehm is offline Find More Posts by Raehm
Old Jul 09, 2012, 04:06 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
What meter are you using and have you established that it is more accurate than your charger? e.g. - Has the meter been calibrated against a known voltage reference?
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jul 09, 2012, 04:39 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Originally Posted by Raehm View Post
Question...
A full charge for any lipo is 4.2V x cell count. So for a 4S it's 16.8V which isn't too far off from the 16.85V you said your meter reads. Chances are pretty good your meter is not reading correct. Depending how your meter reads and rounds numbers if it's not calibrated right a little bit off on each cell value could add up fast.
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 09, 2012, 04:47 PM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
I don't see the problem.
I assume you mean 6.6A ( not 6.6V) as you are charging 3 x 2200 packs, presumably in parallel.
For 4S pack the finishing voltage should be 16.80 so 16.85 is OK. The meter can easily be that far out as it is only 0.05% error on a full scale basis and the charger readout would probably not be that accurate
Mark - did you read it as a 3S pack?
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Jul 09, 2012, 04:53 PM
So. Cal.
No, I read it as a 4S pack and the user was concerned about the minuscule .05V 'overcharge'. Where I was heading is that it is simple measurement error.
Mark
Old Jul 10, 2012, 08:42 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
i had started a new post so now this is my findings
http://www.rcgroups.com/forums/showthread.php?t=1686670
FASTBEN is offline Find More Posts by FASTBEN
Old Jul 10, 2012, 10:49 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
I asked this once before and I can't find it again. For lead batteries what is a safe charge rate? Is it amp hours/4. Grandpa got the kids a power wheels and the wall wart charger take 13 hours to charge it. Figured the I charger could do it in less.
The wall wart is rated at 13 watts for 12 volts.
stgdz is offline Find More Posts by stgdz
Old Jul 10, 2012, 02:59 PM
United States, MN
Joined Feb 2011
Based on this article sounds like C/3 is doable as long as you are sure it won't over charge:
http://www.powerstream.com/SLA-fast-charge.htm
The iCharger manual though says no more then 0.4C.
Old Jul 10, 2012, 03:19 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Got it. Thanks!
Old Jul 11, 2012, 07:29 AM
dea90 is offline
Find More Posts by dea90
dea90's Avatar
Italy, Piemonte, Casale Monferrato
Joined Jun 2010
Hello, I have an iCharger 3010b and I accidentally plugged the lipo reversed and I started charging. The cb has smoked even though in theory there is protection against polarity reversal, the component went up in smoke you can see it here
is a mosfet of the international rectifier, this https://ec.irf.com/v6/en/US/adirect/...D=IRFB3306GPBF.
question for Junsi: why the polarity protection did not work?
Thanks to all for your responses
Matteo
ps. i bought it from hobbyking
dea90 is offline Find More Posts by dea90
Old Jul 11, 2012, 03:45 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
The reverse polarity check alarm didn't go off?
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jul 11, 2012, 04:00 PM
Woody_99 is offline
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
Looks like it was a visual indicator in this case. (smoke signal)
Sorry, couldn't help myself.
Woody_99 is offline Find More Posts by Woody_99
Old Jul 11, 2012, 06:43 PM
dea90 is offline
dea90's Avatar
Joined Jun 2010
the charge started like always without any alarm, a lot of smoke and smell came out from cb, i turned off the cb immediatly and i seen the reversed polarity
Old Jul 11, 2012, 08:49 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Matteo
Hello Matteo,
We are really sorry to cause you this trouble, our engineers have figured out that the problem was caused by our faulty design, and we had revised this problem already in the new batches.
As for 306B and 3010B in the previous batches, we need remind All Junsi Valued Customers to pay attention that: the polarity reversal protection function will fail to work if you first plug the reversed batteries then power on the charger, but the protection still works if you had powered on the charger then plug the batteries with reversed polarity.
Sorry again for this trouble made, we have sent you a PM about sending the charger back to us for repairing, thanks for your understanding and cooperation.
BR
Junsi
junsi is offline Find More Posts by junsi
Old Jul 11, 2012, 10:38 PM
Great_Goose is offline
Find More Posts by Great_Goose
Flying from Vic Park
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
I have beening thinking about getting the 206B and P350 for a while. Junsi's handling of the situation above gives me confidence in their customer support if I need it. I will order them tomorrow, I was going to buy them from Progressive RC are any other supplers I should look at before buying?
Great_Goose is offline Find More Posts by Great_Goose
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
