Old Jun 13, 2012, 03:36 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I'm wondering if he is stuck on the cell voltage screen.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jun 13, 2012, 05:41 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Mine goes back to the main screen automatically in less than a minute.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jun 13, 2012, 06:33 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
I have the 206b and it is great, I was reading in the instruction that I can check a batteries ir but I can't work it out how to do it, can some please give me the dummies guide to checking ir.
Thanks gary
aeromaniac is offline Find More Posts by aeromaniac
Old Jun 13, 2012, 06:41 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Thanks gary
Hi Gary
Be very careful what questions you ask..... This type of question would lead to some saying read the manual in a very condescending way
Its is very easy to check IR. plug in your balance plug into the charger, then your main power lead from the battery. While the charger is on press and hold for 3sec the stop button. the screen will change, now press the DEC button and you will get the IR for each cell. Press the DEC again and you will get the Pack total IR.
Good Luck
evltoy is offline Find More Posts by evltoy
Old Jun 13, 2012, 06:57 PM
Glow 😡 no no no
Joined Mar 2010
Originally Posted by evltoy View Post
Hi Gary
Good Luck
Thanks for your reply, here in australia there are a range of books, "the dummies guide to windows" etc so my comments were reffering to myself and no one else.
http://www.borders.com.au/search/for...FUNMpgodWDteXA
Old Jun 13, 2012, 08:46 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Originally Posted by TheWoodCrafter View Post
It is pretty simple.
You read it off your charger.
I always thought that value was a log file of some sort for storage.
Well at least I learn something new every day.
stgdz is offline Find More Posts by stgdz
Old Jun 13, 2012, 08:51 PM
RC Helicopter Pilot
Joined Mar 2010
Watch it the next time you charge.
It starts at zero and will climb.
That is what you are putting back into your pack.
This is the number you should watch to never have to put in more than 80% of the packs advertised size (mAh).
It you do, you discharged it too far.
Old Jun 14, 2012, 10:10 AM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Is there a simple option to get into the amount of mah put back into a battery at the end of the charge? I have seen people list it before but I can't find the option without digging into the setup.
Or do they just use math based on the volt/cell before and after they charge?
The charger tells you what it put into the battery on the display. Of course, if you are parallel charging, this is not so straightforward.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jun 14, 2012, 10:32 AM
helinutz is offline
Find More Posts by helinutz
United Kingdom, Bournemouth
Joined May 2006
3010B Display Problem
My icharger 3010B has stopped outputting to the display.
The backlight is on with row of blocks in the first row of the display.
Buttons sound like they work, but I cannot get the display to change.
I have tried an update, but that doesnt make any difference (update shows as succesful)
Could any of you advise on what to try next.
helinutz is offline Find More Posts by helinutz
Old Jun 15, 2012, 09:18 AM
Randal McSandal is offline
Find More Posts by Randal McSandal
Randal McSandal's Avatar
Joined Dec 2011
I'm thinking of buying a 306B and using this: https://sites.google.com/site/tjingu...projects/HP47A as a power supply. Right now for little 2s but soon for 2s 4000. Will this work well?
Randal McSandal is offline Find More Posts by Randal McSandal
Old Jun 15, 2012, 04:38 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
The 600 watt ps? It will be plenty for any 2s jobs you do. Probably anything over 300-400 watts will be enough for 8.5 volts output.
gulio is offline Find More Posts by gulio
Old Jun 15, 2012, 05:06 PM
j.m.costa is offline
Find More Posts by j.m.costa
Joined Jan 2005
I wonder to know if Icharger 206B gives, the internal resistance of each cell, or just all pack?
j.m.costa is offline Find More Posts by j.m.costa
Old Jun 15, 2012, 05:10 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
It'll do both.
To check internal resistance of each cell, simply connect both the main leads and the balance lead and perform measurement. To check the pack internal resistance including lead, connector, and charge lead, do the same with the balance lead disconnected.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jun 17, 2012, 10:54 PM
Jeckler is offline
Find More Posts by Jeckler
Joined Jun 2012
Re: Regenerative discharge. Does this effectively charge the Pb source? What if it's already fully charged? What's the smallest source I can use and dump say 4ah into it?
I just bought 2 206b's, for my 2S packs and will be using a 12v-575w supply to power them. But I'd be interested in the higher discharge rate that regenerative offers.
I did search, but after the first 10 results, it doesn't seem to be a question that's been asked very often.
edit: Apparently I just need to read more. Found another high-discharge solution too, using a Celllog monitor and a relay. I remember building something similar about 10 years ago for my NiCd packs.
Jeckler is offline Find More Posts by Jeckler
Old Jun 17, 2012, 11:01 PM
RC Helicopter Pilot
Joined Mar 2010
From what I read about regenerative discharge your Pb source has to be low on charge or things don't work.
If what you are looking for is to discharge at a faster rate you will have to build a discharger.
Several types are in thread, here on RC Groups.
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
