Joined May 2012
Are you implying that the 106 terminated early because of 'not-so-positive' connections? The discharge rate I used was 500mA (.25c of 2000mAh cell) |
I have observed some trying to charge and or discharge Transmitter and receiver Ni batteries thru a 36" long 28 gage leads with not so great connectors and then they complanded abput early charge and or discharge termination. Charles |
United States, OK, Edmond
Joined Jun 2004
USB issues with 208B
Thanks, Dave. |
That should not be necessary I do not believe. I would just use a battery to power the charger during updating and not worry about it. Surely you have some Ni,LiPolys,LiFePO4, Pb around that are small / portable anda voltage range capable of powering the charger. The computer I use for updating most of my chargers has a sticker on its' front which says Caution ! Use Battery For Charger Updates. This is not necessary for all chargers but is simple insurance. Even if a ground loop is not an issue having the charger or computer lose power during an update can brick (kill) some chargers. My desktop computers are on UPS units so no issue with poer for them however the power supplies I use for the chargers are not on UPS unit and only sometimes on a deep cycle Pb source. Sorry sometimes I miss the real issue. Quote:
Some users of other chargers with ground loop issues went to using a USB Hub which is optically isolated. Charles |
Joined Jun 2004
Charles - yep, you nailed it at the end. One of the joys of electronic communications is that I though I was being clear, then re-reading my own posts I see that I could and should have been more specific about what exactly it was that I was trying to do.
So, yes, I want to be able to l use logview for potentially longer that I would be able to using a battery to either power the charger or to power the laptop. Recommendations for either an inexpensive isolated USB cable or hub? Everything I'm seeing is running about $100.00. |
This one works well. Been using it on my Hyperion Super Duo for about a year without a glitch.
Less than 40 bucks. Doesn't need an external supply with my PC and the Super Duo. http://microcontrollershop.com/produ...oducts_id=3769 John Quote:
Joined Jun 2004
Charles and John, thanks for the help. I'll be getting the isolator some time this week.
I promise to try and be more clear next time. Yep, with my extremely limited knowledge there will be a next time... Fwiw, this is my first "real" charger, that is one that isn't a wall-wart or automotive battery charger type. I'm just now getting back into RC following a break since 1994 due to kids and the military. I figured I better get a charger first and figure out how to use it. When I started looking for a charger I went looking for one that be able to handle Nimh/Nicd for my son's RC cars and Airsoft gear, but would also be able to do any of the lithium chemistry types currently out there with the intent being to buy more charger than I could imagine needing any time soon, so that's how I got to the 208B. After all this I think it would have been nice if Progressive and EP Buddy would possibly carry an isolator and a note summarizing what I've learned, namely that 1.) You can operate the charger in standalone mode using whatever power source you want and it will work great. Depending on what you have powering your computer and the charger you may not be able to update firmware or run logview due to ground loop. 2.) In order to update the charger firmware or use logview you must either power the charger or the computer with a battery or have the USB connection isolated. If you chose to operate both with power originating from 120 VAC, you must use an isolator of some sort for the USB connection - either an isolated USB cord or USB hub. Otherwise your computer will not recognize that the charger is connected. |
I've used a few different power supplies for the iChargers, and currently have two separate iChargers and power supplies both connected to one PC and the USB port works fine, even for both at the same time using only the original iCharger USB cables without any isolator to the USB connection. Just saying, it will work as advertised and probably does for most. The experts on here will help to get yours working too. |
And just one more piece of info.
I added the Opto isolator not to get the charger to work but to avoid frying it or the PC. There have been a few experiences where the ground loop through the PC USB cord has allowed large currents to flow in either the charger or the USB port in the PC. Smoke ensues. There is a description in the Hyperion Software Suite help file that explains what can happen. I suspect the iCharger may be susceptible as well but I have never investigated it. http://media.hyperion.hk/dn/pc/ecds-...reyoustart.htm Bottom of the page. This is quite apart from any noise issues that the ground circuit may introduce and upset the serial comms. John Quote:
What ones needs to understand is that with charger spec. they really mean up to 10A max, and up to 10S max. or 200 watts max not all.
A 10S equals 42 volts . 200 watts / 42 = 4.76 amps. A 3S is 12.6V thus 200 / 12.6 = 15.87A however the max. in amps is 10 so in fact a 3S at 12.6 X 10a(charger's max.) = 126 watts. These rules apply to all chargers. I have often posted that one needs to understand the specs. and pay more attation to the max. watts. MAny purchase a $30 5A charger expecting to charge a 3 or 4 cell Lipoly at 5A only later to find out that 50 watts will only charge a 3S at 3.9A and a 4S at 2.97A. Even worse is the discharge abilitie of many such 50 watt chargers as many are limites to 25 watts or less discharge rates which means discharging a 4S 3300 or larger to Storage is going to take awhile. Charles Charles |
My Plan with Pb Batteries
Hi Guys
I’m hoping someone can pin point any problems or advise me a better solution to a plan I have in mind. Your help & knowledge to answer any of my questions will be much appreciated. I have been lucky enough to acquirer some Pb Batteries. I have in hand the following: 2x CSB GP12170 (12V 18000mAh) – currently in serial setup http://www.csb-battery.com/english/0...p?fid=5&pid=13 Here is my cunning plan I plan to test the 2 GP12170 Batteries to make sure they are ok and rewire them into parallel. While at the field I was thinking to use my icharger 106B+ and the GP12170 to charge my 6S 2650mAh lipos. My question are: - Is my max charge rate limited to only 6A as the max DC input current for the 106 is 6A? - How many Lipos (80% discharge) do you think I will be able to charge from the fully charged Pb? Would it be 36000/2100 = 17 Lipos - What setting should I set in my charger to make sure I don’t stress or over discharge my Pb? Safety Timer:40mins, Capacity cut off:2200, Input Limit:5.0-6.0A & 10.00v. After a days flying and my flight packs are discharge, I would charge all my packs to full peak via AC power. After this I plan to discharge all my packs through the Regenerative Option to the Pb I had used at the field. Other then setting regen to; On, current limit to; 4or5A and Limit to; 14v.. is there anything else I’m missing or doing wrong? Thanks for taking the time to read my post Cheers evltoy |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
