Old Apr 23, 2012, 02:57 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by Marwell View Post
Thanks fred, i'll check the balance ports, but the probles still exists on 4s packs, so maby it wount be the balance port, two pins disconnect? Any other opinion? Also what about guarranty servcie? Where to conntact?
If there is a burnt track between 2S and 3S that could influence all except 2S.
For warranty the easiest option is to PM or email Junsi. He seems to be quite helpful in these cases. If bought "locally", you should perhaps contact seller.
Fred
flarssen is offline Find More Posts by flarssen
Old Apr 23, 2012, 06:47 AM
Marwell is offline
Find More Posts by Marwell
Joined Apr 2012
i bought on ebay, used item, do they take warranty rof used items? No matter how mutch? Can you give me some e-mails?
Marwell is offline Find More Posts by Marwell
Old Apr 23, 2012, 07:34 AM
IgorNik is offline
Find More Posts by IgorNik
Joined Apr 2012
Good afternoon!
I have a problem with 106B +.
Today I connected 106B + to the computer and wanted to update 106B +.
Updating didn't come to the end and on the screen 106B + now only this picture:
I tried to update again, disconnected 106B + and included again, disconnected and turned on the computer but that didn't help.
Now in attempt to update I see "Error opening COM port":
I don't know what to do, somebody knows how to recover 106B+?
Thanks!
IgorNik is offline Find More Posts by IgorNik
Old Apr 23, 2012, 09:16 AM
flarssen is offline
Son, Norway
Joined Sep 2004
Most things can be found in the first post of this thread.
Old Apr 23, 2012, 05:00 PM
xplo5iv is offline
Find More Posts by xplo5iv
Joined Sep 2007
Burnt 1010B
Hi
I've owned my 1010B for some years, but I've just burned it moments after plugging in today
On opening I can see D14 is burnt, as is the unknown component attached to it, possibly a diode.
Anyone able to help me identify what they are so I can replace them?
I've tried searching, but couldn't find D14 mentioned.
(Arrows pointing to each component on attached photo)
ps Ignore the vga connector - it's used as a balance port on by ebike battery pack, this charger gets used for a lot more than just my planes!
Thanks in advance for any help :-)
xplo5iv is offline Find More Posts by xplo5iv
Old Apr 23, 2012, 05:12 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Would someone please do me a favor (or maybe one knows without doing it)?
I did not see an error for this in the manual for 306B.
Plug in a lipo with 3s or 6s and the balance port. Set the charge to NIcad or NIHM and see if it gives a "check balance cable" error. The main lead must also be plugged in.
If not start the charge at any rate you want and see if you can view the individual cell voltages while in NI mode. Two other possibilities are a "check balan port" error or perhaps no error (but unable to read cell voltages)
OR does it give an error?
Thanks.
ps. Don't forget about your setting , that would be bad thing.
gulio is offline Find More Posts by gulio
Old Apr 24, 2012, 04:13 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by xplo5iv View Post
Hi
Please check the PM we have sent to you, thanks.
Junsi
junsi is offline Find More Posts by junsi
Old Apr 24, 2012, 11:20 AM
minihawk is offline
Find More Posts by minihawk
Thailand, Bangkok, Wat Tha Phra
Joined May 2010
I am using a 106B+ charger bought from hobbycool.com, very accurate and great charger, no complaint so far.
minihawk is offline Find More Posts by minihawk
Old Apr 25, 2012, 05:13 PM
ERNALTO is offline
Find More Posts by ERNALTO
Brazil, BA, Salvador
Junsi, i have the same problem that post:
I have problems with the balance charge for LiPo batteries.
Connecting the 6s 4000mAh results in Bal. error. I see the burn line in the balance conector and i repair it but nothin, the charger say me batt low ou over and not balancing and measure the internal resistance.
The sequence:
1. connect charger to power (16v, 4.5A via jack)
2. connect balance port
3. connect main charge cables
As soon I connect the last main cable the error occurs.
The batteries are new (2x) and both have the same problem.
I am able to charge them normally (without balance port connect)
I checked the balance ports according to this post:
All works out OK.
The batteries show 15.27V and the digital diagnostic unit x6.5 shows the individual cells, so a battery problem is unlikely.
Can you help me??
PS.: Icharger 106B+
ERNALTO is offline Find More Posts by ERNALTO
Old Apr 27, 2012, 02:38 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
The sequence:
All works out OK.
Can you help me??
PS.: Icharger 106B+
We have sent you a PM, please check it, thanks for your cooperation.
Junsi
Old Apr 27, 2012, 02:40 PM
ERNALTO is offline
I've done all this, I tried to calibrate the difference is + - 2v on display, already updated the softwere and continues to swing port error message when I connect to load it reads the voltages, see:
cell 1 4,05
cell 2 4,05
cell 3 4,04
cell 4 2,01( and lowering)
cell 5 4,05
cell 6 4,04
Old Apr 28, 2012, 12:16 AM
jackheli is offline
Find More Posts by jackheli
Joined Aug 2006
My 306B went up in flames
I bought this charger in November and it has worked perfectly until now.
I was charging in parallel six 4S 4000 mah at 16amps, like I always do. After about an hour, the charger was at its final cycle putting out only about 6amps. Again, as I always do, I pressed the "INC" button to check individual cell voltage and bam! the charger caught fire... literally!
I raced to disconnect it from the power supply and from all batteries, but now my house smells like burnt bacon...
This was REALLY scary. Has it happened before? on the "INC" button?
jackheli is offline Find More Posts by jackheli
Old Apr 28, 2012, 07:00 AM
Mach3 is offline
Find More Posts by Mach3
Surrey, B.C.
Joined Feb 2004
Originally Posted by Mach3 View Post
My iCharger 1010+ is already at 3.14 which I see is the latest already. When I try to see if re-flashing would help, Junsi Upgrader (Ver1.6) give me a error saying "The update file is in inconformity with the device" .
Any others idea or is there anywhere I can sent it or should I just give up on it ?
junsi, can you help me with this or suggest as to what I should try ?
Mach3 is offline Find More Posts by Mach3
Old Apr 29, 2012, 12:06 PM
jackheli is offline
Joined Aug 2006
junsi, no comments on this?
Old Apr 29, 2012, 05:24 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
jack this is on icharger 3010 read the comments,i just ordered the 306B from progressive the other day hope nothing like that happen.
i also like to see if there has been other reports.
Ben
http://www.hobbyking.com/hobbyking/s...dProduct=11597
FASTBEN is offline Find More Posts by FASTBEN
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
