Old Dec 12, 2011, 02:25 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by olivzol View Post
Hello,
I'm having about the same issue. Same behavior on 208B or 106 B+.
Please check the PM we have sent.
Junsi
junsi is offline Find More Posts by junsi
Old Dec 12, 2011, 02:28 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by plank420 View Post
I have a 206b icharger and everytime i go to charge something it stops and beeps and says input vol err low voltage. It wont let me charge. Anyone know what is going on here?
Please check the parameter setting, check the setting of the low limit of voltage, if it is close to the input voltage, which is not supposed.
If it was not, press STOP button for 3 seconds to monitor if there is any difference between the input voltage and the actual voltage measured?
Junsi
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
@jackheli
If you use 5/21W bulbs (tail/brake combo) you have four possible loads:
http://www.rcgroups.com/forums/showp...5&postcount=27
Fred
flarssen is offline Find More Posts by flarssen
Old Dec 12, 2011, 03:36 PM
jackheli is offline
Find More Posts by jackheli
Joined Aug 2006
Originally Posted by flarssen View Post
@jackheli
Fred
Awesome. Thanks.
I was using 50W resistors in parallel. This setup is much better.
Thanks again.
jackheli is offline Find More Posts by jackheli
Old Dec 15, 2011, 10:43 AM
fox74 is offline
Find More Posts by fox74
Salt Lake City Utah
Joined Oct 2009
208b
Hi junsi, I bought a heli which come with couple of flight power 4250mA 8s batteries, my current charger can only charge 6s batteries. I am pretty set about buying an icharger base on all the good reviews I have read, my question is a 208B is suitabe charger for thses batteries. Thanks
fox74 is offline Find More Posts by fox74
Old Dec 15, 2011, 05:15 PM
Raehm is offline
Find More Posts by Raehm
Raehm's Avatar
Charleston, SC
Joined Jul 2006
re: Cells not registering
I have two almost brand new GForce 2200 3-cells that my iCharger noticed immediately as 2 cell batteries. I confirmed that the solder connections are OK, so the problem exists somewhere inside the balancing plug.
Are these plugs replaceable or can the wires be re-seated?
Raehm is offline Find More Posts by Raehm
Old Dec 15, 2011, 05:21 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
You are thinking that the balancing plug on the side of the charger is bad?
I wouldn't think this is replaceable.
We'll see what Junsi says.
Did you measure voltage at all the pins on the battery's balance plug?
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 15, 2011, 05:52 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
I am quite certain I don't have the proper instrument to make such a measurement.
Could it be just a bad cell? After only two or three cycles? And happening to two batteries?
Old Dec 15, 2011, 06:00 PM
RC Helicopter Pilot
Joined Mar 2010
That would seem highly unlikely.
Do you have a volt meter?
It is a good tool to have for any hobbyist.
Harbor Freight sells them for like $20.
I would measure voltage at all the balance plug pins before I condemned the charger unless you have checked it with a third battery pack and you get the same results.
Old Dec 15, 2011, 06:02 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
The charger is fine, as I have subsequently charged other batteries with no issues.
The cell-read failure was confirmed by both my iCharger and separate tester.
Old Dec 15, 2011, 07:06 PM
LizardMan is offline
Find More Posts by LizardMan
Joined Sep 2010
3010B and LiFe
After running several cycle tests on a new Hobbico 1100mAh 2S LiFe battery I have a few questions about charging them with the 3010B.
While charging the peak voltage reaches 3.60V, the charger begins a CV charging phase. Within an hour after the charge cycle completes per cell OCV drops to 3.34V. After a discharge test at 1C to 2.5V/cell a cell recovers to 3.23V. The OCV difference between a fully charged and drained cell is only 0.10V.
The discharge curve is very flat, like a NiCd/NiMH battery. Cell voltage varies with load applied, but the overall shape remains about the same.
A 2S LiFe seems a nice replacement for five cell NiCd/NiMH packs. I'm a bit concerned about tracking charge condition at the field. It looks like a CellLog or PowerLog wont be as useful as with LiPo packs.
Now for the questions:
1) The default storage voltage is 3.30V, only 0.04V below the fully charged OCV. Applying a load will pull cell voltage down. With only four hundreds of a volt to work with, what load should I use?
2) Is use of storage mode required? (I use it with LiPo)
3) Discharge tests do not terminate as a cell reaches the discharge limit voltage. Instead, the charger seems to divide the pack voltage by the number of cells and use the average. In LiPo mode, it stops when a cell reaches the discharge limit.
4) Does the LiPo 80% depth of charge guideline apply?
LizardMan is offline Find More Posts by LizardMan
Old Dec 16, 2011, 04:50 AM
flarssen is offline
Son, Norway
Joined Sep 2004
1. None.
2. No.
3. Yes, this flaw has been pointed out several times. It's actually the same for LiPo. I just tested with cutoff set to 3.30V. The charger didn't enter the CV phase (discharge reduce on) until pack voltage was 9.90V (3S). At that time lowest cell was 3.25V.
4. No.
Old Dec 17, 2011, 07:44 PM
OwlPic is offline
Find More Posts by OwlPic
OwlPic's Avatar
United States, MA, Tyngsborough
Joined Jun 2010
ECO 6-10 from Hobby King HK
Is the Hobbyking ECO 6-10 the same as the junsi 106?
It looks similiar.
OwlPic is offline Find More Posts by OwlPic
Old Dec 17, 2011, 07:50 PM
RC Helicopter Pilot
Joined Mar 2010
Different charger.
The iCharger is 250W.
And the fans are located in a different spot.
Old Dec 18, 2011, 11:19 AM
OwlPic is offline
OwlPic's Avatar
Joined Jun 2010
Ok - Is the firmware the same? The frontpanel operation seems similiar.
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 03:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 01:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 04:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 09:55 PM
