Old Nov 29, 2011, 02:19 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Originally Posted by Stan Hinman View Post
Actually, no. But I can fix that when I get home tonight...
Stan
Great.
One thing I don't like is it is heavy.
I have 2 server PS, all my wire adapters, 2 chargers, a parallel board, a volt meter and I carry my 3 - 6S 2700mAh Lipos in it.
It weighs 27LB.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Nov 30, 2011, 10:46 PM
Stan Hinman is offline
Find More Posts by Stan Hinman
Old gasbag glider guy...
Stan Hinman's Avatar
Tehachapi, CA
Joined Aug 2006
My 306B / Server Power Supply Setup
Originally Posted by TheWoodCrafter View Post
Great.
It weighs 27LB.
Mine is only a little over 17 lbs., with most of the same stuff except that I've only got the 306B charger, and I'm not transporting Lipo's in it. The voltmeter is in the my flight box. To quote akschu, the guy who designed the conversion kit for the PS, "The power supplies have 4 terminals, two for each power supply. You can use a jumper between the two middle terminals to put the power supplies in series and use the outer two for 24v (47amps) or you can jumper both the red and blacks to each other and put the power supplies in parallel mode where you have 12v (94amps)." Works great for me...
The rest is the usual paraphernalia that accompanies chargers; like conversion pigtails, harnesses, charging bag, etc. It all fits nicely in the Harbor Freight case.
Kind regards,
Stan
Stan Hinman is offline Find More Posts by Stan Hinman
Old Nov 30, 2011, 11:01 PM
RC Helicopter Pilot
Joined Mar 2010
Looks really good Stan.
Sure makes it convenient doesn't it.
Have you seen any snow yet in the Tehachapis?
Old Dec 01, 2011, 01:18 AM
tonypan is offline
Find More Posts by tonypan
Baoan ShenZhen China
Joined Apr 2009
I have a iCharger 206B used for one year, recently find balance port voltage measurment is not correct, one cell (cell 5) is always 0.03V higher than othels, I have 6 5S Packs, every pack is the same situation .
How to calibrate the balance port monitor voltage?
tonypan is offline Find More Posts by tonypan
Old Dec 01, 2011, 02:43 AM
crusey_aus is offline
Find More Posts by crusey_aus
Melbourne
Joined Aug 2010
Calibration procedure is listed on the first page of this thread
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Old Dec 01, 2011, 09:27 AM
mahathyr is offline
Find More Posts by mahathyr
Joined Dec 2011
hi there...noob here...basically first time parallel charging...everything went well charging 6 packs 6cell 4500mAh...everything was going fast..then when it went to the finishing stages like its trickle charging it takes like forever...is this normal or is there any setting i overlook?..many thanks for reading
mahathyr is offline Find More Posts by mahathyr
Old Dec 01, 2011, 09:53 AM
RC Helicopter Pilot
Joined Mar 2010
That last part is the CV mode (constant Voltage).
The balancing takes place here.
How long is forever?
It could take 1/4 of the charging time, depending how bad your batteries are out of balance.
Old Dec 01, 2011, 11:10 AM
Tehachapi, CA
Joined Aug 2006
Sure does. And I love being able to top off all my larger batteries in pretty short order. I've had no problems at all with this charger. It's great!
Snow, yes, but so far only above my house (just barely). I don't mind the cold, but this wind is really wreaking havok with the flying both at home and at work. We have friendly competitions once a week and we've had to cancel way too many of late...
Old Dec 01, 2011, 06:15 PM
redhotpearl is offline
Find More Posts by redhotpearl
Starring as Devils Advocate
redhotpearl's Avatar
Joined Feb 2009
Can I charge 4 (2S 5300mah) Thunderpower lipos at once? I have the Icharger 206b
redhotpearl is offline Find More Posts by redhotpearl
Old Dec 01, 2011, 06:20 PM
RC Helicopter Pilot
Joined Mar 2010
Sure you can.
How fast do you want to charge it?
Your charger is 20AMPS max.
4 x 5.3 = 21.2 = 1C
You will be charging at less than 1C but it will do it.
Old Dec 01, 2011, 06:32 PM
Joined Feb 2009
Sure you can.
4 x 5.3 = 21.2 = 1C
Thanks, just making sure. Love this charger.
Old Dec 03, 2011, 06:31 AM
dicio is offline
Find More Posts by dicio
Italia, Lombardia, Milano
Joined Nov 2011
Hi guys, i built a hot wire and i use "FOAM CUT" icharger 106b+ function.
It's really useful but, if i set up 10A when the process start the amperes that i read are only 2A.
Why ??
Archetto a caldo (Hot Wire) utilizzando il caricabatterie icharger 106b+ (2 min 10 sec)
dicio is offline Find More Posts by dicio
Old Dec 03, 2011, 05:26 PM
Raehm is offline
Find More Posts by Raehm
Raehm's Avatar
Charleston, SC
Joined Jul 2006
My iCharger 106b is working fine, but only charging to 98% (12.55).
Is that normal? What settings can I change to charge to 100%?
Thanks!
Raehm is offline Find More Posts by Raehm
Old Dec 03, 2011, 05:50 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Yes, this is both normal and expected. Post charge resting voltage of a lipoly is dependent on several factors - cell internal resistance, charge rate, pack temperature, charger setup parameters, etc... IMO, any charger that charges to 4.20 volts per cell resting is overcharging.
iChargers (and others) have the ability to adjust termination voltage either up or down. I typically set mine at ~4.18 volts per cell and charge at 2C rate. Upon termination, my lipolys are ~4.15 volts per cell. If you must have 4.2 volts per cell resting, you can adjust termination voltage to 4.21 or 4.22 volts per cell but understand that this will affect the useful life of your packs and only gain a few extra seconds of flight time.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Dec 03, 2011, 06:33 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Thanks!
Setting Balance speed to "Slow" brings you closer, as charge is terminated when current has dropped to 1/40 of initial current. Results in longer charge time though.
Fred
flarssen is online now Find More Posts by flarssen
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
