Old Nov 24, 2011, 11:57 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Originally Posted by LeszekJ View Post
No and yes.
MOSFETs take this role sometimes
Lol that's what I figured.
Hopefully Santa will drop off some tp batts this year but all of my setups are xh.
This guy is what I need correct?
http://epbuddy.com/index.php?main_pa...products_id=38
Its not rated to the 30x series though. That shouldn't matter though correct?
stgdz is offline Find More Posts by stgdz
Old Nov 24, 2011, 12:16 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by stgdz View Post
Is there a fuse in these chargers in case the user does something stupid?
There is a 7A fuse on the DC jack input. That's all.
Fred
flarssen is online now Find More Posts by flarssen
Old Nov 26, 2011, 10:19 AM
oz tinkerer is offline
Find More Posts by oz tinkerer
Joined Nov 2011
icharger input solar
to junsi
is it possible to input power into an icharger using a solar panel?
Does the icharger require contant voltage/constant current input?
Would an mppt ( max power point tracker) be useable if it is possible as solar input source to icharger?
If answer to the above is 'no' : would it be possible to modify icharger so it acts as mppt and has input plug for solar input?
oz tinkerer is offline Find More Posts by oz tinkerer
Old Nov 26, 2011, 10:54 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
A mppt would be nice. The charger itself can be set to a minimum input voltage. If that voltage is undershot, the charge current will be reduced automatically, so that the supply voltage hovers around the level that was set. This way, the charger can compensate the fluctuating output of the panel, and will not just stop with a low voltage error. Just make sure, that the panel's maximum voltage does not exceed the chargers specs.
Julez is offline Find More Posts by Julez
Old Nov 26, 2011, 01:55 PM
HuskyKMA is offline
Find More Posts by HuskyKMA
Go Huskies!
Camas, WA
Joined Dec 2009
I'm looking to get my first real charger, and the iCharger 206B and 208B caught my eye. Right now my packs range from 1S 160 mAh to 3S 1300 mAh, but I want the charger to be somewhat future-proof and be able to handle larger 4S-6S packs I might use in the coming years.
I know the 206B will handle my current packs, but will it be able to handle the larger packs in the future at decent charging rates, or charging two packs at once?
HuskyKMA is offline Find More Posts by HuskyKMA
Old Nov 26, 2011, 02:17 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
I went shopping for a good LiPo charger about 2 months ago.
I wanted something future proof also.
I wanted to be able to charge up to 6S batteries.
I needed something that would not take an hour at the field to charge.
I use 2700 mAh batteries now but knew I would be going to 5000 mAh batteries.
I wanted to be able to parallel charge multiple packs in a reasonable amount of time.
So I jumped in the deep end and bought a 306B and built a PS.
I don't think I will ever need another charger.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Nov 26, 2011, 03:14 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
The 30x series is not that much more for what you get. I have thought about adding a 29xhalf series with my 306 but the 306 is about twenty bucks more, well worth it fir what you get.
Old Nov 27, 2011, 09:17 PM
unhinged is offline
Find More Posts by unhinged
Auckland
Joined Mar 2010
Hello Junsi -- that is the correct address. Thank you for getting in touch and I hope to be charging again ASAP.
Thanks for your patience all other readers.
unhinged is offline Find More Posts by unhinged
Old Nov 28, 2011, 09:54 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Perhaps a better means of contac
http://www.rcgroups.com/forums/member.php?u=143941
Old Nov 28, 2011, 01:18 PM
unhinged is offline
Auckland
Joined Mar 2010
Thank you very much Charles. I struggled to find that contact. I somehow just miss these things when scanning the page. This will prove just ideal.
Apologies again.
Old Nov 28, 2011, 09:39 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
For a forming charge on a 4000 may nicad I charge at a quarter c, so its 1.0a.
Is there anything else I have to do when doing a first charge on a nicad?
Old Nov 28, 2011, 11:40 PM
ZagiZag is offline
Find More Posts by ZagiZag
Joined Nov 2011
balance without charging
Charger Icharger208 +. There is no charge-balancing mode?
ZagiZag is offline Find More Posts by ZagiZag
Old Nov 29, 2011, 01:51 PM
Stan Hinman is offline
Find More Posts by Stan Hinman
Old gasbag glider guy...
Stan Hinman's Avatar
Tehachapi, CA
Joined Aug 2006
Same position I was in several months ago, and ended up with the 306B and this 12/24v selectable power supply.
I even have the same case from Harbor Freight. I'm very pleased with this setup.
Stan
Stan Hinman is offline Find More Posts by Stan Hinman
Old Nov 29, 2011, 01:58 PM
RC Helicopter Pilot
Joined Mar 2010
Stan
Funny how great minds think alike...
Got any pictures?
Old Nov 29, 2011, 02:05 PM
Tehachapi, CA
Joined Aug 2006
Got any pictures?
Actually, no. But I can fix that when I get home tonight...
Stan
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
