Old Nov 20, 2011, 12:35 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
What size batteries are you wanting to charge?
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Nov 20, 2011, 12:51 PM
Jimmie Neutron is offline
Find More Posts by Jimmie Neutron
Michigan
Joined Jan 2011
Yes, you can parallel charge with this charger.
You can actually parallel charge with just about any decent charger.... it just makes more sense to do this with a more powerful 20a charger, like many in the iCharger line.
To match you with the proper size charger, we will need to know the cell count, mah, and chemistry of the batteries you are currently using; as WoodCrafter has asked.
Jimmie Neutron is offline Find More Posts by Jimmie Neutron
Old Nov 20, 2011, 11:22 PM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Yes, you can definitely parallel charge. Took less than an hour to charge up 6 4000 4S Lipos for my 71 Slick on the I306B
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Nov 21, 2011, 11:22 AM
nartac is offline
Find More Posts by nartac
United States, CA, Irvine
Joined Sep 2011
Hi guys. I posted this problem on another forum but a member directed me to here to see if I can get this resolved. As posted on the other forum, I have 3x 2200mah 3s lipo batteries. I have discharged these batteries for storage with a skycharger B6AC+ charger and placed them in the refrigerator few weeks ago. Recently I purchased a used icharger 208b and it works well in charging up my 1S batteries for my 120sr and mcpx. Today I decided to pull out these 2200mah batteries to fly my B400 but when plugged it into the balancer, I initially plugged the balance plug into the balancer and the 208B identified this as 11.1V (3s) and that alternatively blinks with "main port?". I then plugged the deans lead in and I get Vout low. I checked these batteries with one of those handy battery checker that shows the voltage of these batteries and it shows each cell has 3.83-3.84V with 11.4v total for each of the batteries. I plugged these batteries back into the skycharger B6AC+ and it charges the batteries just fine without showing any errors.
The firmware has been updated to latest version and all settings are at default. The watt limit has charge set at auto and discharge at 30W.
Any help is appreciated.
nartac is offline Find More Posts by nartac
Old Nov 21, 2011, 08:32 PM
BGR is online now
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Here is the manual for the 208b incase you dont have it. http://www.progressiverc.com/media/i...B%20Manual.pdf. It does not even list the Vout error you posted.
BGR is online now Find More Posts by BGR
Old Nov 21, 2011, 10:08 PM
fbm224 is offline
Find More Posts by fbm224
fbm224's Avatar
Mexico, MEX, Naucalpan
Joined May 2009
Hi,
I have one of the first 106B+ from HK, which I like very much. Yesterday I wanted to discharge a bit one of my lipos and when I pushed the start button the screen blinked and a smoke smell came out, immediately a message appeared and the fan started. I disconnected every thing as fast as I could.
Later I did connect it again and everything seemed ok, but when I connect the battery to the output, it shows immediately "Int Tem Over Break Down" and the fan starts.
I opened it to try to find the origin of the smell, but didn't notice anything burnt. Please help me. I don't know what went wrong, or how to fix it.
By the way I'm really glad to see that the thread is alive and the chargers are still for sale, but I would like very much not to have to buy another.
fbm224 is offline Find More Posts by fbm224
Old Nov 22, 2011, 02:25 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Could you please press STOP for 3 seconds to monitor the voltage of each cell to see if there is any difference between the displayed voltage and measured voltage? If different, please check if the battery balance port again, the wire from balance board to the charger, and the balance board are damaged or some lines are disconnected.
Junsi
junsi is offline Find More Posts by junsi
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by fbm224 View Post
Hi,
Please check the PM we have sent to you, thanks for your cooperation.
Junsi
Old Nov 22, 2011, 07:00 AM
Woody_99 is offline
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
Noise Abaitment
This question is not specific to the iCharger, but that is what I am using, so I thought I would post my question here.
With my iCharger, I am using a server P/S (2U size I believe). The power supply has a high speed noisy fan on it. I'm wondering what has been tried to cut down on the noise of these supplies.
I have tried putting some egg crate foam around it, but didn't help much. I was also thinking about moving it further away, but that would involve longer leads to the charger. How long could I make the leads, it I increase the wire gage?
Any thoughts on making the power supply a little quieter would be appreciated. (anyone unplugged the fan all together?)
Thanks!!
Woody_99 is offline Find More Posts by Woody_99
Old Nov 22, 2011, 07:56 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
There are threads on server power supplies being used as charger power supplies and in those threads there are post on replacing the fans, installing temperature controlled variable speed ones,using resistors to slow the fans down and such.
Learn to use the SEARCH it is an extremely powerful FORCE
Old Nov 22, 2011, 09:15 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Got my 306 last night. I should have gotten one of these instead of my 1010.
stgdz is offline Find More Posts by stgdz
Old Nov 23, 2011, 08:21 AM
Davey NY is offline
Find More Posts by Davey NY
Ya gotta land eventually...
Davey NY's Avatar
United States, NY, Mahopac
Joined Sep 2010
volts and amps- input verse output
Question guys. I searched and just could not find what i was looking for and seems to be a fundamental principle I am missing:
if my Junsi 350 Power supply outputs 15volts and 23 amps, how is it that I can charge my 3S batteries on that power supply. Does the 208B step down the input received from the power suplly and then output the needed volts? What happens to that extra voltage? is it dissipated in the form of heat?
Second- if the Junsi350 can only give 15volts then how does it charge a 6S battery that requires much more? Does one set the amps higher so long as not goingover max C rating of the battery?
Sorry guys, I truly searched and googled and searched...
David
Davey NY is offline Find More Posts by Davey NY
Old Nov 23, 2011, 11:49 AM
Southern Pride
Most chargers including the iChargers have a Buck / Boot circuite which make it possible to charge batteries below or above the input voltage.
Old Nov 24, 2011, 09:08 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Is there a fuse in these chargers in case the user does something stupid?
Old Nov 24, 2011, 11:25 AM
LeszekJ is offline
Find More Posts by LeszekJ
LeszekJ's Avatar
Poland
Joined Nov 2010
No and yes.
MOSFETs take this role sometimes
LeszekJ is offline Find More Posts by LeszekJ
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
