Old Nov 15, 2011, 09:15 PM
crusey_aus is offline
Find More Posts by crusey_aus
Melbourne
Joined Aug 2010
Turn off the capacity limit setting, serves no real purpose for lipos
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Old Nov 15, 2011, 09:25 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The capacity limit as well as the time limit are adjustable and can be turned off.
It really helps if you download ,print out and study the Owner's Manual.
Old Nov 15, 2011, 09:36 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
yeah I did download it, couldn't find the error though in the manual.
yeah page 27 didn't list the error
stgdz is offline Find More Posts by stgdz
Old Nov 16, 2011, 12:15 PM
Southern Pride
It is really not an error if one has capacity limit set to 2200 mAh and the charges a 3300 or 5000 mAh battery or has time out set at 120 min. and starts a charge that takes more than two hours.
Chargers still require thier user to do part of the thinking and adjust setting .
Charles
Old Nov 17, 2011, 12:48 PM
Dzejar is offline
Find More Posts by Dzejar
Joined Mar 2010
It's written first conect charger to power supply and then turn it on.
How I can turn on Pb batery as a power supply?
If I understand correctly, the power supply can be on while conecting charger, but the batery must be disconected...
Can be used big switching power supply? ( more then 900W)
Dzejar is offline Find More Posts by Dzejar
Old Nov 17, 2011, 12:57 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
You need to have a little common sense here.
Connecting your charger to a Pb battery with an alligator clip IS turning it on.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Nov 17, 2011, 08:54 PM
BGR is online now
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
BGR is online now Find More Posts by BGR
Old Nov 17, 2011, 10:11 PM
unhinged is offline
Find More Posts by unhinged
Auckland
Joined Mar 2010
Message for Junsi
Regards post '11419'. I do not know if this is appropriate to post here, but I lost a pm from Junsi giving their contact details regarding my 208b which I mailed back to China at Junsi's advice. This was over 2 weeks ago, and I was wondering Junsi, if you could update me as to when I can expect something back. Much Appreciated.
Thank you all for your patience.
unhinged is offline Find More Posts by unhinged
Old Nov 17, 2011, 11:50 PM
NefariousRC is offline
Find More Posts by NefariousRC
NefariousRC's Avatar
USA, CA, San Diego
Joined Jan 2011
I've got a question about charging Nimh packs. I'm trying to charge a 6V 5000mAh pack on my 306B and it completes the charge cycle but my pack is only at 5.25V. What am I doing wrong?
NefariousRC is offline Find More Posts by NefariousRC
Old Nov 18, 2011, 01:47 AM
unhinged is offline
Auckland
Joined Mar 2010
Thank you Junsi for the quick reply. Can you please find out if the charger has arrived in China, and maybe when I can get it or another one back as soon as possible. I was going to write a note to that address which you have sent me, but I think you could find out more easily for me, because I do not know if these letters are getting to the right people.
Old Nov 18, 2011, 05:12 AM
Dzejar is offline
Joined Mar 2010
There is big diference. With power supply you start from zero voltage, but with batery you have directly full voltage on charger, and this can be problem or not?
when not, then I can also conect charger at home to power supply switch on...
Old Nov 18, 2011, 06:36 AM
stockman20 is offline
Find More Posts by stockman20
Joined Sep 2011
If you have no batteries (to be charged) connected to it than it doesn't matter how you turn it on / hook up the power supply. Sometimes I'll plug in my PS with the charger already connected...sometimes I'll connect the charger to the PS AFTER plugging it in. Doesn't matter if you have no batteries connected to it, and even then it might not.
stockman20 is offline Find More Posts by stockman20
Old Nov 18, 2011, 10:19 AM
xener is offline
Find More Posts by xener
United States, GA, Alpharetta
Joined May 2011
Hi Junsi. Is it possible to add reading of cells internal resistance while charging?
May be in 3.16 ? :-) I would like to know a cell conditions when getting charge.
xener is offline Find More Posts by xener
Old Nov 18, 2011, 10:24 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I have to ask...why?
You can simply check either before or after charging. Since internal resistance of lipolys is very stable over a wide charge state, I see checking during the charge process providing zero benefit, other than saving a few seconds.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Nov 20, 2011, 03:31 AM
Lindert is offline
Find More Posts by Lindert
Joined Jun 2010
ICharger 1010B+
Hi,
My charger is a Graupner Ultramat 16s, but I have a problem with this one, he charges the last cel of a batterie only till 3.09V. He does this with all my batterie's, maybe a bad charger ?
Now, i saw on Hobbyking the Icharger 101B+, I Would like to read this whole thread but there a 'just' +700 pages .
Is this a good charger for me ? I fly electro so i have to charger big batteries. Can i also charge parralel with this charger ?
Lindert is offline Find More Posts by Lindert
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
