Old Nov 11, 2011, 12:41 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by Raehm View Post
finished at 01:38 hrs.
should I try a 2c charge? what would be the amp setting?
You can set current to 10A max, which is close to 2C (10.8A).
Maybe you should study the last part of a charge to get familiar with how the charger operates. Enter cell voltage display and see what the voltage of each cell is. When a cell reaches 4.20V, current will start to drop to make sure the voltage stops rising. If all cells are the same, current will drop to a fraction of the initial current and the charge ends. If the pack is unbalanced, it will start to discharge high cells (cell voltage flash on display) while it continues to charge low ones at low current. This means that this last phase will take longer to complete.
Fred
flarssen is online now Find More Posts by flarssen
Old Nov 11, 2011, 05:05 PM
jawelsh is offline
Find More Posts by jawelsh
jawelsh's Avatar
San Antonio, TX
Joined Apr 2006
Originally Posted by jawelsh View Post
Well, I just smoked my 306B charger today. It had been working awesome up to this point. I was parallel charging 2 6S 5000mah packs at 20 amps and all of a sudden smoke started pouring out of the cooling fan housing.
I purchased it from EP Buddy about a month ago. What is the warranty service like? Will they replace this with out hassle or do I just throw it in the trash and buy something different? This is my only charger and I'm down until I get it replaced. Never should have sold my hyperion.
JAW
I wanted to follow up on this post and did not want to leave it hanging. Dale at EP Buddy took care of me. I was able to get a replacement and in time to be able to fly this weekend. I'm glad to see a company stand behind their product and take care of their customers!
JAW
jawelsh is offline Find More Posts by jawelsh
Old Nov 12, 2011, 08:33 AM
Raehm is offline
Find More Posts by Raehm
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Fred
Fred, thanks for that valuable feedback!
Raehm is offline Find More Posts by Raehm
Old Nov 13, 2011, 12:16 AM
Ola. is online now
Find More Posts by Ola.
Joined Feb 2011
Can i use my iCharger 206B to re-charge a 12v acid and/or dry car battery? (using a 110/230v powersupply at home)
I mean, i expect it to manage it, but i dont know what program to use etc..
Ola. is online now Find More Posts by Ola.
Old Nov 13, 2011, 12:17 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Yes. A car battery is a 12V Pb battery. As such, use 12V Pb setting.
mrforsyth is online now Find More Posts by mrforsyth
Old Nov 13, 2011, 03:07 AM
badger-b is offline
Find More Posts by badger-b
Badger
badger-b's Avatar
UK
Joined Jul 2008
Originally Posted by LeszekJ View Post
"After starting the charger" doesn't mean "when you are charging a battery".
Well the original instruction is hardly clear about this whole procedure.
badger-b is offline Find More Posts by badger-b
Old Nov 13, 2011, 03:10 AM
badger-b is offline
Badger
badger-b's Avatar
UK
Joined Jul 2008
Originally Posted by kgfly View Post
Have you tried letting go of the buttons after the third beep rather than waiting for the fourth?
Have you heard how quick the beeps are! My fingers and reactions arent as quick as they once were
Surely if this was the case, the procedure would have mentioned it - I still havent had a response as to WHY the darn thing is beeping FOUR times, when all thats mentioned is 3.
Old Nov 13, 2011, 09:53 AM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Hi. I just bought a 306b and am waiting on delivery. Does it need to be calibrated. Score use? I'm using Parallel cables. I still want to use the balance charge setting on the charger , yes ?
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Nov 13, 2011, 10:08 AM
3Dplank is offline
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Quick question about parallel charging. If I am parallel charging 2 3s 1000 mah batteries can I set the amps to 2.2. Or 3 3s 1000 set the amps to 3.3. Is this correct?
3Dplank is offline Find More Posts by 3Dplank
Old Nov 13, 2011, 10:50 AM
DrMobile is offline
Find More Posts by DrMobile
Joined Oct 2010
I just Receiced My Icharger i106b Plus from Hobbyking.com
I having problem with that charger.
Today I put a 2200mah battery for balance charge,
after few minutes. i checked on charger its was showing 4.27, 4.25, 4.27
charging was still still not finished, but I stoped charging process becuase I wanted to charger charge my lipo any more..
Why this charger over charged my lipo,
second problem.
when ever I put my batteries for storage voltage, if battery already have voltage of 3.50 to 3.70 or something near this per cell, charger instantly show DONE<
I already received my charger with firmware version 3.14
what to do?
DrMobile is offline Find More Posts by DrMobile
Old Nov 13, 2011, 11:26 AM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
For a 1C charge in parallel you add up the total MAH of the batteries. Two 1000mah batteries = 2 amps.
BGR is offline Find More Posts by BGR
Old Nov 13, 2011, 11:52 AM
3Dplank is offline
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Old Nov 13, 2011, 04:01 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Just wanted to report that all is well with my new iCharger 106b. About an hour to balance charge 5 3c 1800. Migrating to the 2200mAh 30c, and will be happy charging 4 at a time.
Of course, once one understands the iCharger settings, charging is a breeze!
Thanks to all for your help!
Old Nov 14, 2011, 01:20 AM
DrMobile is offline
Joined Oct 2010
second problem.
what to do?
any one plz tell me about my problem plz
Old Nov 14, 2011, 02:11 AM
Patriek is offline
Find More Posts by Patriek
Fun Scaler
Patriek's Avatar
EHTX
Joined Jun 2007
Charging 2 6S 5Ah in parallel at 2C each: charge time = ~25 minutes
Charging 2 6S 5Ah in parallel at 3C each: charge time = ~29 minutes
Balancing starts in CV mode (which seems to take longer when charging at 3C compared to 2C) and balancing mode is set to slow. Both batteries are fairly new, IR ~ 2mOhm/ cell and balance within <10mv
What could cause a 3C charge rate to take longer than a 2C charge rate?
-Patriek
Patriek is offline Find More Posts by Patriek
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
