Old Nov 09, 2011, 11:27 PM
Raehm is offline
Find More Posts by Raehm
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Greetings! I'm totally new to the icharger and looking for some general programming procedures for parallel balance charging using an XH paraboard.
Could anyone please refer me to specific posts or youtube videos on this subject?
Thanks!
Raehm is offline Find More Posts by Raehm
Old Nov 10, 2011, 12:21 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Search on YouTube for progressiverc as dave has a whole series of how-to videos posted there.
kgfly is offline Find More Posts by kgfly
Old Nov 10, 2011, 07:50 AM
Rumple is offline
Find More Posts by Rumple
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
Many of David's videos can also be found directly on the ProgressiveRC website when browsing through the parallel equipment he sells.
TJinguy also has a great website. Check the How-To: Parallel charging page.
Rumple is offline Find More Posts by Rumple
Old Nov 10, 2011, 10:21 AM
badger-b is offline
Find More Posts by badger-b
Badger
badger-b's Avatar
UK
Joined Jul 2008
As requested by Junsi, heres a video of my calibration procedure.
106b+.wmv (1 min 33 sec)
badger-b is offline Find More Posts by badger-b
Old Nov 10, 2011, 11:39 AM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
First time using my iCharger106b, I know that my Lipo's do have "vastly different voltages".
So, before doing a balance charge, how does one equalize the voltage on all the batteries?
Old Nov 10, 2011, 12:01 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Do you mean the batteries or the cells in each battery?
It is normal for cells to be at different voltages when discharged. The only time they need to be balanced is when charged.
Charles
Old Nov 10, 2011, 12:25 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Charles
I meant "cells". The cell voltages are certainly outside of the limits as suggested by TjinTech...
"Ideally the packs to be charged should all be at a similar voltage. If I had to put a number on it I would say that all cells should be within .2V for each other"
Old Nov 10, 2011, 12:41 PM
Southern Pride
So you are saying your cells are greater than 0.2V inbalance when discharged?
How low are they?
Cells should not be below 3.7 after a flight / useage.
Easy / slow way to get them balanced is to charge at a low rate such as < .3A untill the cells are balanced at which time they can be charged faster.
iChargers can be set to start balancing at different ststes of charge. I would suggest setting the Blance to Start at Storage which is 3.85 per cell in order to get these batteries balanced.
If the Balance is set to start at CV stage then no balancing takes oplace until cells are at 4.2 volts and while this works well with balanced cells it does not work so well with poorly matched cells.
Charles
Old Nov 10, 2011, 01:08 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
How low are they?
Charles
Sounds good. Thanks!
Old Nov 10, 2011, 01:55 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
I think there is some misunderstanding here. The 0.2V max difference quoted is regarding parallel charging of packs; cells in one pack should not be more than 0.2V different from the cells in the other pack when they are connected in parallel.
Fred
flarssen is online now Find More Posts by flarssen
Old Nov 10, 2011, 02:04 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Fred
That definitely my situation. So I am going to "Storage Charge" each battery so as to get them to a fairly close voltage.
Can I "Storage Charge" multiple Lipo's in parallel?
Old Nov 10, 2011, 02:16 PM
Son, Norway
Joined Sep 2004
Yes, but then you have to connect them in parallel first
As long as they are all discharged, paralleling packs is ok. Voltage will equalize pretty fast as long as all packs are below storage voltage.
Fred
Old Nov 10, 2011, 03:09 PM
Southern Pride
OK big difference between cells mbatteries and charging single packs and parallel charging packs. It most often helps to supply as many details as possible.
If the batteries are similiar as in 3S approx. same capacities and approx. the same voltages as in between 11.0 volts and 11.5 volts then just connect them in parallel by their main power leads, wait 15 minutes then parallel the balancing leads then start the balanced charge or Storage charge.
If a single LiPoly has cells greater than 0.2V inbalance then use the slow charge / balance I suggested earlier.
There are many threads on parallel charging and there is really little point in trying to cover all of the whys or why nots ,do's or don'ts here.
http://www.rcgroups.com/forums/showthread.php?t=932319
Charles
Old Nov 10, 2011, 06:21 PM
LeszekJ is offline
Find More Posts by LeszekJ
LeszekJ's Avatar
Poland
Joined Nov 2010
"After starting the charger" doesn't mean "when you are charging a battery".
LeszekJ is offline Find More Posts by LeszekJ
Old Nov 10, 2011, 08:03 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
I would think that means after you plug it into power.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
