Old Nov 06, 2011, 03:40 PM
H2SO4 is offline
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Originally Posted by blaues_Kopftuch View Post
When you turn the power supply on, the voltage on the output rises slowly (in terms of milli seconds or nano seconds), thats the big difference.
Right, and that waveform is presumably at least somewhat specific to each power supply and its design.
H2SO4 is offline Find More Posts by H2SO4
Old Nov 07, 2011, 02:22 AM
Trevorh is online now
Find More Posts by Trevorh
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
True, but at least the big capacitor on the output of the supply is empty when you switch it on, so can absorb any spikes as it charges up. Whereas if the power supply is already turned on, the capacitor is fully charged and ready to discharge instantly when you connect your charger. You are then dependent on whatever capacitor is on the input of the charger to soften the blow.
Trevorh is online now Find More Posts by Trevorh
Old Nov 07, 2011, 03:11 AM
H2SO4 is offline
H2SO4's Avatar
Joined Jan 2011
Thanks, that makes sense.
Old Nov 07, 2011, 06:56 AM
hangtime21 is offline
Find More Posts by hangtime21
Joined Oct 2011
What do you people think about using this lipo reader as reference for calibration?
hangtime21 is offline Find More Posts by hangtime21
Old Nov 07, 2011, 07:23 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Extremely unwise. I tested three or four variants of those and they all showed poor accuracy and repeatability. You could perhaps use a high quality cell checker that has been proven by users to have decent factory calibration and accuracy. Candidates would include the CellLog8S and PowerLog6S.
Best bet is a high quality, high precision DVM/DMM with at 0.2% accuracy (or better) in the 5V DC range.
kgfly is offline Find More Posts by kgfly
Old Nov 07, 2011, 08:23 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Always use the same reference for all cell values when calibrating. This ensures that all cell voltages are calibrated equally, even if they are not 100% correct. Cell checkers are in principle several meters in one unit and should not be used.
Fred
flarssen is online now Find More Posts by flarssen
Old Nov 07, 2011, 09:47 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Yes, these things are extremely unreliable abd inaccurate.
Also, normally a meter should not be calibrated with another meter, but against a standard.
The voltage standart of 4.5V which I mentioned earlier is now assembled and is in the aging process. When it is shipped and arrives here, I will report my findings concerning using it as calibration standard.
Julez is offline Find More Posts by Julez
Old Nov 07, 2011, 12:20 PM
badger-b is offline
Find More Posts by badger-b
Badger
badger-b's Avatar
UK
Joined Jul 2008
So, on the subject of calibration, anyone got any ideas on my problem I posted a day or so back?
http://www.rcgroups.com/forums/showp...ostcount=11438
badger-b is offline Find More Posts by badger-b
Old Nov 09, 2011, 02:21 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by badger-b View Post
Been a while since I posted here, and with over 700 pages, it may have been covered so apologies. I updated the firmware on my 106B+to the latest (3.14) as it was occasionally not changing the interface display when buttons were pressed - somethimes I needed to push the button REALLY hard, or maybe several times before the display changed. The upgrade doesnt seem to have fixed that, but has now revealed a different, more serious problem.
On every pack I connect ( 3s upwards ) in balance charge mode, cell two reads WAY lower than actual. Leaving it on balance charge for ages ( which I did first time i saw the readings cos I thought cell 2 WAS low ) changes nothing. I looked at the front pages and read the calibrate charger PDF, but following the procedure , all I get is as far as powering up the charger with the 4 buttons pressed, and all I see is a long serial number, and cant get past that stage ??
Even if I could, I still cant see how this will calibrate the individual cell volt readings- as it seems to just mention "battery" voltage versus battery voltage on a DVM.
Help.
When calibrating, please refer the instruction carefully, don't press 4 buttons together all the time when electrify the iCharger, loose the buttons when hearing 3 beeps from the buzzer.
If the voltage of second cell reads much lower than the actual one, you need check if the balance socket on the right side of the charger is burnt accoding to the file bal err.
Junsi
junsi is offline Find More Posts by junsi
Old Nov 09, 2011, 04:08 AM
badger-b is offline
Badger
badger-b's Avatar
UK
Joined Jul 2008
If the voltage of second cell reads much lower than the actual one, you need check if the balance socket on the right side of the charger is burnt accoding to the file Attachment 4405658.
Junsi
Well Ive only ever used it with a balance board, so according to the last statement of the pdf - I should be "protected" against this particular error.
What message should actually be displayed when I try to enter calibration mode then?
Old Nov 09, 2011, 04:56 AM
badger-b is offline
Badger
badger-b's Avatar
UK
Joined Jul 2008
Tried again just now, and I get FOUR beeps when powering up with the buttons all held down. I release immediately after the beeps, and get a normal screen. Connecting the battery and balancer plug, then "start" the charger......holding the stop button for 3 seconds changes nothing.
Old Nov 09, 2011, 09:55 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Calibrating steps:
1. Press <Stop><Dec><Inc><Start> these 4 buttons together, then electrify the iCharger; loose the
Note 3 beeps not 4.
everydayflyer is online now Find More Posts by everydayflyer
Old Nov 09, 2011, 10:11 AM
badger-b is offline
Badger
badger-b's Avatar
UK
Joined Jul 2008
Yes I know that, but I get FOUR beeps in quick succession not THREE.
Old Nov 09, 2011, 10:20 AM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Will you get 3 if you continue the hold them down a little longer?
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Nov 09, 2011, 11:50 AM
badger-b is offline
Badger
badger-b's Avatar
UK
Joined Jul 2008
Nope...
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
