Old Nov 04, 2011, 04:58 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Originally Posted by blaues_Kopftuch View Post
To me it's almost a fact that the iCharger, some time ago, could not survive being connected (with battery already connected) to a running power supply or car lead-acid battery.
My question is if this problem still exists or if "the chinese man was learning really quick" and this problem is solved / precautions are taken?
Being a n00b, a few dozen posts ago I asked "why does the charger sometimes hang on startup?". It was quickly pointed out to me that my habit of connecting the battery before powering up the charger was procedurally incorrect.
Hence, I feel I can readily answer your question by saying that the problem has definitely NOT been resolved as of firmware 3.13h in a 206B, and that the act of powering up with the battery already attached causes a full lockup about 30% of the time, and even what appears to be a reboot cycle on rare occasions.
I never see either of those symptoms if I remember to power up before attaching the battery.
H2SO4 is online now Find More Posts by H2SO4
Old Nov 04, 2011, 05:30 AM
blaues_Kopftuch is offline
Find More Posts by blaues_Kopftuch
Joined Nov 2011
What was the voltage of your battery pack (empty) and did you turn on the power supply when the charger was connected or did you first turn on your power supply and then attach the charger?
And what was the voltage of your power supply?
But at least your 206B still works ... the posts i read in german RC forums were about destroyed chargers. But as stated, they assume that the batterypack voltage has to be at least 3-4 volts higher than the input voltage for this to happen.
regards
blue bandana
blaues_Kopftuch is offline Find More Posts by blaues_Kopftuch
Old Nov 04, 2011, 05:35 AM
ramboman is offline
Find More Posts by ramboman
Waterloo, Belgium
Joined Dec 2004
I like my iCharger 3010B to charge my 12s2p a123, balancing not needed, takes less than 15min for a full charge.
Before it I used (and still use) a MasTech 5010 power unit. There is no automatism, if you know what you do, it's nice:
* set current to 20A
* set voltage to 43.2V (12 * 3.6V)
* go !
Phase CC: current is limited to 20V
Phase CV: voltage is limited to 43.2V
Phase switching is part of the design of the power unit
There is no "end", current falls to zero when pack is full.
ramboman is offline Find More Posts by ramboman
Old Nov 04, 2011, 05:57 AM
H2SO4 is online now
H2SO4's Avatar
Joined Jan 2011
I use 1S cells as well as 2S and 3S packs. The problem intermittently manifests itself with all of them, and I've never noticed that the 3S batteries, for example, are any more or less predisposed to causing a "bootup hang".
I never run my batteries down below 3.8V/cell, so the range of voltages is from say 3.8V (1S discharged) up to 12.6V for a full 3S pack about to be discharged down to storage level.
The charger and power supply are permanently connected. Hence, the act of flicking the switch on the supply immediately "energises" the entire system.
It's a Turnigy T-20Pro, 14 Volts 220 Watts. I've regularly pushed it up to just over 200W and it's never skipped a beat.
I can't comment on what might happen with 5S and 6S setups, but my own 206B has lived through literally hundreds of these "hangs" (battery already attached on powerup) before I found out it was a no-no. Even now I regularly forget and attach the battery first, because past history has led me to (complacently?) conclude that the charger is really not that fragile, and the worst that happens is a hang - sometimes.
In fact, most of the time everything is perfectly OK, even with 6x 3S 2200mAh already attached through a paraboard.
I'll definitely be more careful if I should I ever graduate to 4S+ setups. Thank you for the information regarding reported damage at higher voltages.
Old Nov 05, 2011, 08:55 AM
Joined Nov 2011
Yes ... but in fact thats the method that is known not to destroy the charger.
According to the posts in the german forum the "destrutive" way to power everything is / was: (thats the question)
Turn on the power supply and THEN plug the charger in the power supply (with battery already connected and battery voltage 3-4 Volts higher than power supply voltage / car lead-acid battery voltage).
Such thing could happen when your pole-connection-gripper slips of the car-battery and you just connect it back to the car-battery without disconnection the LiPo you were just charging.
regards
blue bandana
Old Nov 05, 2011, 11:05 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Originally Posted by Dusey52 View Post
I don't think it's unreasonable to expect a charger to survive a power failure while it's in use. I can think of several ways a charger could lose power, like a breaker tripping. Any manufacturer that doesn't account for this in their design isn't doing their job.
Easy, gentlemen. iChargers survive power failures.
We are talking about two different situations here:
A) Connect charger output to battery, then to power supply, then switch power supply on --> no problem.
This is what would happen during a power outage.
B) Connect charger output to battery, switch on power supply, then connect charger to running power supply, or supply battery --> problems have been reported.
Julez is offline Find More Posts by Julez
Old Nov 05, 2011, 01:16 PM
Joined Nov 2011
Exactly :-) and no one can tell me if B is still the case or if Junsi changed the hardware / software to handle this problem :-(
regards
blue bandana
Old Nov 06, 2011, 06:50 AM
badger-b is offline
Find More Posts by badger-b
Badger
badger-b's Avatar
UK
Joined Jul 2008
cell two reading low on all batteries
Been a while since I posted here, and with over 700 pages, it may have been covered so apologies. I updated the firmware on my 106B+to the latest (3.14) as it was occasionally not changing the interface display when buttons were pressed - somethimes I needed to push the button REALLY hard, or maybe several times before the display changed. The upgrade doesnt seem to have fixed that, but has now revealed a different, more serious problem.
On every pack I connect ( 3s upwards ) in balance charge mode, cell two reads WAY lower than actual. Leaving it on balance charge for ages ( which I did first time i saw the readings cos I thought cell 2 WAS low ) changes nothing. I looked at the front pages and read the calibrate charger PDF, but following the procedure , all I get is as far as powering up the charger with the 4 buttons pressed, and all I see is a long serial number, and cant get past that stage ??
Even if I could, I still cant see how this will calibrate the individual cell volt readings- as it seems to just mention "battery" voltage versus battery voltage on a DVM.
Help.
badger-b is offline Find More Posts by badger-b
Old Nov 06, 2011, 07:04 AM
H2SO4 is online now
H2SO4's Avatar
Joined Jan 2011
I get that A and B are physically different, but I don't see why it should make a big difference on an electrical level unless the power supply itself is somehow producing transients which kill the charger in scenario B.
Old Nov 06, 2011, 10:34 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Hi folks,
I think these are useful items and you can have a discount with the following buddy codes
2S-Buddy code:
http://www.hobbyking.com/buddy.asp?c...6-657CA305EE4E
Item description:
http://www.hobbyking.com/hobbyking/s...dProduct=19939
3S- Buddy Code:
http://www.hobbyking.com/buddy.asp?c...1-67566F91D2F0
Item description:
http://www.hobbyking.com/hobbyking/s...dProduct=19940
4S-Buddy Code:
http://www.hobbyking.com/buddy.asp?c...3-284D6672CE2F
Item description:
http://www.hobbyking.com/hobbyking/s...dProduct=19941
I find I tend to need to pull on the balance port cable when disconnecting the batteries from the charger and/or parallel boards. The above items will help to eliminate the need and keep your balance leads in good shape. I just ordered some to try
chewy
chewytm is offline Find More Posts by chewytm
Old Nov 06, 2011, 10:40 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Wish there was a 10S one to use on the 1010B and 3010B.
Fred
flarssen is online now Find More Posts by flarssen
Old Nov 06, 2011, 10:53 AM
chewytm is offline
Joined Jul 2006
Fred
I am sure they will come out with more esses(?). So far I only use up to 2x3S in series which will be charges are 3s2p, so I am ok there.
chewy
Old Nov 06, 2011, 01:34 PM
jawelsh is offline
Find More Posts by jawelsh
jawelsh's Avatar
San Antonio, TX
Joined Apr 2006
306B Smoked!
Well, I just smoked my 306B charger today. It had been working awesome up to this point. I was parallel charging 2 6S 5000mah packs at 20 amps and all of a sudden smoke started pouring out of the cooling fan housing.
I purchased it from EP Buddy about a month ago. What is the warranty service like? Will they replace this with out hassle or do I just throw it in the trash and buy something different? This is my only charger and I'm down until I get it replaced. Never should have sold my hyperion.
JAW
jawelsh is offline Find More Posts by jawelsh
Old Nov 06, 2011, 01:35 PM
LeszekJ is offline
Find More Posts by LeszekJ
LeszekJ's Avatar
Poland
Joined Nov 2010
I have just ordered 6S.
LeszekJ is offline Find More Posts by LeszekJ
Old Nov 06, 2011, 01:37 PM
Joined Nov 2011
When you turn the power supply on, the voltage on the output rises slowly (in terms of milli seconds or nano seconds), thats the big difference.
regards
blue bandana
P.S.: looks like I'll buy a iCharger ... due to a lack of alternatives.
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
