San Diego
Joined Dec 2003
Do you have the manual for your charger? If not you can download them from progressive RC, just click on your charger and there is a manual button down the page a bit. http://www.progressiverc.com/charger...-chargers.html
Mine shows CONNECTION BREAKDOWN This will be displayed when an interruption of the connection between battery and the charger output has been detected during charging or discharging. CAPACITY OVER SHUTDOWN The capacity (mAh) charged or discharged reached the configured protection limit. |
Auckland
Joined Mar 2010
Charger not terminating at 4.2 on 4s
Thanks again BGR, Charles and Fred. I have tried all the options, and NO, there is no warning, and YES, this problem is consistently reproduced. I do note Charles, as you said earlier, that someone else did report the same issue with the 208b, with Junsi stating that they would post a reply. However trawling through a lot of the thread since, they have Not replied with an answer. Unfortunately I will have to take my chances with HK. Are Progressive RC good for Overseas customers as well?
Sorry for the delay reply. You can try to test this problem via using the battery with more cells, such as 6S or 8S, when connecting the batteries, press STOP button for three seconds to monitor the voltage of each cell to see if there is any difference between the displayed voltage and measured voltage. And show us the data for the difference of which cells, so we can offer you the further method. Thanks for your cooperation. Junsi |
Son, Norway
Joined Sep 2004
Have you tried the LiIon and Life modes? LiFe mode should definitely give a warning when a charged LiPo is connected. Fred |
Joined Oct 2011
When i discharge a Pb battery with 20Ah or more it will take a long time. I can not check every hour the discharging is done. The charger must only start at this point the charging mode. Where is the problem? The time in the discharged state is more critical for the Pb battery as an deep cycle. Best regards, maex |
Auckland
Joined Mar 2010
Thank you for getting back to me. I will try the 3sec stop button idea. So far I have just used the 'inc' button during the charge. I have removed the battery to check each cell with an independent meter, which always shows exactly the same voltage as the 208b, whether during charge or after -- which at present is 4.26 on each single cell. This is after some time, so there is no 'sag'. Unfortunately I have no bigger batteries, other than 4s. I live in a small place and do not know anyone with bigger than 4s.
So far I have used a stable PSU delivering about 11.95V. Just another point -- my computer (64bit windows 7), does not recognise the charger at all. It does not even see it via the USB connection. ??? is this related or another matter. I will get back to you soon when trying the stop button trick. It is night time here and the family do not like the 'beeps'! |
Once again no explanation at all how 3S can be perfect at 4.2 and going to 4S all cells go to 4.26.
Suggesting the owner try charger with more cells does not really help understand what is happening. Does the charger use some kind of voltage divider network which is only accurate with a certain number of cells. |
Melbourne, Australia
Joined May 2006
To get the full rated output power from a 208B you need a 24V/17A, 400W power supply. So to power two you need a total of 24V/34A, 800W.
There are not many PS that meet that specification and very few that come as standard with dual outputs. Someone might know of one. There are good selections of PS (and accessory cables) at epbuddy and progressiverc You could get a Meanwell 24V/1000W supply and then use multiple sets of ring terminal output cables, one set for each charger. Or for a similar investment you could get two smaller PS, one for each charger. If you can live with a small reduction in output power then you can use one of the inexpensive 15V supplies for each charger. I run mine from a Junsi P350 (15V/23A, 350W) and can get up to about 310W charger output power. |
Joined May 2006
Ah, here is one (30V/80A, 2000W @ $550) with QUAD outputs, not cheap though!
http://www.amainhobbies.com/product_...-30V-80A-2000W ![]() Or this one (30V/40A, 1000W @ $300) but the secondary outputs are only rated for 17A each: http://www.amainhobbies.com/product_...-30V-40A-1000W
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
