Please press STOP for 3 seconds to monitor the voltage of each cell to see if there is any difference between the displayed voltage and measured voltage? If different, please check if the battery balance port, the wire from balance board to the charger, and the balance board are damaged or some lines are disconnected. Easily, you can use DMM to ensure each cell voltage coming to the charger. If the balance board or balance wire has been burnt, please change one. (Please also check another file “bal err” on the first post.) Junsi |
![]() That's a relief. At least I can still charge them one at a time. |
Charge 5 3 cell Lipos at one time for $57.20
I'm not an expert on batteries yet and one of the hardest things for a new RC pilot is to figure out a way to charge 5 batteries quickly so he can spend a few minutes flying and not most of the day waiting on batteries to charge. My original idea was to buy 5 cheap Turnigy lipo chargers at 11.44 a pop, not bad for 2 and 3 cell Lipos. http://www.hobbyking.com/hobbyking/s...idProduct=8247
I have 1 and it works great for the money, its nothing fancy, has no digital read outs of any kind and only does 2 and 3 cell Lipos and has auto shutoff. You can get it in AC or DC. It is slow though and takes an hour and a half to charge my Blade SR 1000mah Lipo's. With 5 batteries I'd get about 40 minutes of flying time for every hour and a half of charging for 57.20 plus shipping and tax. This is the ultimate but way more expensive and what I want to eventually do as I move into larger Helis requiring 6 cell batteries. This is awesome. Be sure and check out the You Tube Video half way down the page. http://www.progressiverc.com/paralle...t-xh-xt60.html |
Melbourne, Australia
Joined May 2006
Julez, Quite a few chargers have been working that way for years now, perhaps it is why some are quicker than others for the same packs.
Hyperion, FMA and Maxpro all use a pause during charging to monitor the resting cell voltage. I know that the Hyperion 610 used to pause every 60s and the Maxpro X6 every 5s. The Bantam B6 used to do it every 30s but only in the CV-phase. I cannot say for sure how high they allow the voltage to go while current is flowing, but they certainly cut off the charge current to do a cell check. |
![]() As long as the resting voltage is kept within limits, Lipos do not seem to mind if the voltage during the charge process is a tad higher. Quote:
Here is a paper about this. It gets interesting after page 5: http://www.st.com/stonline/books/pdf/docs/4391.pdf |
Joined May 2006
That paper is quite old (1998) as are others I found about pulse charging LiXx cells, so I would be careful about applying their conclusions to the current generation of cells used for RC, which clearly have very different characteristics. Using conventionaly CCCV charging contemporary LiPo cells charge from 80% discharged in 50 to 70 minutes, not the 2.5 hours mentioned in that paper. To me that says something about the changes (advances) in chemistry and anode composition.
So I agree that there may be something gained by adopting a periodic pause to check the resting cell voltages, I would be against changing to any significantly more aggressive like the reflex-style method mentioned in some references. |
Joined Sep 2009
I'm sorry, but we don't accept any documents unless they have been funded by non-profit organizations and have appeared in at least 3 peer-reviewed journals.
![]() I doubt their claims that conventional LiXX charging reaches the CV phase after 30 minutes at 1C and needs 2.5 hours for a full charge, but I guess if you had a lot of resistance between you and the battery it could happen with dumber chargers. Still, I've never had a phone or laptop that took 2.5 hours for a full charge. Back when the FMA CellPro 4S was new I recall claims that you could use very long charge leads with no ill effects, something like 16 feet. The reason why is that the charger would pause from time to time and use the -dV to compensate for line losses. With products like the FMA PL8 you can actually use Kelvin connections to allow for line loss compensation without having to pause the charging process, but I know it still pauses from time to time to evaluate the battery being charged and the power source. To bring this back to the iChargers, I have no idea what they do, but I suspect "nothing" as we already know they have issues reading cell voltages because they don't compensate for the voltage drop of the wires. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
