Joined Jul 2008
Looking at the pics at http://www.jun-si.com/EnProductShow.asp?ID=87
both the 106B and 1010B have mini-USB ports. I assume these are for updating the firmware. Maybe Junsi can confirm this? Are these available from Hobbycity now? |
Has anyone managed to use the HXT speed controller converter? This would be the simplest as you can get one from HC for about $10. MadMax |
Melbourne, Australia
Joined May 2006
OK so the Silicon Labs CP2102 is a single-chip USB-to-UART Bridge so that provides the transformation between USB and legacy serial interfaces. I cannot identify the other chip from the numbers but my guess is that it is a level translator or bus tranceiver that buffers the signals bewteen the Bridge and the RS232 port. So you should plug it into a USB port and measure the voltage between each of the red and white wires and the black GND wire. If you get +5V then you should be safe to try using this to interface to the charger. You will need the Virtual Com Port driver which appears to be available here: http://www.silabs.com/tgwWebApp/publ...en/mcu_vcp.htm
Sunshine Coast, Australia
Joined Sep 2004
Hi ML_Crisis,
another point of difference between the Cellpro and the iCharger is that the Cellpro MUST be connected to a balance connector to charge, whereas the iCharger only needs the main power connection. In practice, this means the the Cellpro can't charge small LiPo packs used in indoor planes which don't usually have balance connectors. The Cellpro also cannot charge your A123 packs unless you take the trouble to fit them with a balance connector, which the cells don't need (i.e. they don't need balance charging, they're power tool cells and very robust). As has already been noted, the Cellpro can't do Nicad or Nimh either. This leaves the iCharger as a 1 charger solution for just about everybody, whereas the Cellpro cannot fulfil the charging needs of so wide an audience. They each have some good features though; the Cellpro is really good at charging at 2C and 3C rates, and the iCharger can balance charge 3 3S or 3 2S packs at once. |
Joined May 2006
It is a very good unit with a clever (and possibly unique) charge controller chip that makes it faster than most other chargers doing the same lipo at the same nominal charge current:Code:
Charge up the same KP 3S 2200mAh from Storage level -------------- ---- ----- Charger mAh Time -------------- ---- ----- Bantam BC6 820 32.46 iCharger 106B 908 36:46 Maxpro X6 860 31:30 -------------- ---- ----- The only negative is that it won't charge a Tx battery in situ in some Tx due to their internal protection diode. JunSi fixed that issue for the iChargers back in v2.8/2.9 ![]() The iC106B has more flexibility, more features (which you may never need or use), more power, heavier-duty leads and is quite a bit smaller. However as noted, the Maxpro comes PC-ready and currently the iC chargers do not. |
LiFePO4 (A123) battery packs do need balancing leads. If you run them hard and do not balance them they will get out of balance ,you will have one or more cell(s) with lower charge/volts / capacity and they will dump early on you. I speak from experience, not only mine but that of others also. I have had some A123 packs to stay in near perfect balance but I can say the same for LiPolys. Thing is without balancing you do not know which ones stay inbalance and which ones do not. I should also note that many of the other LiFe cells vary in quality and balance a lot more than the true A123 cells do. Closing thoughts The cordless power tools have a battery management module built into them , the only charger that A123 Racing sells for use with their batteries is a balancing charger. Charles |
Joined Oct 2007
Junsi,
Please could you give me a reply to my earlier questions: First, I have now tried a number of small LiPo belonging to club mates, all at or below 1000mAh. It is clear that the cut-off mechanism is not working. At the same level of discharge (80% or less), they take between 90-120mins (safety timer cut-off activated) on the 1010B (bal. charge normal), whereas on my LiproPlus 5 they take under 1 hour. There isn't a lot of difference on bal. charge fast. On both settings, the charger settles at about 0.23-0.24A, charging and discharging at the same rate. All 3s 2200 LiPo's I have tried take longer on my 1010B than on my other charger, sometimes considerably longer. So, is this a faulty unit? or will upgrading to v. 3.05 solve this? My version is 3.04. Other users do not seem to be reporting the same situation as I am seeing, so I would be grateful for your thoughts. Thanks. |
I believe it was Julez who mentioned earlier about loose screws. Well see post (Thread) here.
http://www.rcgroups.com/forums/showthread.php?t=890256 It seems to me there are some real QC issues with these chargers. Perhaps they should charge 50% more and spend the additional funds on QC. An inexpensive charger that fails to work for very long is no bargain IMO. Charles |
Gales Ferry, CT
Joined Jun 2008
What software update is shipping from Hobby City? 3.05? Will the FACTORY be supplying a USB adapter to update the units that don't work properly or will the units that don't work properly be updated for free under warranty? kgfly, What software version is being sold by your contact in Austrailia? |
Joined May 2006
Joined May 2006
You would have to confirm that with them directly before ordering. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
