Old Jul 05, 2008, 09:02 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
I guess what you could do is more like the way some digital clocks work. That is, the longer the increment/decrement button is held down, the larger the step size. So for example, after 10 steps at 100mA, change to 500mA. Once the button is released the increment goes back to 100mA so any overshoot is quick and easy for the user to correct
I like this idea even better than mine.
But to be honest, I dont think a 2200mAh Lipo will mind if charged at a 2,5A rate
Also, does a lipo connected to the output of your charger power it up?
No, it does not.
Well, I will write an email now to HobbyCity, and ask how an exchenge will work.
Cheers,
Julian
Julez is offline Find More Posts by Julez
Old Jul 05, 2008, 09:35 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Keg - Hmm, well thank you for trying but they are too out of focus to tell what chipsets are being used. I look forward to hearing the results of your experiment
kgfly is offline Find More Posts by kgfly
Old Jul 05, 2008, 10:42 AM
rizky_p is offline
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
Is it okay to use a 12v Rail from 400w PC power supply to power up 106B charger?
Thanks.
rizky_p is offline Find More Posts by rizky_p
Old Jul 05, 2008, 06:30 PM
kgfly is offline
Joined May 2006
Yes but you will need at least a 5W load on the 5V rail to get it to regulate. Also a 400W PC power supply will not deliver 400W on the 12V rail. Check the rating, you need at least 18A on the 12V rail if you want to run the 106B at 180W output.
See here for more info: How to: Convert a Computer ATX Power Supply to a Lab Power Supply: http://www.wikihow.com/Convert-a-Com...b-Power-Supply
Old Jul 05, 2008, 07:50 PM
ML_Crisis is offline
Find More Posts by ML_Crisis
West Linn, Oregon
Joined Mar 2006
iCharger 1010 vs competing chargers
Hello all,
I am somewhat puzzled with regard to to overwhelming response/following to the iCharger 1010. I do not have vested interest with any charger manufacturer so hopefully I present a unbiased perspective of value & feature set of chargers. Furthermore, I have ordered a iCharger106B, reason - seems to be an excellent value at < $100 and am impressed with Junsi's response to user feedback/input.
Examining specs, the iCharger 1010, ~200 Watt, priced at ~ $180 USD + S/H through United Hobbies does not hold a candle to the FMA Direct 10S, ~300 Watt, priced at $190 USD + S/H unless NiCd/NiMh/Pb charging and "brushed Motor Breakin" / Foam cutting is worth more to you than ~100 Watts of charge power and USB Firmware Upgrade/ PC data logging (for which you all are willing to spend additional sums and personal effort to just obtain Firmware Upgrade capability with the iCharger 1010 (no PC data logging/control)).
What am I not appreciating here, the iCharger 106B is a good value at < $100, the iCharger 1010 for 10 cell/200W vs 6 cell/180W and $180 is again puzzling.
ML_Crisis is offline Find More Posts by ML_Crisis
Old Jul 05, 2008, 08:36 PM
kgfly is offline
Joined May 2006
A little more research will reveal that the FMA Cellpro10S is rated by the Mfr as 300W INPUT and they give no specification for the output power. User testing has shown it is only 180W output.
Cellpro10S benefits over the 1010B:
* PC interface for upgrade, config and logging
* per-cell Ri measurement
* US distributor and support
Cellpro10S benefits over the 1010B+:
* None based on their features and specifications
iC1010B+ benefits over the CP10S:
* Multichemistry
* Genuine 200W output even down to 11V input
* 300W output with 14V input
* Discharge and cycle features (30W/7A internal, up to 270W/7A with an external load)
* PC interface cable included in base price
* A little more compact
You might find this comparison interesting
TP1010C vs CP10S vs iC106B+ vs iC101B+ vs Hyp0610iDUO
kgfly, 29 Oct 2008
FMA Cellpro 10S (~$190)
- Requires DC power (up to 300W, full output power requires 15V input)
- LiXx only
- 2s-10s integrated balance charger with two series connected 5S ports
- 180W/10A output (Mfr claims up to 260W but this has not been achieved by users)
- Balance current 1000mA (best of breed)
- Per-cell Ri measurement
- Manual, 1C, 2C and 3C LiXx cycles
- No discharge features
- 6 memories
- no temperature probe
- PC interface (configuration and logging, required for advanced configuration) (cable is optional extra)
- some balance plug adapters available
iCharger 106B (~$100) Replaced by 106B+, see below
- Requires DC power (>250W, full output power requires 14V input)
- Full multichemsitry LiXx/NiXx/Pb
- 2s-6s integrated balance charger (with on board 2s-6s JST-XH balance sockets)
- 210W/10A output (180W at 11V input, full power at 14V input)
- Balance current 300mA
- No per-cell Ri measurement
- Normal, Fast, Slow, Balance and Storage LiXx cycles
- Discharge features (20W)
- 10 memories
- optional temperature probe
- hidden PC interface (easy mod to add it)
iCharger 106B+ (~$130)
- Requires DC power (>300W, full output power requires 14V input)
- 250W/10A output (180W at 11V input, full power at 14V input)
- Discharge features (20W/7A internal, 170W/7A with external load)
- 10 memories
- USB PC interface (upgrade and data logging)
iCharger 1010B (~$180) Replaced by 1010B+, see below
- 250W/10A output (200W at 11V input, full power at 14V input)
- Discharge features (30W/7A)
- 10 memories
iCharger 1010B+ (>$180)
- Requires DC power (>350W, full output power requires 14V input)
- 300W/10A output (200W at 11V input, full power at 14V input)
- Discharge features (30W/7A internal, 280W/7A with external load)
- 10 memories
Hyperion 0610i DUO (~$270)
- Requires DC power (>400W, full output power requires 15V input)
- Dual independent ports each 2s-6s integrated balance charger
- 180W/10A output per port (full output power requires 15V input)
- Per-pack Ri measurement
- Balance, SynchBalance (balance across the ports) and TCS (can be used for Storage) LiXx cycles
- LiXx dischage at max. of 300 mA and also Auto Storage mode will dischage or charge as needed (added in v1.5)
- 10 memories per port
- optional temperature probe per port
- PC interface for logging and firmware upgrades (cable is optional extra)
- JST-XH, TP/FP and Hyp/PQ balance plug adapters available
- DUO-II adds better LCD and 50W discharge per port
ThunderPower 1010 + 210V balancer (~$280)
- Requires DC power (>270W, full output power available at 12V input)
- 2s-10s separate balancer (210V) with datalink back to the charger
- 220W/10A output
- Balance current ?300mA?
- No Ri measurements
- Normal and ?other? cycles
- Discharge 28W
- ?temperature probe?
- PC interface for firmware upgrades (cable is optional extra)
The DUO is an excellent candidate for those that want a dual-port charger with fully independent ports (chemisty, cell-count/voltage, capacity, current and start/stop can all be different on the two ports) and don't need support for more than 6S on any single pack. The very low 300mA discharge capability or lack of NiXx cycle/discharge features are issues for some users. This is addresses in the DUO-II which adds a much better LCD and 50W/port discharge.
The CP10S is an excellent LiXx-only candidate for those that want single-pack capability above 6S and a full PC interface.
The iC1010B+ is perhaps the best value for a full multichemistry solution with single-pack capability above 6S in a remarkably compact and conveniently portable size.
Choosing amongst the CP10S ($190), iC1010B+ (>$180), a pair of iC106B+ (~$240)and the DUO ($270) is indeed a bit of a challenge. At the moment the criteria might include:
* Need NiXx or Pb => not CP10S
* Need single packs over 6S => not DUO or iC106B+
* Need PC interface off the shelf today => not TP1010C if you want logging
* Need independent two port operation => DUO or 2 x iC106B+
* Need operation fom 24V DC => DUO
* Need max output power from a 12V Pb source => iC1010B+ or TP1010C
* Need US local Mfr/support => CP10S or TP1010C
* Need per-cell Ri measurement => not the TP1010C
Last edited by kgfly; Oct 28, 2008 at 08:08 PM. Reason: Updated for ic106B+ and 1010B+
Old Jul 05, 2008, 10:06 PM
luky is offline
Find More Posts by luky
Plastics Weenie
luky's Avatar
San Diego
Joined Jul 2007
Don't know if this has been posted yet, but I recently saw that you can buy the 1010B from B-P-P.com now... So you don't have to worry about ordering it from China.
luky is offline Find More Posts by luky
Old Jul 05, 2008, 10:18 PM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
Are you certain that they sell the icharger 1010B? The only 1010B I see is the Chargery Power 1010B. There are differences between these two chargers.
Phoenex is offline Find More Posts by Phoenex
Old Jul 06, 2008, 12:30 AM
Phoenex is offline
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
Charger comparisons
I bought two 106B's for this very reason. Two of the 106B's equals 360watts total for $160. I spent another $25 or so and some time installing a firmware upgrade ability so that brings the total up to $185. I have still spent much less than the Hyperion option $270 which I might add has less features that I want. Since I already have the upgrade device, I went ahead and ordered another for my 4 cells I am looking at the future with the ability of these new cells to charge at 2C rate, A123's and the ability to upgrade to charge new types of batteries. These new chargers are quite a leap forward from the old Celectra's, HXT, MKII I currently have for charging.
Old Jul 06, 2008, 08:38 AM
NCguy is offline
Find More Posts by NCguy
Greensboro/H.Pt/Win-Salem P.T. Intl, North Carolina, United States
Joined Dec 2003
Excellent Kgfly! Again the only significant feature I didnt see mentioned was the ability to see internal resistance which is great on the Cellpro and present on the Duo.
NCguy is offline Find More Posts by NCguy
Old Jul 06, 2008, 08:44 AM
kgfly is offline
Joined May 2006
Thanks. Good point NCguy, I have updated the post above including the summary for future reference.
Old Jul 06, 2008, 09:48 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
(DUO corrections)
- Per-cell Ri measurement ( per battery not per cell)
- No discharge features (plan to add very slow discharge via the balancer in the future) ( Li dischage at max. of 300 mA and also Auto Storage mode will dischage or charge as needed V 1.5)
I am most likely one of the very few who really cares but TCS can be used with LiPoly to limit the max. charged to percentage / voltage. A few of us are fully aware that 4.15 volts per cell is much kinder on the cells tnan packing them 100% full to 4.2 volts per cell. FYI Thunder Power 1010C was the first LiPoly charger that I am aware of to offer a less than 100% charge to option for LiPolys.
Charles
Old Jul 06, 2008, 09:57 AM
kgfly is offline
Joined May 2006
Thank you Charles, I have corrected the comments/summary above for future reference. Hope I got it right this time !
Old Jul 06, 2008, 10:00 AM
kgfly is offline
Joined May 2006
The 106B and 1010B offer two ways to limit the charge voltage. The direct way is to simply edit the cutoff voltage for the LiXx chemistry of your choice. The indirect way that I have been using for some time is to use the Fast Charge or Fast Balance modes. These modes have a higher termination current. This effectively ends the CV phase earlier than the Normal (or Slow) modes. My packs get charged to 4.17V this way which gives me benefits along the same lines as 4.15V cutoff.
Old Jul 06, 2008, 10:34 AM
NCguy is offline
Joined Dec 2003
I get a headache thinking about the amount of time and posts that went into putting together this chart. Many, many thanks to you, Charles, and others that made all this possible! There is no way one could make as educated a decision without reading this comparison.
You may want to consider starting a comparison thread with your chart as the first post. It could easily deserve its own thread. That is if people haven't already O.D.'d on this stuff already.
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
