Joined Jan 2011
When I check voltage, I press the 'inc' button to see the voltage read at the balance board then short press on the 'start' to go back. I don't use an external meter. Manual states to use 'dec' button to return to general info screen, but in my case this cycles through additional settings and info like capacity limit, temperature, etc... |
Joined Feb 2008
Joined Jan 2011
I have a solution for "connection breakdown" 106b+
I replaced a component Q26, which is near the DC input port, the model of the Q26 is BC807 and D 16 a zener 20 volt with anotherone no smd, this is upside down the input port, I used a magnifying glass. bye from italy |
Hi,
Today after a charge of 10s lipo packs in series I forgot to hit the stop button and I disconnected one of the main cables from the packs, don’t know if that was the cause, what I know is that I can’t charge anymore. The problem is after connecting balance conectors I connect the main positive first and it says “vout low”. Tried the lipo charge only mode and I choose 10s and the charger identifys only 9S. I tried a downgrade on the firmware but the problem is the same. Any help would be appreciated, Thanks |
Joined Jan 2011
I`m having the same problem here. One of my ichargers (1010B+) have this display problem. I've seen your post advising to unsolder C22 and C24 SMD componentes. I did it, but it didn't solve my problem. Could you help me? Thanks in advance, Mario. |
Sorry to cause you trouble. Our engineer will test and study this problem as you mentioned, then offer you a solution later. Junsi |
We have received your E-mail, and have replied it, please check it. Junsi |
We are sorry to hear that the above method is not available for your charger this time. Please check the PM we sent, thanks for your cooperation. Junsi |
Greetings not to change the subject but for those in the know could you look at this thread and offer some help
thanks William http://www.rcgroups.com/forums/showt...7#post17107736 |
What does it say if you connect both main leads? Quote:
If 10S pack is partially discharged it's detected as 9S or less (charge mode). |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
