Melbourne, Australia
Joined May 2006
Note that the losses in the charger when charging are not huge as it is around 90% efficient. Still, going to a 24V supply would be a good idea if you think you might need to go to higher power setups in the future.
The 206B works exactly like the 306B in the sense that it delivers half its rated output at half the input voltage required for its full rated output. That is, it requires 17V to deliver 350W and from 8.5V will deliver 175W output. The components in the 206B are not rated for higher power throughput. If you want more power you have to upgrade to a 306B
We are really sorry to cause you confusion. Generally, we choose PM to answer the question for it's related with the private information about our customers, we need their contact way to offer some specific information for them, or we need communicate with distributors for them, which we think is not necessary to talk publically. On the other hand, sometimes it's really related with some secrets about our products. Besides, all information will be public if it's useful for our all customer. Your understanding and cooperation will be appreciated. Sincerely Junsi |
Sorry to cause you trouble. Please check if you have installed USB driver and iCharger upgrader. If done, please press STOP and electrify the charger, and then connect PC with our original USB cable not your other USB cable to upgrade again. Regards, Junsi |
Joined Dec 2010
I have send a PM to you... Thanks Junsi Best regards |
Gurgaon - India
Joined Jul 2009
Junsi, even for very small small things you send PM and do not provide the solution in the forum then what is the use of this forum ? My issue of error with 2S Lipo is still not resolved and I am not ready to send it to you because that is expensive affair. I tried to order one iCharger 3010B from your site and mentioned comments to charge me with a sample price, I am waiting to hear on that. |
Son, Norway
Joined Sep 2004
Fred |
Joined Sep 2010
anyway I think it would be helpful because I think that not anyone who has the same problem as a poster here will send you a PM. They just se a message, see "private answer" ... and leave. Volker |
Joined Jan 2011
parallel charging with included balance board
Can anyone help? I have a new 208B, and am trying to use balance board to parallel charge 2 2200 3 cell lipos. When plugging 2nd batt in to middle slot it sparks and wires get hot. Why is this happening?
john |
You are connecting the balance connectors in series when moving laterally across the board, not parallel. And you are likely in parallel with the main leads.
Look at this picture. It shows how you hook up packs in parallel using the standard board. http://www.rcgroups.com/forums/attac...mentid=2969084 You may have burnt up some traces on the board. You aren't the first to do this, and probably not the last. |
El Cajon, CA, USA
Joined Feb 2001
Isn't this what we should be using for parallel balancing? or somthing like it? (you have to pick the correct number of cells of course....this one is a 4s version)
http://epbuddy.com/index.php?main_pa...p_image&pID=56 8 bucks or something like that. Can't beat it. |
The adapter boards with multiple connectors that I have are all for series charging multiple packs. Peel the foam tape off the back of the board, and solder some small wire in place of any burned up traces. Best to check pin-to-pin continuity with an ohm meter too. Progressive RC also has a selection of cables/adapters for parallel charging. Somewhere Julez has a good write up on parrallel vs. series charging (find with a search).
Instead of a snakes nest, why not use this to keep things all neat and tidy, 2S-6S.
http://epbuddy.com/index.php?main_page=index&cPath=15 Several harnesses, or the Paraboard, they both work, I've got 'em, but the Paraboard is my go to product for parallel charging. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
