Old Jun 29, 2008, 09:37 AM
alex.guzun is offline
Find More Posts by alex.guzun
iCharger 106B user
Lab, Slovak Republic
Joined Jun 2008
i have 106B charger and what to charge my 6cell nimh battery (from my xray m18mt) using 12mA current (ok i used 10mA) for 14h.
So i set 10ma in MAN charging mode... after 9 min and some seconds charger stopped charging and on the display i say blinking NIMH/OVER
so i started to charge it again and now for 20min running i'm having 8.45V, is it ok? why charger stopped even it has been in manual mode (safety timer is switched off)
alex.guzun is offline Find More Posts by alex.guzun
Old Jun 29, 2008, 10:19 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
It is hard for a delta-peak detect charger to charge very low capacity NiXx packs, it tends to false trigger. You could try:
* Turn NiMH Trickle ON
* Increase NiMH Check Delay time
* Turn the Safety Timer OFF
kgfly is offline Find More Posts by kgfly
Old Jun 29, 2008, 10:29 AM
iCharger 106B user
Joined Jun 2008
thank you
as for Trickle ON, 10mA is enought? (don't really know what Trickle is)
Old Jun 29, 2008, 12:02 PM
kyalamikid is offline
Find More Posts by kyalamikid
kyalamikid's Avatar
Kyalami, South Africa
Joined Jun 2006
I have taken a short (bad quality) video clip showing how balancing starts immediately. You can see the balancing start in the first few seconds on a pack that is discharger to 3.3V.
Junsi, any chance of having the balancing kick in towars the end of charge as previously suggested?
http://www.rcgroups.com/forums/showa...mentid=1940241
kyalamikid is offline Find More Posts by kyalamikid
Old Jun 29, 2008, 03:03 PM
iCharger 106B user
Joined Jun 2008
got it, trickle... set it to 120mA (my battery is 1200mah)
After some charging (maybe hour) time display started blinking with OVER TRK / NIMH CHG 0.12A
what does it mean?
Old Jun 29, 2008, 06:01 PM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
Charger number two updated..
Updated charger 106B number 2. I really do need help with proper soldering techniques and equipment. Again it took awhile but hopefully it will be worth it. I did notice the case can get quite hot during the discharge process. I still need to get the cases up on some standoffs. I don't think I am going to push discharging too hard on these chargers.
Phoenex is offline Find More Posts by Phoenex
Old Jun 29, 2008, 06:24 PM
ukpaul is offline
Find More Posts by ukpaul
ukpaul's Avatar
Joined Aug 2006
You're not wrong there, 154F on mine using a temp gun, too hot to touch for more than a couple of seconds. That was with the unit not flat to, but resting on it's edge. Might be even higher if it's flat on it's back. The design is not great when discharging for getting rid of the heat.
ukpaul is offline Find More Posts by ukpaul
Old Jun 29, 2008, 08:49 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by kgfly
JunSi a local user has had a similar display problem with his 1010B as we have seen with the 106B.He is running v2.9 of the firmware.
Is there a fix for the 1010B equivalent to the "remove C47" fix for the 106B or do you have some other recommendation ?
Hello Kgfly,
Thanks for telling us this!
Please tell him to remove “C52”, which lies in the left downwards of the PCB. The other way is to upgrade his version 2.9 to version 3.05 according to the upgrading instructions.
Junsi
junsi is offline Find More Posts by junsi
Old Jun 29, 2008, 10:43 PM
kgfly is offline
Joined May 2006
Thank you for the fast response Junsi. Does upgrading to 3.05 also fix the problem on the 106B or is removing C47 still required on that unit even with 3.05 installed ?
Old Jun 29, 2008, 10:52 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hello Kgfly,
You'd better remove the C47 for 106B even you have upgraded your charger to version 3.05.(I made a mistake before! )
Regards,
Junsi
Old Jun 29, 2008, 11:28 PM
kgfly is offline
Joined May 2006
OK, thank you. So does that mean that new stock of 106B ship without C47 ?
Old Jun 30, 2008, 12:43 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Yes, there is no C47 fo rthe new stock of version 3.05!
Regards,
Junsi
Old Jun 30, 2008, 12:52 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by ricardo_bh
jun 29,2008 stock in HC
stock in HC is 5 chargers now.(jun 29,2008)
Junsi,
What is the current software version for 1010B in HC stock ?3.05?
I want to 3.05 version.
Rick
Hello,
I have sent you a PM, please check!
Regards,
Junsi
Old Jun 30, 2008, 02:20 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
You can do 2 things:
- Charge with at least 0.5C. Lower charge currents will not trigger the delta peak termination reliably, therefore the erratic behaviour you experience.
- Charge using the NIxx mode. This mode is optimized for longer charges for forming the battery pack.
Do not set the tickle current higher than 0.1C.
Junsi, is the feature of automatically adjusting the tickle current according to the charged capacity already implemented?
I have seen the video, and have to agree. Balancing at a voltage level of 3.5V certainly too early.
Julez is offline Find More Posts by Julez
Old Jun 30, 2008, 02:43 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hello Julez,
Sorry to say that this feature hasn’t implemented yet . Currently, the user has to set the trickle current by themselves.
Regards,
Junsi
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
