Old Jun 22, 2008, 08:50 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by skyboyken
Hi Junsi,
I notice you are saying nice things about recent software change suggestions, but making no commitments to implement, nor giving any timeframes.
So let me ask you please, do you have any intention of implementing Julez' and my suggestion to do a foam cutting bow driver mode, and if so when?
Ken.
Hello Ken,
Thanks for you remindness!
now, we have implement this foam cutting driver mode to Version 3.05, we will release its update later!
Junsi
junsi is offline Find More Posts by junsi
Old Jun 22, 2008, 08:54 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by Julez
Well, I just had a closer look at the manual, and I noticed that the motor break-in feature is almost the same as the foam cutting feature.
Not as convenient, but the following should work:
Just connect a cutting wire instead of the motor, set the amp to 4A, and slowly work your way up at the voltage setting, until you have the desired wire temperature.
The max. voltage of 15V would limit the wire length to 0.6m, though, at least with the type of wire I use.
Junsi, concerning the manual:
At the program flow chart, how about putting little numbers under each display image, which refer to the page number of the manual, where this feature is described in detail?
For example, put a "18" under the PB charge display images, so one would see directly, that one has to go to page 18 in the manual to find the explanations.
Cheers,
Julez
Hello Julez,
Thanks!
As for the putting little numbers under each display image , We just misundestood your meaning , we will add the page number to the under images of flow chart.Thanks!
We really appreciate this valuable idea, it's really a convenient way.
Junsi
Old Jun 22, 2008, 09:07 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Junsi I think you might have misunderstood Julez's suggestion. I think he just meant that in the manual you could place a little page number reference below each drawing of the LCD in the flowchart.
kgfly is offline Find More Posts by kgfly
Old Jun 22, 2008, 09:27 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hello Kgfly,
A thousand thanks!
Language barrier!
Thanks for your explanation!
Regards,
Junsi
Old Jun 23, 2008, 02:39 AM
KegRaider is offline
Find More Posts by KegRaider
Townsville
Joined Jul 2007
Hi guys,
I got to page 22 and realized that I NEED this charger Ordered from HC, and eagerly await it's arrival! Should replace my DN Power and iMax B6 just nicely
Any idea on what firmware is on the ones stocked at HC? Not that it matters, as i bought a TTL board from futurelec anyway
-->KegRaider.
KegRaider is offline Find More Posts by KegRaider
Old Jun 23, 2008, 04:33 AM
skyboyken is offline
Find More Posts by skyboyken
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
Thanks Junsi,
i was hoping you would say that .
Ken.
skyboyken is offline Find More Posts by skyboyken
Old Jun 23, 2008, 09:18 AM
blanchjd is offline
Find More Posts by blanchjd
Snohomish, WA
Joined Jun 2007
Foam Cutting mode in upcoming 3.05? Wow this thing just keeps getting better and better. Now I really need to finish my RS232 to TTL converter.
-Jeff
blanchjd is offline Find More Posts by blanchjd
Old Jun 24, 2008, 05:03 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
News!!!
Hello Everybody,
After assimilating your guys’ valuable suggestions, now the new version 3.05 come into being.
As usual, there are some new functions added and modifications. Please see detail information in attachment: update information
And updated user manual: http://www.jun-si.com/UploadFiles/iCharger-english.pdf.
Regards,
Junsi
Old Jun 24, 2008, 05:29 AM
ivanhoes is offline
Find More Posts by ivanhoes
Marburg/Germany
Joined Jul 2007
Junsi,
just a short question. Will HC get the 106B back in stock this week?
ivanhoes is offline Find More Posts by ivanhoes
Old Jun 24, 2008, 10:39 AM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Rock on Junsi - nice list of updates in the release notes and I love how credit is given to the originator. This soon to be legendary series of chargers is destined to become the model that others mimic and aspire to be, given this level of direct and immediate user feedback.
Manufacturer/engineer direct to consumer/hobbyist - isn't it wonderful!
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Jun 24, 2008, 10:43 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Junsi,
The foam cut mode looks absolutely beautiful in the manual!
Thanks for incorporating it, a huge benefit for the DIY foam enthusiast!
Julez is offline Find More Posts by Julez
Old Jun 24, 2008, 10:48 AM
Joined Dec 2006
I can almost smell the foam burning - mmmmm-mmmmm! The first charger with integrated foam cut mode, I believe you can take some credit for that one too Julian.
Site Sponsor
Old Jun 24, 2008, 11:25 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hm, thanks
*Cough* - I prefer wearing a gas mask while cutting
Anyhow, I wonder why noone has thought earlier of this. A computer charger can do everything a normal foam cutting power supply can do, too, only better.
Old Jun 24, 2008, 11:33 AM
not.likely is offline
Find More Posts by not.likely
England
Joined Apr 2008
Updating port ?
I already have the 1010b but what is the little USB port for on the side? Is it possible or necessary to update the charger with latest software or what? I am a little confused, as there are a lot of things which seem to have been incorporated into it since its first release, and these seem to keep occuring almost daily - but how will I know whether these are active in my particular model. It says ver3.04. when first booting up, and the manual is on a disk which came with it. TYIA
not.likely is offline Find More Posts by not.likely
Old Jun 24, 2008, 11:48 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
The punch out for the USB port is intended for future versions.
You can update the charger with a little soldering and a USB / TTL converter.
Instructions are here, and in some other postings:
http://www.rcgroups.com/forums/showt...08#post9767208
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
