Old Jun 17, 2008, 02:22 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by thomanie
@junsi:
I believe NCGuy wants a "lipo disposal" mode to completely discharge a already broken lipo to 0V before handing it off the correct facility for proper disposal. Instead of putting a lightbulb on it to discharge it to 0V, he wants to hook it up to the (dis)charger to get it to ~0V.
T
Hello Thomas,
Thanks!
Originally posted by NCguy,
Does it make any sense to have a discharge to zero function for lithium or would this risk damage to the charger? To dispose of LIPOS's I prefer to discharge to zero (or very close) rather than saltwater which can corride the tabs before the pack is fully discharged.
I currently use a charger with a discharge function to take it down to around 3 volts per cell and then use bulbs to take it the rest of the way down. It seems like it would be more convenient to have the charger take it to zero in one step? And unfortunately I have to do this a lot more frequently than I would like.
Thoughts?
Hello,
You can use the dicharge program for NiCd/NiHM to discharge your LiPo, then you can discharge the LiPo to 0.1V.
Regards,
Junsi
junsi is offline Find More Posts by junsi
Old Jun 17, 2008, 03:30 AM
Smeagle is offline
Find More Posts by Smeagle
Munich, Germany
Joined Nov 2003
I just take the old cells to the "resource collection point" (no idea if this word exist in English) - they handle this stuff. I called and they told me, no need for any special treatment, just bring them in. This may be different in other countries
- Oliver
Smeagle is offline Find More Posts by Smeagle
Old Jun 17, 2008, 04:58 AM
planekrazee is offline
Find More Posts by planekrazee
Gales Ferry, CT
Joined Jun 2008
I would not want full discharge feature on the charger, the storge feature is a good one.
planekrazee is offline Find More Posts by planekrazee
Old Jun 17, 2008, 06:30 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hello Junsi,
I have one question concerning the setting of the Watt Limit, manual page 8.
When I sett the watt Limit to "auto", how does this work? Is the charge current reduced, when the input voltage lower limit is reached?
Lets say, I program in 10V minimum voltage, and watt limit "auto".
Then I connect the charger with my power supply, which can deliver 6.5A/13.8V. If I try to draw more current, the voltage will fall. It is short circuit protected.
When I connect the charger to the power supply, and operate it with a high charge current for a large battery, so that it will need more than 6.5A input, how will the charger react?
Will it increase the current, until the supply voltage falls to 10V, and then regulate the curent, so that the supply voltage will never fall below 10V?
Julez
Julez is offline Find More Posts by Julez
Old Jun 17, 2008, 07:57 AM
Gales Ferry, CT
Joined Jun 2008
When is the next shipment of 106b's scheduled? It looks like everyone is sold out.
Old Jun 17, 2008, 09:39 AM
NCguy is offline
Find More Posts by NCguy
Greensboro/H.Pt/Win-Salem P.T. Intl, North Carolina, United States
Joined Dec 2003
Originally Posted by Julez
Submerging them in a little bucket filled with saltwater is safer and more convenient.
You may want to re-think that Julez.
Recent tests have shown that salt water is so corrosive that it corrodes the tabs before the pack is completely discharged.
NCguy is offline Find More Posts by NCguy
Old Jun 17, 2008, 09:42 AM
NCguy is offline
Joined Dec 2003
Originally Posted by junsi
Hello Thomas,
Thanks!
Hello,
Regards,
Junsi
Does anyone know if 0.1v is safe enough to discard in the trash? Does it still require further discharge?
Old Jun 17, 2008, 10:35 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Well, I must admit that I have never done it before, I just read it at the UH website or forum.
I think they also recommended to puncture each cell with a knife or so before throwing it in the water bucket.
Old Jun 17, 2008, 03:27 PM
DeepRising is offline
Find More Posts by DeepRising
Agrate Brianza, MI - Italy
Joined Mar 2007
Originally Posted by kgfly
I agree, the exact value is probably not vital.
Are you sure FP EVO 25 recommend 3.4V ? I never discharge my lipos that low, ever ! Before doing that I would seek confirmation from FP directly.
Attached you can find a picture of the label located on the EVO 25 10S 5000mAh, until now I have always used this rule. By phone Flight Power guy told me that 3,8V is also ok.
DeepRising is offline Find More Posts by DeepRising
Old Jun 17, 2008, 03:33 PM
Joined Mar 2007
Nice news
AFAIK, around 3.8V is perfectly ok for all LiPo brands.
A little more or less does not really matter.
Thank you for your suggestion, I have a question: why Flight Power stress the customer to manage element value so low respect 3,8V? I spent several time to redouce the voltage at home.
Attached Evo 20, Evo 25 and Enerland rules.
Old Jun 17, 2008, 03:49 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Well, I don't really think this is rocket science.
My simplified theory is, the more you are at the max/min levels, the faster the pack ages.
Taking 3.3V as a minimum, and 4.2V as a max, 3.75V is right in the middle.
A little more or less really does not matter.
Cheers,
Julian
Old Jun 17, 2008, 08:39 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hello Junsi,
Julez
Hello Julez,
Your understanding is right.
The charge current will reduce when the input voltage lower limit is reached!
the lower limit of input voltage=The set minumum voltage +0.3v
If you set the minumum voltage as 10V, then the lower limit of the input voltage is 10V+0.3V.
Regards,
Junsi
Old Jun 18, 2008, 12:42 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
I don't think being close to the min level will increase the ageing process. Only problem with going too low is the risk of self discharge below min voltage. I never bother to charge a pack to 3.8V after use.
Fred
flarssen is offline Find More Posts by flarssen
Old Jun 18, 2008, 09:27 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
I am sot too sure.
AFAIK, the electrolyte is stable in a specific voltage window. If you leave this window, the electrolyte is damaged and the cells swell.
This may be an additional risk, yes.
Interestingly, I recently bought a couple of new LiPos, and after discharging to 80%, the resting voltage is arounf 3.75-3.8V. I do not charge them, either.
Junsi:
Thanks a lot for your clear answer!
Cheers,
Julez
Old Jun 18, 2008, 10:20 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Had my first hiccup with the 106B tonight. The LCD went completely blank right after I started a charge cycle. This was particularly frustrating as I was in the middle of logging comparative performance figures amongst several chargers and really needed to see the volts/amps/mAh figures. I found if I pressed the Inc, Dec or Start key a few times I would get something. Sometimes random characters, sometimes a partial display, sometimes the normal display with a few weird characters or extra dots and sometimes, the normal display. Note that all this time the charge cycle was still running (I know for sure as a had an FDR in line).
I tried pressing a bit on the case to see if there was some issue with the LCD not making proper contact with the PCB but it made no difference.
This unit has been working beautifully for up to several hours a day almost every day since I received it about a month ago. It has never been dropped or otherwise physically abused. I have opened the case twice, once when I first received it to take a peek and once when the info about adding a serial port came along, although I have not yet done so.
At the end of the charge cycle the display came on as normal and so far, has remained on. I have not yet tried another charge cycle (am out of discharged packs for tonight!).
Any thoughts JunSi ?
kgfly is offline Find More Posts by kgfly
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
