san francisco
Joined Nov 2003
Hi guys I've just got my new I-charge 106b+, and I'm getting this message;
Battery check low Voltage, I connected It to my car battery and the balance connector to the balance Port I tried different sizes; Thanks for any help you can give me Mike;;;;;;; |
- Correct battery type? - Correct cell count? - Correct charge mode (Fast, balance, etc.)? - Main battery leads and battery balance leads connected? - Correct charge current set? |
Mike, I had the exact same problem with all my iChargers (2@ 106b+ and a 208b). The problem was caused by high frequency "transients" in the power line. It happened with both my power supply, and the battery of my Ford (my Ford has a high quality spiral cell deep cycle battery too).
I installed a 25V 2200uF electrolytic capacitor across my input leads and the problem went away. The exact value of the capacitor is not so critical; just make sure it's rated for the voltage you'll be using (>15V for an auto battery), and in the 1000-3000uF range. A quick to to Radio Shack should get you straightened out. Cheers, Kevin [edit: BTW, this is not necessarily a flaw in the iCharger design, so much as it is a limitation with the power supply(ies). In my case, a single capacitor fixed the problem for all 3 chargers, since all 3 chargers plug in at essentially the same location (I use an extension with 4@ female banana jacks mounted in a box on the end; the cap is located in the box, and all my chargers plug in to the box).] |
first off my 1010+B is probably the best charger i have used to date. my hats off to the designers.
ok short of sifting threw all 300+ pages of replies can i charge a 7s A123 pack using 1 3s balance plug, and 1 4s balance plug to get all 7 cells balanced? if so how do i wire between the 2 plugs? do i put the 3 cell plug (closest to the - of the battery) in the first 3 cell port on the balance port, and the 4 cell plug in the second 4 cell port, and then start the charge? Jerry |
orlando florida
Joined Jun 2005
Hi guys,
I just purchased a 1010 charger and I tried to charge 10s setup using 1-4S & 1 6S battery. I connected the battery together red to black from 1 lipo to the other then I attempted to connect the balance tabs on the balance board. the 6S connected fine when I went to connect the 4s tab, the balance wires started to fry. What did I do wrong? And also where can I get a new balance connector for a Turnigy 4S battery. Thanks Ty |
Since your packs are wired in series, you can't mix and match the balance connectors on different rows as that would create a short circuit, damaging at least the balance board and possibly the packs and charger. If your packs are wired in series, then you must ensure that your balancing leads are also wired in series. This is why most people now recommend parallel charging (ie: packs of the same voltage ... 3s with 3s, 6s with 6s) vs series charging. Parallel charging greatly reduces the chances of incorrect wiring. Looking at one side of the balance board, notice the letters: A, B, C, D, E ... you can only use one of those rows at a time if series charging. When parallel charging (packs made up of the same number of cells), you can use multiple rows, but only with connectors aligned on the negative side. Scan this thread for photos of that setup. FYI, the recommended sequence by the manufacturer is to connect the balance lead first (see post #1). You could build your own wiring harness to series charge a 6s and 4s together. The required JST-XH plugs are available at Digikey. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
