The 106B+ can give a max of 250W on 13.8V The 206 can give a max of ~260W on 13.8V The 1010B+ can give a max of 300W on 13.8V The 208 can give a max of ~300W on 13.8V Don't exclude the 20X chargers based on your current power supply! Plus, if you ever do get a 18V+ supply with enough amp-delivering capability, you can push the 208 up to 350W (or the 206 up to 300W). Unless you need 10s charge capability, I'd say the 208 is a better choice than the 1010B+. |
Patchogue, NY
Joined Jan 2009
Am I the only one who doesn't have CB issues? I have 106B+and 208 and I've been using them almost daily for about a year. I recall a couple of error messages but those could be addressed by mistakes in power scheme of my old charge box, once I changed the wiring no more errors at all. And I have latest firmware.
Bogota Colombia
Joined Oct 2008
Regards, Gustavo |
Melbourne, Australia
Joined May 2006
No you are not the only one. If the charger works most people have no need to post on forums. If someone has a problem they post seeking help. Hence we see many posts from the small proportion that are having problems. Mine have been working problem free since new and they are amongst the first ever shipped.
It is very frustrating to spend a significant amount on a charger and have it misbehave. The difference with Junsi is that they have shown that they care by acknowledging it whenever a problem is found (rather than ducking, denying or ignoring like some others) and working on a solution. Clearly this problem is proving difficult and taking longer to fix than anyone would like, but Junsi's track record is excellent and patience is the best medicine for now. |
I wonder why charger manufacturers don't put some kind of plastic (even clear) at least an inch or so around the output power connectors? I know from experience that people can forget and connect the charger side last by mistake(or disconnect the charger side output first by mistake). If you miss the plug when connecting it you can cause a very short lived battery short against the outside case around the connector depending on which .
It is easier to make this mistake when the output power connectors are on the side of the charger than when on top because you sometimes can not see the connector very well on the side depending on where you are standing in relation to the side of the charger. I never had that happen with any charger that had the output connectors on top but all the chargers with output connectors on the side I usually made the mistake once on each. I doubt this causes any problems with the battery since it lasts for such a tiny amount of time based on experience but the spark and weld pitting on the case sure scares you. I know this is user error but things happen. |
Belfast / Dublin
Joined May 2004
![]() any reason for that preference?... i was looking at 106B also... 208B looks good, but i'm not convinced i need that sort of fire power
If all you need is 6s and the lesser of 10A/250W, then the 106B+ can serve you well and let you save some coin. |
You never know where your needs or wants will end up. It's always better to have too much firepower, verses, not having enough. it is a small upgrade in price initially, but I'll bet you will be glad you did it in the long run. From a favorite movie, "Don't take a knife to a gunfight". Richard |
Lab, Slovak Republic
Joined Jun 2008
After all, thst was a support related question for all of us, not a business one.David, thank you for clarifying. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
