Old Dec 06, 2009, 05:27 PM
las vegas
Joined Jan 2004
My neu x10 i just bought (1010B+) has the 3.09 loaded
done a few lipo charges-NiMH ext ...
#1 due i need to load the new software 3.11 in it seems to work fine love it.
#2 how can i test it to see if it has this conection error you are taking about ?
and other issues ....i would like to catch it now and not later
i've charged every thing i have in the house including camera lion and cell phone batteries lol its fun to play.
overall what a great charger vary happy !
wing warrior is offline Find More Posts by wing warrior
Old Dec 06, 2009, 05:42 PM
Melbourne, Australia
Joined May 2006
IMO if you are happy with how any charger is working then do not upgrade unless the Mfr recommends the upgrade for safety reasons.
kgfly is offline Find More Posts by kgfly
Joined Sep 2009
My advice (give it little or no weight if you wish): don't tempt fate-leave the firmware "as is" and DON'T EVEN THINK ABOUT TRYING TO INDUCE THE CONNECTION BREAKDOWN ERROR, you'll have it soon enough.
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Dec 06, 2009, 05:45 PM
Joined May 2006
BTW - It looks like you are powering the X10 via the optional DC jack input. You should be aware that input is limited to 7A so the maximum output charging power is very limited, about 75W if you are using a 12V/7A supply.
Old Dec 06, 2009, 07:01 PM
las vegas
Joined Jan 2004
thanks for the info
i use the laptop plug for small pack charges , i also have a 13.8 v 25 amp power supply......i will just leave the good alone then for now
Old Dec 06, 2009, 11:55 PM
Keep it steady
lavi's Avatar
Haifa ISRAEL
Joined Oct 2008
Originally Posted by henrik2000 View Post
Question for Junsi:
As the 1010B+ is a 250 Watts charger..
If I set the charger on 5A and 10S {P = V * I} or (42 Volts * 5A) = 210 Watts.
Will the charger being able to handle it? (I don't want another "smoke event ")?
Happy charging without smoke...
The 1010 is a 300W 10A 10S charger (thats why its called 1010).
i.e. its max cell count is 10S, its max amp is 10A and its max watt is 300W.
so if you charge 3S pack you can go as high as 10A, even though it is well under 300W (12.6*10=126W).
BUT if you charge a 8S pack you will only be able to charge at ~9A becuase the Watt limit of 300W (300W/33.6-~9).
for 10S you will be able to charge @~7A (300/42).
BTW: 106 is 10A 6S 250W, 206 20A 6S 300W, 208 20A 8S 350W
lavi is offline Find More Posts by lavi
Old Dec 07, 2009, 01:19 AM
iCharger 106B user
Lab, Slovak Republic
Joined Jun 2008
Guyz with connection breakdown, did you try to downgrade your firmware?
alex.guzun is offline Find More Posts by alex.guzun
Old Dec 07, 2009, 07:23 AM
Joined Sep 2009
I NEVER modified my 208b's firmware (never flashed it): one day, it just started.
Old Dec 07, 2009, 08:30 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
In my opinion this is only going to lead to confusion.
One poster has a new Neu charger ,it is not the official iCharger one. It may be made by same manufacturer but it may or may not be exactly the same including the firmware.
Another poster is aking about connection break errors and no one know which charger he is refering to or if he had either cjharger or has had any issues.
What if I posted my charger died?
I suggest keeping iChager comments in this iCharger thread and limit comments Neu chargers elsewhere .
Personally I hate chargers being name the same / similar . The iCharger 1010?
was and is confused with the Thunder Power TP1010C
Charles
Old Dec 07, 2009, 11:37 AM
Belfast / Dublin
Joined May 2004
anyone using these chargers with Hyperion / Flight power / Kokam Lipo's
how does it work with the balance port as the charger seems to have only one type ... especially on the 206B which has no balance board, just a few ports/sockets in the side for balance plugs.. how do we use this for all the different cel types?
are there other balance boards available?
big bird is offline Find More Posts by big bird
Old Dec 07, 2009, 11:48 AM
ProgressiveRC
write2dgray's Avatar
Seattle, WA
Joined Dec 2006
Sure,I use them will all types of lipos on a regular basis. Balance boards for the many options (JST-XH, PolyQuest, ThunderPower, Kokam) are available here:
http://www.progressiverc.com/index.p...5&Itemid=1
Cheers,
David
write2dgray is offline Find More Posts by write2dgray
Old Dec 07, 2009, 11:52 AM
Joined Sep 2009
David sells and I use adapter/balance boards for every "plug" on the market.
Old Dec 07, 2009, 12:23 PM
Belfast / Dublin
Joined May 2004
thanks guys, these look suitable for the 1010 and the 208B
can they used with the 106B / 206B chargers?
also they are only up to 6s balance, whereas 208 is an 8s charger...
Old Dec 07, 2009, 12:44 PM
ProgressiveRC
Seattle, WA
Joined Dec 2006
The boards are up to 10S and the same ones are used for all 6S, 8S, and 10S chargers, although the max. number of cells in series that can be used is limited by the model of charger.
106B+/206B = 6S
208B = 8S
1010B+ = 10S
- David
Old Dec 08, 2009, 03:07 PM
iCharger 106B user
Joined Jun 2008
Cheers,
David
OT, do you know where to get those silicone banana housings?
Charles
Junsi should say if it is the same or not, then more ppl can find their 'appropriate' answers here, also (the same for A Main Hobbies iCharger)
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells khen Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
