I hadn't appreciated that connecting the leads in a sequence other than the recommended one can cause damage to the charger, except under the specific circumstances mentioned in Junsi's first post of this thread - ie reversed polarity. If you're saying, as I think you are, that connecting main leads first can lead to this "connection breakdown" error then it's news to me but I'm glad to know it as I have another 208b and a 1010B+ to look after.
As far as connecting positive before negative, this isn't so easy as I use Deans, although I suppose I can do it by removing the neg banana plug from the side of the charger then reconnecting it. All of this is hassle I hadn't bothered with because I didn't see any benefit, but if you can verify that this can prevent the connection breakdown error then I suppose I should do it. If that's the case, it would be good if Junsi's first post is more explicit regarding this. |
First off I am not stating that sequence has to be followed. I have done it both ways many times but the spark can not be good for the charger.
About a year ago there was a lot of Hyperion chagers developing Connection Break down Errors ( still happens but not as often it seems)and Hyperion specifically recomended connecting the main leads first then balancing leads and then reverse for disconnecting. Hyperion modified the firmware to take care of this issue but...... Concerning the Deans Ultras. It is easy enough to connect the pos. blade first then rock the neg. blade into the connector. Charles |
Son, Norway
Joined Sep 2004
Fred |
Connection Order:
OK I will leave it to others to sort this out. I have expressed my views. English is not junsi native language and find much of the owner's manual unclear and I know he has had much help with it. IMO if everyy user read and understood the instructions in the owner's manual and the first post here then this thread would be approx. 5% of its current size. Charles |
+1 for that. I have just read over it twice (208b) and it all makes quite good sense. A few things I needed to read a few times, but thats only because I wasnt really paying attention the first time and I Mhad the lappy in the loungeroom and the charger in the garage so I was running back and forth!
Still not quite sure why connecting the +ve lead before the -ve lead will stop arcing, but I will give it try
Summerville, GA...USA
Joined Apr 2006
Here's what I have:
2s A123 pack, wired up with a servo extension. The red wire goes to the + of one cell, the black wire goes to the - of the other cell, with the yellow wire going to the bar connecting the 2 cells in series. I have a plug that I can make for the balance board for a 2s pack. Now the problem is, I have to plug in the power output wires from the 106b+. Do I need to run 2 more wires off of the original red and black wires to connect the power output wires to? Or should I just make a plug to charge the A123's, only using the red and black wires? |
Son, Norway
Joined Sep 2004
Hope this is clear without any illustration. Fred |
If the servo lead is the only one then you need to made and adaptor so that the pos. and the neg. can be connected to the chargers main output leads and the servo (balancing )leads can be used for blancing.
So yes you need to run 2 more wires off of the original red and black wires to connect the power output wires to but you could also only use the red and black leads and not balance charge it. I recomend balancing however. Charles |
Deerfield Beach, FL
Joined Apr 2006
got the 106b+ today, seems pretty good, charged a crappy eflite 800mah 3s pack and it balanced it pretty well, one cell was 4.21 while the other 2 seemed to be 4.23 but they aren't the best packs so that could be the issue. I set them for 2C and it still took around 47 minutes which I thought was a long long time.
But for my main question. I've tried nicd and nimh auto mode on my transmitters and is it just me or are they just useless? I set them for like 1 amp and they charge at like .4 amps. I'm just using manual mode now so they actually do something. |
Auto Ni mode results depends on how good the battery (cells) are . With decent lower IR cells it does fine with higher IR cells it backs the charge rate down to a safer(kinder) level. This is normal and I have several chargers which react the same.
Try doing a discharge then using the Ni Forming charge as the battery may be out of balance. Charles |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
