Old Aug 19, 2009, 08:22 AM
chainring is offline
Find More Posts by chainring
Joined Apr 2007
Originally Posted by Junior86
Hello Junsi,
I am a happy 106B+ user but I have minor problem. First of all I have the v3.11 firmware, everything is OK with the charger except for the indicated 5. and 6. cell voltages of the balance port. The difference from the real (measured with multimeter during monitoring so poor balance port connection can not be an issue) cell voltages are 0.05V and 0.08V. Sofar I have been used v3.08 with almost the same issue: 0.05V and 0.05V. All in all if the charger balances the pack to 4.20V/cell, the mentioned cells are overcharged to 4.25V and 4.28V. Is there a way to fix this problem?
Thank you in advance,
Junior
See the first post for "User calibration.pdf". User calibration of all voltages.
chainring is offline Find More Posts by chainring
Old Aug 19, 2009, 09:59 AM
Junior86 is offline
Find More Posts by Junior86
Hungary
Joined Feb 2009
Thanks for the hint! I like the support for this charger!
Junior
Junior86 is offline Find More Posts by Junior86
Old Aug 19, 2009, 10:08 AM
rsmheli is offline
Find More Posts by rsmheli
rsmheli's Avatar
Indiana
Joined Feb 2007
Originally Posted by junsi
Hello Sir,
Would you pls use Logview to note data, and then send us for analysing?
Thank you very much.
Regards,
Junsi
PM sent
Log View File Sent to szjunsi@163.com
Thank you
rsmheli is offline Find More Posts by rsmheli
Old Aug 19, 2009, 01:15 PM
Hupplung Dungh is offline
Find More Posts by Hupplung Dungh
Joined Aug 2009
I'm no good at all this, but I have a meter and a 208b: WHERE do I connect the meter to recalibrate? Thanks
Hupplung Dungh is offline Find More Posts by Hupplung Dungh
Old Aug 19, 2009, 01:26 PM
Joined Apr 2007
For each of the voltages you want to calibrate, you'll need to hook your meter up at that point for the reference. Such as, at each cell, for each of the individual cell readings. Or, if you use longer charging leads, then at the end of them, where you hook to your pack. I did this because I was seeing final LiPo termination voltage over 4.20 (at the cell), so I calibrated the charger to what was being seen at the cell. Now, they're in agreement.
Old Aug 19, 2009, 01:37 PM
Joined Aug 2009
Sorry-I'm a bit dense.
How can you do that if the leads and balance tap are connected to a battery as per the instructions?
When you say "hook up," my meter only has probe type leads: what do I need to "change?"
Thanks!
Old Aug 19, 2009, 02:18 PM
patterkid is offline
Find More Posts by patterkid
TC, Michigan
Joined Jan 2009
Question....
Say i power the iCharger 208B with the Mean Well SE-600-24. How many amps will it be able to charge at on 3s? 6s?
-Justin
patterkid is offline Find More Posts by patterkid
Old Aug 19, 2009, 02:27 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
With a 24V power supply the 208B will deliver its' full rated 350 watts output. I tested mine at running at 350 watts out put it was drawing 382 watts from the power supply ( not a Maenwell) mine was holding 24.55 volts and delivering 15.5 amps to the charger.
I was charging an 8 cell A123 ,with battery at 28 volts ,12.5Amps. were being delivered to the battery.
Depending on the nonimal voltage you use .
350 watts / 12.6 volts - 27.7 amps. and half of that for a 6S.
Remember not to exceed the recomended charge rate for your LiPolys.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Aug 19, 2009, 02:36 PM
saarisalo is offline
Find More Posts by saarisalo
Kirkkonummi, Finland
Joined Mar 2006
Originally Posted by patterkid
Question....
-Justin
As per iCharger manual, it will be able to output 350W once the input voltage is 17V or more.
350W/12.6V = 27A. The output current is limited to 20A. 3s max current will be 20 A.
For 6s, 350W/25.2V = 13,89A. 13.98A is well below the 20A limit. 6s max current will be 13.89A. In practice it should be a bit higher until you reach the 4.2V cell voltage during the charge process.
-mikko
edit: Charles was faster.....
saarisalo is offline Find More Posts by saarisalo
Old Aug 19, 2009, 02:51 PM
Southern Pride
But I forgot to mention the 20A max. out put
I am still amazed at how much power this little bitty charger packs and how effecient it is.
Charles
Old Aug 22, 2009, 12:26 AM
TC, Michigan
Joined Jan 2009
So i picked up a 600-24 PSU. Now i need assistance on how to wire a AC Power plug to it. Im assuming you take a standard PC Power Cord and cut the end off and attach the three wires to the spots on the Power Supply. But i am wondering if anyone can clarify this and possibly post a picture of how they did it :-)
-Justin
Old Aug 22, 2009, 09:42 AM
skippy55
A moderator felt this post violated the following rule: Offensive content (Flatulence). It is temporarily hidden while skippy55 edits it.
Old Aug 22, 2009, 10:22 AM
Southern Pride
Darn spammers
Here also
http://www.rcgroups.com/forums/showp...&postcount=101
Charles
Old Aug 22, 2009, 02:26 PM
kribe is offline
Find More Posts by kribe
kribe's Avatar
Luleň, Sweden
Joined May 2004
About 106B+ question.
I have an 106B+ baught in aug 2009 and updated to V311.
However, when I check the Ri on my LiPo (hextronic 2200 g3 3s pack) then iCharger shows 8 7 8 mOhms with the balance connector connected. Without balance connector ir shows Battrey pack Ri= 75 mOhns.
This is strange, bacuse 8+7+8= 23 mOhms and this differs very much from 75mOhms.
SW bug? Or ?????
Seabee water flying!
kribe is offline Find More Posts by kribe
Old Aug 22, 2009, 04:41 PM
Wyn is offline
Wyn
Find More Posts by Wyn
Wyn
VoltMagic
Wyn's Avatar
Joined Apr 2007
SW bug? Or ?????
When the balance connector is not used, the resistance of the connectors and all the wiring is included. With the balance connector, the wiring and connector to the pack is not measured, just the cells.
In your example, it's indicating that 52 mOhms (75-23) is the resistance of the wiring and connectors from the charger to the battery.
Wyn is offline Find More Posts by Wyn
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
