| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 | |
I repeat this one: During balancing, what is the max bleeding current? Fred |
#32 |
Lots of good ideas there Julez
I agree with almost all of it with some minor variations (eg chemistry order LiFe/LiIon/LiPo is indeed safer but one could argue that LiPo/LiFe/LiIon is more convenient given what folks are using or moving towards).Certainly making the firmware upgrades available to the user to "flash" the charger will greatly lower the barrier to acceptance of a new brand or even a new model in an established brand. This feature is available for several of the major competitors (eg TP1010C, EOS0610i, EOS1210i) and other newcomers (eg MaxproX6). If that cannot be done quickly, then providing your distributors with the ability to upgrade the firmware locally in their geography is the next best thing to do. Folks are very, very reluctant to ship items internationally just for a firmware upgrade. |
#33 | |
iCharger
max bleeding current that you mention to is Current drain for balancing? max Current drain for balancing is 300mA. it means, the max current of every cell discharged by balance module is 300mA during balance charging mode. Do you know what i mean?
#34 |
Proud to eat Kraut ;-)
Thanks, kgfly !
I could not agree more with your second point. Shipping a charger to China and back, just for a software update, would need about a month minimum. Nowadays, I can really see no reason why a charger should not be flashable. The 1 od 2$ more in hardware costs, many people would gladly pay. I have 2 chargers, and both have recieved 5-10 updates. Each one was a good improvement. This way, especially when people weigh whether buying from a new brand or not, they can be sure not to be stuck with some software bugs, or when a new battery technology emerges. Junsi, Thanks for making clear how it works! One suggestion for the capacity cutoff menu: Please make it possible to disable this option. The chargers I have, have a value of 0-xxxmAh for capacity cutoff. When choosing "0mAh", the cutoff is disabled, when choosing more than 0mAh, the cutoff function works normally as described in your manual. One question about the Lithium normal charge mode: Do the balancer cables have to be connected to the charger in this mode? Or is it possible to charge the battery pack without the balancer connection? Last edited by Julez; Mar 29, 2008 at 11:22 AM. |
#35 | ||||||
iCharger
Julez, thanks very much.
#36 | |
Beef the circuit to handle +300W (9s 5000mah charged at 2C, any large parallel LiFe pack) and you'd sweep the market IMHO. T |
#37 |
Junsi,
wonderful to read this! If the options are implemented as you write, you will soon have a killer product When manufacturers and hobby people with experience listen to each other, great improvements can be made for the benefits of everyone. Thanks for your detailled answers. Cheers, Julez |
#38 | ||
iCharger
#39 | ||
. It works fine! Quote:
I think this must already be one of the better chargers on the market. Julez suggestions would make it even better. Fred |
#40 |
on a vacation
Amazing world, isn't it: some guy in China uses the whole world to design the ideal consumer product, rather than what some egineer thinks they "should" have-I'm with the German guy-if you bring this to market, it will be a "killer!"
I sent an e mail inquiry about how to buy the smaller one here in the U.S. and got no answer. How do I buy either of these chargers! |
#41 | ||
Yes, listening to the actual customers is always a benefit. A Chinese flashlight company, Fenix, does this too on CPF, and sells like mad. Get the charger done, and with the suggested hardware and software, this will be a winner. |
#42 |
I totally agree with Julez - "If you build it, they will come!"
![]() The obvious question now is when can we expect to see v2 (1010Bv2,1010C?) with these features in? T |
#43 |
on a vacation
Build it sooner, please, because there may not be any "dollars" left over here!
#44 |
Another suggestion.
Recently, I have experimented a lot with different LC Displays, especially concerning the backlight color. The best results I have achieved with Supertwist Nematic (STN) transflective displays with grey color and white backlight. Yes, I opened these displays and changed the LE diodes They have the best readability, both indoors with ambient light and in the darkness, as outside in bright sunlight. Any other backlight color is inferior to my tests, especially blue. Blue looks cool, but is bad to read. Yellow backlight or green display color is also ok, it makes the charger look less monotonous. What kind of backlight do you currently use? Is it green or yellow? It looks a little greenish on the images provided. If this is the case, I encourage you to experiment with yellow or white backlight, you might be surprised The photo shows the current display in my transmitter: Yellow/Green display color with white backlight. Cheers, Julez Last edited by Julez; Mar 29, 2008 at 03:46 PM. |
#45 |
Yep, the blue displays are fashionable but hard to read, definitely stick with the green/yellow/grey ones.
| Thread Tools | |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 01:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 04:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 09:55 PM |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 22 | Aug 09, 2002 12:52 PM |
