Old Jul 15, 2009, 10:24 PM
MDEMSKI is offline
Find More Posts by MDEMSKI
Santiago - Chile
Joined Jul 2009
Originally Posted by junsi
Hello Sir,
Would you pls press STOP button for 3 seconds, to check the individual cell voltage? Then you can measure it by multimeter, to see if the difference is more than 10mV or not. If the difference is less than 10mV, then the charger is without any problem.
According to your provided data, it's normal. Maybe the problem is that the Cell 2 internal resistance is higher.
Regards,
Junsi
Sorry but I do not understand: It will be normal that the charger needs 90 min. to charge a almost full (84%) LiPo Pack and is not able to finished the charging procedure balancing the cells because the cell voltage does not has 4,2 V (setup). LogView showed 12,6 V for the LiPo and each cell had 4,02 V? ---> 3 x 4,02 = 12,06 and not 12,60 V or am I wrong???
The same LiPo my ThunderPower charger charged in 34 min.
By the way: I tried to make the calibration, following you instruction. But only get this: www.Jun-si.com and a large number. Holding down the start bottom for 3 sec. ---> nothing.
MDEMSKI is offline Find More Posts by MDEMSKI
Old Jul 16, 2009, 12:23 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Regards,
Junsi
It's not normal to have a 0.74V difference between pack voltage and the sum of cell voltages, at least not when current is close to zero. It seems to be a calibration problem and the charger is backing off because of pack voltage limit and not based on cell voltage.
Fred
flarssen is offline Find More Posts by flarssen
Old Jul 16, 2009, 12:29 AM
flarssen is offline
Son, Norway
Joined Sep 2004
Should be easy to check if calibration is needed by measuring the voltage at the charger terminals with your multimeter, and compare with the displayed one, just like you already did with the cell voltages.
Fred
Old Jul 16, 2009, 05:06 AM
nobita is offline
Find More Posts by nobita
Jerez De La Frontera La Parra, Spain
hello!
Since measuring the voltage at the battery balancer terminal when this balancing??
thanks
nobita is offline Find More Posts by nobita
Old Jul 16, 2009, 07:21 AM
mm2 is offline
mm2
Find More Posts by mm2
mm2
mm2's Avatar
Joined Aug 2007
I am not native english speaker so I apologize if it's crystalclear for you but I don't understand what these calibration instructions exactly mean: "Steadily 12V input power supply" and "When calibrating, you need clear the voltage source."
Does it mean I just need zero-ripple input power source (e.g. lead-acid battery) or do I need exactly 12,000V reference input voltage?
mm2 is offline Find More Posts by mm2
Old Jul 16, 2009, 07:40 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hello Julez,
It can not only calibrate the individual cell voltage, but also the main voltage.
Regards,
Junsi
Hi Junsi,
I need your help here. How do I calibrate the main voltage?
Here is what I do:
I connect a 4s A123 Pack to the charger with main and balancing cables. I think this is enough, as I do not want to calibrate the individual voltages.
I connect the CellLog in parallel, to read the main voltage.
I follow steps 1-4 of your calibration manual. But I can only scroll through the individual voltages 1-10. Number 5-10 show nothing, of course.
How do I get to the main voltage?
Julez
Julez is offline Find More Posts by Julez
Old Jul 16, 2009, 07:41 AM
Vince53 is offline
Find More Posts by Vince53
Potage, MI
Joined Dec 2003
I was able to successfully calibrate each channel on 208B to +-0.001 volts against my reference standard. After I use it a while and it cycles through heating/cooling cycles I'll check it again and report back.
Vince
Vince53 is offline Find More Posts by Vince53
Old Jul 16, 2009, 08:19 AM
natterjak is offline
Find More Posts by natterjak
Asks too many questions
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
I have a problem developing with my 1010B+. The stop button does not work all the time, sometimes it's ok, sometimes it has no effect. If you press it 5 times in a row it might not work the first 4 times, then the 5th time it works.
Is there anything I can do to fix it myself or is a warranty return issue? This is not my original 1010B+ it's the one I received as a warranty replacement when my original smoked itself during a charge Not sure what Hobbyking's view on a second warranty exchange will be but I originally purchased my charger in November last year so I've had less than a year of total usage and have only had this charger for 2 months.
natterjak is offline Find More Posts by natterjak
Old Jul 16, 2009, 08:33 AM
mm2 is offline
mm2
mm2
mm2's Avatar
Joined Aug 2007
Julez
It works for me on 1010B+. After step 3 don't press <Inc> to jump to per-cell volatge screen, however, directly in the main screen (displaying Vin, Vout, Tin and Tout) press and hold for 3 seconds <Dec><Inc><Start>. It allows callibration of Vin, Vout a Tin then (may be Tout as well but I didn't have external probe connected). 3s pack was sufficient to do that.
Old Jul 16, 2009, 08:39 AM
jollyrogertoo is offline
Find More Posts by jollyrogertoo
Joined May 2009
Vince
How did you do this?
Must you open the case?
jollyrogertoo is offline Find More Posts by jollyrogertoo
Old Jul 16, 2009, 08:59 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
junsi has been extremly good at keeping the first post of this thread updated with relative imformation. There is a pdf file link in the first post to the calibration imformation.
Post here
http://www.rcgroups.com/forums/showp...postcount=4173
Hello everyone here,
We have published the calibration steps in the first page of this thread. If you need it, you can check and follow it.
Regards,
Junsi
I should most likely keep many of my opinions to my self but I never cease to be amazed how little effort many make to find an answer before posting a question.
Link repeated here
http://www.rcgroups.com/forums/showa...mentid=2640055
Charles
Old Jul 16, 2009, 09:46 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Yeah! This worked perfectly. Thank you, Sir. I must have been a blockhead.
Now the charger charges my field pack just fine.
There is a stuff in electronics stores called "tuner contact spray". It is not agressive like the automotive stuff, and is made especially for electronics.
I make it a habit to give every button a little squirt on every charger I own, not only iChargers. This helps.
Old Jul 16, 2009, 09:56 AM
Joined May 2009
Post here
Link repeated here
Charles
Okey, doaky, now moving on to the next question: what is a "41/2" meter?
Oops, another question: how and where do you connect it as the instructions seem to assume one understands this, too?
I'd search for the answers but I don't know what search string to use!
Old Jul 16, 2009, 09:59 AM
MrBungle is offline
Find More Posts by MrBungle
rebmeM roineS
MrBungle's Avatar
Rockingham, Perth - Western Australia
Joined Apr 2001
My guess is a 4.5 digit multimeter.
Where to connect? Sorry, dunno, just here researching this charger to decide whether to buy
MrBungle is offline Find More Posts by MrBungle
Old Jul 16, 2009, 10:10 AM
Joined May 2009
Well, if this helps, "use" is indicia of preference, right?
I seldom use my Hyperion Duo 2 or Thunderpower 610C, now, and head straight for my 208B, and use parallel charging.
Also, the little power supply sold by Icharger is almost silent and very powerful!
The only "problem" I have with Icharger products is that such seem to be designed for experts as well as novices (like me), and the experts post all this "stuff" that I want to try!
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
