We have published the calibration steps in the first page of this thread. If you need it, you can check and follow it. Regards, Junsi |
New Zealand, Auckland
Joined Dec 2008
discharge max amp setting & MAX discharge power rating
Hi there. From the specs'
Discharge current range : 0.05 @ 7.0A Maximum discharge power capacity : 20W Is there a safety feature to NOT ALLOW to try & discharge a 7v batt @ 5A ?? as this is over its rated discharge power of 20W I blew my Imax as it allowed discharge of 5A @ 7v, too high for it to cope with & it blew (5A x 7v =35W attempted discharge) |
The charger reduces discharge current such that the maximum power rating is not exceeded. I guess there is no reason to be afraid.
The maximum power during discharge can be changed from the device setup. I have seen more than once that the discharge current I desired could not be obtained, because of the power limit. The current is reduced automatically by the charger. As the battery voltage decreases, the current increases - if I remember it right. Bulent |
Thank you, Junsi! But is it only possible to calibrate the individual cell voltage display, or can I also calibrate the main voltage? I noticed, that on my preproduction 1010B(+), the main voltage is around 0.1-0.3V too high. This is not a problem when I balance charge. But I have a 5s 20Ah LiFe field supply pack, and its cells are connected to individual 1.5A discharge devices, which trigger at 3.66V. When I charge this pack, the discharge devices bleed lots of current, and the charger does not stop. My normal 1010B+ is calibrated just fine, and works well with this pack. |
Santiago - Chile
Joined Jul 2009
Problem With 1010b+
yesterday I tried for the first time my new 1010B+ with factory settings I tried to charge a 3S 2.250 mAh LiPo (50% rest capacity). After more then 70 minutes the charger did not finished charging. Strange was that the iCharger and LogView showed: Input: 12,682V
Voltage accu 12,807 V (!!!!) Cell 1: 4,011 V Cell 2: 4,023 V Cell 3: 4,031 V Capacity: 632 mAh Checking with a multitester and a LiPo checker confirmed the cell values above and showed also a rest capacity of 75% Look also attached file. Thanks for any help! |
Jerez De La Frontera La Parra, Spain
hello!
sorry for my English, I do not understand com being so good is necessary to calibrate them. if I do not have accurate industrial meters.¿? less updates and more calibrations. I have bought to charger that I must fit is not serious. thanks |
So. Cal.
What was the charge rate set at? Did the display on the charger indicate that it was actually charging? You did hit the start button the second time to confirm charge initiation? Mark |
It can not only calibrate the individual cell voltage, but also the main voltage. Regards, Junsi |
Santiago - Chile
Joined Jul 2009
Yes, the display and Logview indicated CHARGING ![]() Yes, I hit the second time the start bottom to confirm the cell count. Well I made the firmware update to 3.10. And tried to charge a 6S 2.200 mAh Lipo with 84% rest capacity (almost full). After 90 minuts the charging current was at 0,01 A and the cell voltage between 4,16 and 4,18 and the charger did not stopped. Then I tried another 3S LiPo 850 mAh from ThunderPower: 4,02 V per cell thats it. Same as yesterday wit the 3S LiPo 2.250 mAh from Rhino. Ohh yes, I have the additional adapter-board for the TP LiPos ![]()
Would you pls press STOP button for 3 seconds, to check the individual cell voltage? Then you can measure it by multimeter, to see if the difference is more than 10mV or not. If the difference is less than 10mV, then the charger is without any problem. According to your provided data, it's normal. Maybe the problem is that the Cell 2 internal resistance is higher. Regards, Junsi |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
