Old Jul 10, 2009, 03:18 PM
lost is offline
Find More Posts by lost
lost's Avatar
USA, FL, Hobe Sound
Joined Dec 2006
Owner's Manual
Is there a way to know when and if the Manual has been updated every time there is an upgrade?
I also second the previous posts that talk about simplifying the manual and perhaps include a few more pictures for some of the more complicated processes. I have yet to be able to store my settings in save settings.
Thanks to everyone for all the info this site provides even if some times it is wayyyyyyyyy above my head.
lost is offline Find More Posts by lost
Old Jul 10, 2009, 03:26 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Go to Settings , make any changes you desire such as C to F, Balancing (Storage ) Max, Capacity , timer time out , etc. Now go to Save Settings, scroll to a Mem. # location press Start , seeting now saved.
If you want to use these settings Load Setting ,scoll to Mem# where you stored them press Start and they are now loaded. If you now go to Lithum battery type and set charging rate ,number of cells etc. saved setting will be used.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Jul 10, 2009, 11:39 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by everydayflyer
So page 18 of maual states 208B can be used to monitor cells when using other devices to charge or discharge Lithium pack.
How?
If I go into Monitor mode I have to connect main power leads to get any cell voltage readings and as soon as power lead is disconnected alarm sounds.
Charles
Hello Charles,
When monitoring the individual voltage of the previous 1010B and 106B, the user needs connect main power leads. As for the 1010B+, 106B+ and 208B, actually you need not connect main power leads. This thing happens, maybe caused by the previous chargers, and we will make some improvement in the next upgrading file.
Regards,
Junsi
junsi is offline Find More Posts by junsi
Old Jul 11, 2009, 12:56 PM
jfrickmann is offline
Find More Posts by jfrickmann
Jesper Frickmann
jfrickmann's Avatar
Raleigh, North Carolina, USA
Joined Aug 2005
LogView
I just spend some time getting the 106B+ charger to work with LogView. It looked like LogView connected, but didn't get any data.
The problem was that I was using the .ini file that came with LogView. Use the .ini file that comes on the CD with your iCharger!
That fixed the problem
jfrickmann is offline Find More Posts by jfrickmann
Old Jul 11, 2009, 07:38 PM
RMFISH is offline
Find More Posts by RMFISH
Surrey, BC Canada
Joined Apr 2000
Data logging software
I purchased a 1010B+ earlier this year and it is the best charger I have ever had. I now find that I "Need" another charger. Since the 208 is now released and I do not yet nor do I envision me ever having 10 cell packs, I wonder which charger I should now go for. Is the 208 using the same data graphing software the 1010 used? Logview? Or does it have it's own? How does the 16MB of memory work? If, for example, I charge 5 packs at the field, when I get home and connect to the logging software, does the software download and handle one cell at a time or are all 5 sets of data downloaded to the computer at once?
Everydayflyer, would you recomend the 208? Your advice would be appreciated!! I do not have to make a decision soon since, at the end of this month, I will be flying to the UK for a two month stay, any events you fellows in the UK can recomend that I should try to get to, any clubs that I should visit? I will be in Nottinghamshire which is pretty central.
Robert.
RMFISH is offline Find More Posts by RMFISH
Old Jul 11, 2009, 08:08 PM
jollyrogertoo is offline
Find More Posts by jollyrogertoo
Joined May 2009
Robert.
Robert, I'm due South of you.
I had a similar situation, and bought a 208B after using the 1010b+: both are very fine chargers.
I never use the logging memory, but, when I tried it, as I recall it was necessary to save each "set" of data to a seperate numbered memory location, so if you charge 5 bats, you must save each.
I never use this function but man I use the charger daily: my Hyperion Duo 2 and 1010b+ gently weep.
jollyrogertoo is offline Find More Posts by jollyrogertoo
Old Jul 11, 2009, 09:55 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
I would certainly recommend the 208B as a good companion to your 1010B+. The built-in logging is a great feature and the 20A charge rate is exceptionally useful if you like short charge times for A123 or 5C-charge-capable lipos.
The built-in logging will append all the data for multiple charge cycles to a single file OR you can save them to separate files, it is entirely in your control.
kgfly is offline Find More Posts by kgfly
Old Jul 12, 2009, 01:25 AM
marc1 is offline
Find More Posts by marc1
I will be an angry old man!
marc1's Avatar
Canada, MB, Division No. 9
Joined Apr 2007
Strange problem with new firmware... I installed the new firmware a few days ago. I tried to use the charger today but the LCD went a little crazy... is this a firmware bug or a hardware problem?
A bunch of chinese characters start flashing on the screen and the charge stopped after 200mah for a 1700mah cell??
Photos attached and see the video on vimeo:
problem charger... (0 min 5 sec)
marc1 is offline Find More Posts by marc1
Old Jul 12, 2009, 12:35 PM
Joined May 2009
http://www.vimeo.com/5558500
Yikes! I have one, and just updated-can you try updating, again and report back?
Now, I'm scared!
Old Jul 12, 2009, 06:39 PM
RMFISH is offline
Surrey, BC Canada
Joined Apr 2000
Updating firmware
Junsi,
It would seem that there is a problem with the update function, using the USB port and the download software. I have not yet upgraded my 1010B+ but feel reluctant to do so if it could end up making my charger useless as with the previous poster. If I buy the 208, as I would like to, am I going to be able to relyably update it??
I also have a problem with my 1010B+, when taking a cell resistance reading, if there are more than 3 cells, the 3rd cell and 4th and higher read garbage, such as 115,155Ohms. I can only read 2 cell packs. If I do a voltage reading during ballance charging, I can read all cell votages without a problem. Am I going to have to send the charger back to China for service??
Your advice would be appreciated. Other than the above, the 1010 is a terrific charger.
Robert.
Old Jul 12, 2009, 06:56 PM
Wyn is offline
Wyn
Find More Posts by Wyn
Wyn
VoltMagic
Wyn's Avatar
Joined Apr 2007
Just a thought, Robert. Sounds like sending it back for repairs is inevitable, unless the problem is with whatever firmware version you currently have. Might as well give it a try...
I've upgraded the 1010B+ several times, including with 3.10 without issue. However, loading firmware on anything has it's risks - especially if there is any interruption of power or bad connection.
Robert.
Wyn is offline Find More Posts by Wyn
Old Jul 12, 2009, 10:07 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hello Robert,
This bug has been solved in 3.10 software version, and the useless garbage message would not displayed after you upgrading it to 3.10. Would you pls have a try and tell us the result?
Regards,
Junsi
Old Jul 12, 2009, 10:12 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hello Wyn,
Would you pls upgrade your charger for one more time? After upgrading, you can see if there is any problem in other modes.
Regards,
Junsi
Old Jul 12, 2009, 10:17 PM
Wyn is offline
Wyn
Wyn
VoltMagic
Wyn's Avatar
Joined Apr 2007
Hello Junsi, there is a misunderstanding. No problem here, all the upgrades have worked fine for me. I was suggesting that Robert give upgrading a try, and that loading any firmware (to any microprocessor) has some small risk.
Old Jul 13, 2009, 01:54 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hello Wyn,
Sorry, I made a mistake. This suggestion should be answered to marc1.
Regards,
Junsi
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 03:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 01:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 04:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 09:55 PM
