Old Apr 19, 2009, 01:29 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by mrforsyth
The reason for this is that the voltage drop in the charge leads becomes negligible when at the end of CV mode when current tapers to 1/10th original charge value, resulting in a fully charged battery with or without charge lead voltage drop compensation.
In my opinion, if one wishes to have the benefit of slightly reduced charge times when charging packs without balance taps, it is best to reduce voltage drop by using either heavier gauge charge leads or shorter charge leads.
Mark
Good thinking, the end of the CV phase would have a very small drop, however we must still consider what happens to the cells right at the beginning of the CV phase. We are mainly concerned with damaging cells by pushing them beyond 4.20V.
Not that it matters much, but as kgfly and I noted, the voltage drop cannot be reduced with better/shorter leads because 99.9% of the voltage drop comes from the charger's FETs.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Apr 19, 2009, 01:36 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I understand and echo this concern. However, is there any reason to believe that the iChargers are even slightly going beyond 4.20V/cell as measured at the pack? I've read no such reports but even if they did go slightly beyond 4.20V momentarily there would be no ensuing catastrophe.
Even if this were a concern, the iChargers allow one to configure a slightly lower termination voltage that will put this to rest. I, for one, have configured mine to terminate at 4.18V/cell in hopes that I'll achieve slightly improved cycle counts.
Love my iChargers!
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 19, 2009, 01:42 PM
Mighty Manfred is offline
Find More Posts by Mighty Manfred
Joined Mar 2009
I've done the same, Mark!
Mighty Manfred is offline Find More Posts by Mighty Manfred
Old Apr 19, 2009, 02:23 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Kev
How can the voltage drop push a cell beyond 4.20V? It's the other way around (premature entering av CV phase). ICharger is only allowing 'slightly' higher pack voltage if cell voltage is known. Trying to compensate for voltage drop for packs without taps is not worth the risk.
I fail to see what the FETs has to do with this. Voltage at output is total cell voltages and voltage drops over whatever is connecting the cells to the output. The displayed voltage on the display of the ICharger matches what you will get using a DVM at the output.
Fred
flarssen is online now Find More Posts by flarssen
Old Apr 19, 2009, 03:39 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Love my iChargers!
Mark
Mark, I love my iCharger too!
I had that thought, about terminating at 4.18V/c, but I avoided saying it because it's almost like giving up on the problem. This is a good trade off between cell life and a full charge, so I plan on setting up an "Unbalanced mode"; saved settings with lipo termination at 4.18v just for use with those packs.
Old Apr 19, 2009, 03:57 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Fred
Well Fred, you're 100% correct. I just checked with my BK meter and the voltage at the banana plugs was an exact match to the display (down to the 1/100V). The voltages taken from the unplugged balance taps (at 2A charge current) were about 0.03V lower. I knew there was some resistance, but I thought it would be much less than that.
Thanks for motivating me to get out my good meter and do some probing. My BK meter is stored so it's not easily accessible, so I mostly use my (not so precise) ratshack meter and other ppl observations in it's place. Now it's clear I was very wrong about the lead impedance being negligible.
Anyhow, I must retract everything I've said about the vdrop being a problem. The iCharger voltage measurement methods are in fact exact, wether or not you use a balance plug. I agree with Fred, the 0.05V/A correction is not worth the risk of having cells over 4.20V during every charge. While adding compensation would likely not damage a battery noticeably, it just seems like it would be going too far IMO.
Kev
Old Apr 19, 2009, 04:42 PM
Joined Mar 2009
Whoa! Have we come full circle? What does this mean in lay terms?
Old Apr 19, 2009, 07:39 PM
So. Cal.
It means to simply use your iCharger and charge happily ever after knowing that there's no charger in existence that will better care for your battery investment.
My 2 cents anyway!
Mark
Old Apr 19, 2009, 07:49 PM
Joined Mar 2009
Yes, that's what I thought. So, the sky isn't falling, right?
Old Apr 19, 2009, 08:13 PM
So. Cal.
To use a fonz-ism, correctamundo. The sky isn't even a bit loose, let alone falling.
Mark
Old Apr 19, 2009, 08:33 PM
Joined Mar 2009
Status quo ante, my favorite charger!
Old Apr 20, 2009, 12:28 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Lol :d
Old Apr 20, 2009, 10:28 AM
FenceMagnet is offline
Find More Posts by FenceMagnet
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
While I agree with your overall sentiment, the bolded part of your post is simply not true... if the balance leads were used to monitor the total pack voltage, this could NEVER happen.... for such a simple firmware change, the lead resistance is mitigated and the battery pack voltage is more accurate during charge... I agree that as the pack gets into CV mode, the difference essentially disappears, but it will take longer to charge...
FenceMagnet is offline Find More Posts by FenceMagnet
Old Apr 20, 2009, 10:37 AM
Joined Mar 2009
Deja vu, all over again!
Old Apr 20, 2009, 12:50 PM
So. Cal.
Understand that individual cell monitoring and charge lead voltage drop compensation that you have described has always been an included feature on the iChargers since first release. This feature is active during balance mode lipoly charging. The charger will drive current at the set value until at least one cell hits the default 4.20V and then begins tapering current (CV mode). No firmware change needed.
The first time I witnessed this I was impressed.
Mark
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
