YeeHaw!!! I finally figured out a way to auto scale the axis. The updated file is now on my blog.
BTW, I had to change the formatting of the imax and imin lines since my new method put too many marks to tell the difference between say + and o. So I made them different colors, with a bright teal for imin so we can easily see it when imin=0. I also changed the formatting of the Prrating and Pcrating lines. Now I think it's easier to tell they're both max's and which set of curves they go with (external is all dots and internal is all solids). As usual, let me know what you guys think about the latest iteration so I can improve it. Fortunately, I think this may very well be the final release of my tool. I wouldn't have done all this work without the help and guidance of rcg members! ![]() Cheers, Kev |
Excellent work Kev! Do you ever sleep? I have deleted my spreadsheets from this thread because they were solving a different problem: I was trying to pick the external resistance such that any valid current could be chosen to keep the iCharger below it's recommended power level.
I also have a recommendation for your spreadsheet: create an error flag when imin > imax which can happen when the power ratings of the resistors are too small. [FYI Kev - if you would like a copy of your spreadsheet that I modified, PM me your email. I do not want to post it here to avoid confusion to others.] I have created a resistor value table using your spreadsheet as help. The table assumes you have up to 24 of 50W 1 ohm 1% resistors. I found these to the be most economical (in my opinion) for this application because they are about $4. each. Note that you only need more than 12 of these for some specific cell counts and current levels. I have used the same parallel/serial nomenclature as is used with LiPo batteries. For example, 3S2P means 2 strings of 3 resistors connected in series. Both of the strings are then connected in parallel. Also I have supplied some alternate choices if you want to use a smaller number of resistors for some cell counts. [I can't get the columns to line up right. I thought the CODE tags would use a fixed space font but the "space" seems wrong? ]Code:
Array of 50W 1ohm 1% resistors 106B+ (6 cell, 7.0A max) 1010B+ (10 cell, 7.0A max) LiPo n Current 1 2S3P 6 6.2A 2 5S4P 20 6.7A (4S3P 12 6.2A) (3S2P 6 5.5A) 3 2S1P 2 6.2A (4S2P 8 6.2A) 4 5S2P 10 6.7A 5 3S1P 3 7.0A (6S2P 12 7.0A) 6 4S1P 4 6.2A 7 9S2P 18 6.5A (5S1P 5 5.8A) 8 5S1P 5 6.7A 9 6S1P 6 6.2A 10 6S1P 6 7.0A LiFe n Current 1 2S3P 6 6.2A (1S2P 2 7.0A) 2 5S4P 20 5.7A (4S3P 12 5.3A) (3S2P 6 4.8A) 3 5S3P 15 6.4A (2S1P 2 5.3A) 4 7S3P 21 6.1A (5S2P 10 5.7A) (3S1P 3 4.8A) 5 3S1P 3 5.9A 6 7S2P 14 6.1A (4S1P 4 5.3A) 7 4S1P 4 6.2A 8 9S2P 18 6.3A (5S1P 5 5.7A) 9 5S1P 5 6.4A 10 6S1P 6 5.9A --------------------------- Array of 50W 1ohm 1% resistors 208B (8 cell, 20.0A max) LiPo n Current 1 1S4P 4 16.6A 2 2S4P 8 16.6A 3 2S3P 6 18.7A 4 3S3P 9 16.6A 5 5S4P 20 16.6A (4S3P 12 15.6A) 6 4S3P 12 18.7A 7 6S4P 24 19.4A (5S3P 15 17.5A) 8 6S3P 18 16.6A LiFe n Current 1 1S4P 4 14.3A 2 2S4P 8 14.3A 3 2S3P 6 16.0A 4 3S4P 12 19.0A (3S3P 9 14.3A) 5 3S3P 9 17.8A 6 5S4P 20 17.1A (4S3P 12 16.0A) 7 4S3P 12 18.7A 8 6S4P 24 19.0A (5S3P 15 17.1A) 9 5S3P 15 19.2A 10 6S3P 18 17.8A |
Kev |
Happy Easter Everyone!
Chip Geek, very nice follow up! That list is indeed very useful for those hunting for resistors for D+ mode. Next thing you know, the vendors are going to sell prewired complete resistor kits; I want a cut in the profits if they do, lol. Normally I get 6hrs of sleep, but once I have my mind set on a challenge, sometimes it's hard for me to put my pen down and go to sleep, lol. I think I inherited my dad's OCD! ![]() ![]() Cheers, Kev |
Joined Mar 2009
So what's the latesting thinking on Icharger quality, both as to design and workmanship?
I read a comment from Everydayflyer in the Hyperion thread which, I think, said something like, "Just when everything looks good for the Icharger, some new issue comes up." Now, bear in mind I have a bias for the Icharger (I have a new 1010b+), and so far, (a few days), it seems to be a good "second" charger (after my Hyperion Duo II), with a great price from a very fine American retail seller (progressiverc.com). So, again, what comments do folks have, good, bad or indifferent (if you don't have one, please say so in your comment)? |
![]() - Dan |
The only "ding" I'd put on iCharger is the fan. It seems like a cheap one. I bought 3 106b+'s at the same time, one for myself and 2 for my buddies. After a few hours of running, all 3 fans have developed a mechanical clicking noise. It definitely sounds like the bushings are already going bad, rather than PWM pulses. No biggie, since I have an extra ball bearing fan from my pc projects that I plan on dropping in after the stock one fails. Even if I didn't have an extra 40mm fan, I could go to Fry's and get one for a nice ball bearing one for around $5, so IMO this is a non-issue considering the price of iChargers. Other than that mine has had 0 problems, and I've used it anywhere from 3-12 times per day, leaving it on 24/7. I regularly use the balance, store, expanded discharge, and internal resistance features. It runs cool. I even noted on a very low humidity day last week, my wife and I discharged static electricity (large amounts, that weren't exactly "painless" ) on my iCharger's case at least 10 times without a single glitch.So far so good, Kev |
Joined Mar 2009
I had the 106b+ for a week or so, and I moved to the 1010b+ since the former had an IR measurement peculiarity.
I noticed immediately that the 1010b+ buttons had a firmer mechanical feel, the fan is quieter (a little) and runs far less often. So far, so good! The Duo II was bought some time ago to use at home, and to charge or "store charge" large numbers of batteries so I can get to the field faster or reduce the time for storage charging. I find the Icharger's settings far more intuitive or easier to access. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
