Old Mar 23, 2009, 10:36 AM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Thanks David !
Bill Bergman is offline Find More Posts by Bill Bergman
Old Mar 23, 2009, 10:53 AM
Mera'din is offline
Find More Posts by Mera'din
Mera'din's Avatar
Joined Dec 2006
Thanks for the info! So, you can set your own numbers for the discharge, etc...What I don't like about my current charger is that the discharge cutoff is set by the cell count. 3s lipo is 9volts, etc...
I am still confused by the power supply. The charger is listed as a 250 watt charger, if I buy a 250 watt power supply I wont be able to use all 250 watt of power?
Mera'din is offline Find More Posts by Mera'din
Old Mar 23, 2009, 11:26 AM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
You're welcome, I'm more than happy to help.
As far as power supplies and output power: power in does not exactly equal power out. Some % inefficiency must be allowed for to account for the power conversion within the charger. In my experience the iCharger is one of the more efficient chargers on the market, with a measured efficiency in conversion of 85-93% depending on input voltage/current and output voltage/current.
For example, charging 6S at 10A would require 252W (6x4.20Vx10A=252W) output. To output 252W would require ~280W (252W/90% eff.) input assuming 90% efficiency in the conversion from say a 15V input to 25.2V (6s Lipo voltage) output.
Hopefully this helps and makes it a little more clear.
Cheers,
David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Mar 23, 2009, 01:59 PM
Ubu is offline
Ubu
Find More Posts by Ubu
Ubu
Michigan
Originally Posted by Bill Bergman
I have a PS rated at 12vdc 30amps 450 watts. With no load it measures 12.2 vdc. Is the voltage too low to work efficiently for the 106B+?
Something is off there as 30 amps at 12 volts is 360 watts.
Ubu is offline Find More Posts by Ubu
Old Mar 23, 2009, 02:34 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Yeah, but better "12V" powersupplies allow the voltage to be tweaked up to 14V.
Julez is offline Find More Posts by Julez
Old Mar 23, 2009, 02:45 PM
Firefox675 is offline
Find More Posts by Firefox675
Firefox
Firefox675's Avatar
USA, KS
Joined Oct 2005
Poll
New poll
http://www.rcgroups.com/forums/showthread.php?t=1021494
Firefox675 is offline Find More Posts by Firefox675
Old Mar 23, 2009, 03:25 PM
Houston, Tx.
Joined Jan 2003
Here the power supply
http://www.rcgroups.com/forums/showthread.php?t=1007850
maybe 450 is the total of all outputs....
Old Mar 23, 2009, 03:30 PM
Joined Dec 2006
Yep, 450W would be the total of all outputs. It's 30A max. on the +12V line.
- David
Site Sponsor
Old Mar 23, 2009, 03:38 PM
Houston, Tx.
Joined Jan 2003
Thanks again David.
Old Mar 23, 2009, 03:49 PM
Mera'din is offline
Mera'din's Avatar
Joined Dec 2006
What power supply do you reccomend for the 106b+ that can be tweaked?
Old Mar 23, 2009, 05:04 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
The meanwell 12V power supplies go up to 13.8V, and come in all kinds of power ratings:
http://www.rcgroups.com/forums/showt...38#post9788538
Old Mar 23, 2009, 08:29 PM
Mera'din is offline
Mera'din's Avatar
Joined Dec 2006
So I think I have narrowed down the choice of power supply to two. One of them is from a member on the site, everything looks great. the other is from ebay. I'd rather buy from a member here but the one on ebay has a pot on the side to adjust the voltage up to 13.2 amps.
Will the 106b+ be able to output full power at 12 volts with a 30 amp power supply. Here is the link.
http://www.rcgroups.com/forums/showt...t=power+supply
The ebay charger is here.
http://cgi.ebay.com/12V-DC-29A-350W-...QQcmdZViewItem
Which one will work better for the icharger?
Old Mar 24, 2009, 02:21 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
As per the manual, maximum output power requires at least 13.5V input. I recommend a 13.8V supply as this is the most common voltage above 12.0V and is widely available. If you are in the US you might consider the supplies like this from Hobby-Lobby which are properly enclosed with all connections and leads provided. This is much safer than an SMPS module with exposed connectors. It depends on your skill level/confidence in handling dangerous voltages and on whether you have young children or pets around !
kgfly is offline Find More Posts by kgfly
Old Mar 24, 2009, 09:17 AM
Mera'din is offline
Mera'din's Avatar
Joined Dec 2006
So you would reccomend the ebay charger due to it's afjustable voltage.
Old Mar 24, 2009, 10:23 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
I would.
The additional benefit is that you can charge lead acid batterys directly with a current-limiting resistor with a 13.8V power supply.
I use my Meanwell a lot, and it works nicely.
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
