Old Mar 13, 2009, 08:14 PM
RMFISH is offline
Find More Posts by RMFISH
Surrey, BC Canada
Joined Apr 2000
No CD
Hello Junsi,
I purchased the 1010+ Charger from Hobby City in HongKong. The charger is the best that I have ever used. I do, however, have a problem. There was no CD ROM disk in the box with the charger, there is a USB cable and a USB port on the charger but no software came with the charger. I would like to update and use the computer software for logging and so on. How do I get the USB software and the download software.
Thank you for a fantastic charger.
Robert.
RMFISH is offline Find More Posts by RMFISH
Old Mar 13, 2009, 08:29 PM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Check the first page of this thread for downloads of software and drivers
Bill Bergman is offline Find More Posts by Bill Bergman
Old Mar 13, 2009, 08:31 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Links to the CD rom image files are available in the first post of this thread. If you don't have software that can unpack the ".rar" format, download and install "7-zip" which is an excellent freeware program.
kgfly is offline Find More Posts by kgfly
Old Mar 14, 2009, 08:17 AM
chris verheyden is offline
Find More Posts by chris verheyden
Belgium
Joined Nov 2002
5s made up of 3s and 2s
Hi,
Can I balance a 5s pack made up of a 3s and a 2s pack, each with it's own balancing connectors, using the standard balancing board ?
If I plug in 2s in the first 2s slot and 3s in the second 3s slot, will this work ? Cells 3, 4 and 5 are then actually on pins for cells 4, 5 and 6.
It would make life easier if it works, no need for an additional cable.
Thanks.
KR,
Chris
chris verheyden is offline Find More Posts by chris verheyden
Old Mar 14, 2009, 01:41 PM
Wyn is offline
Wyn
Find More Posts by Wyn
Wyn
VoltMagic
Wyn's Avatar
Joined Apr 2007
Hi Chris, I'd bet that it should not work because it will look like a 6 cell pack with a dead number 3 cell to the charger.
Wyn is offline Find More Posts by Wyn
Old Mar 14, 2009, 02:40 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
http://www.rcgroups.com/forums/showt...3#post11645193
Julez is offline Find More Posts by Julez
Old Mar 14, 2009, 03:35 PM
jiada is offline
Find More Posts by jiada
Joined Feb 2009
ok tnx..
jiada is offline Find More Posts by jiada
Old Mar 15, 2009, 03:44 AM
Belgium
Joined Nov 2002
I think you're right.
found a simple workaround:
- plugged the 3s in the first 3s balancer connector
- plugged the 2s connector in the leftmost part of first 5s connector on the board. (I had to cut away some of the connector)
Works nicely.
Old Mar 15, 2009, 09:20 PM
Wyn is offline
Wyn
Wyn
VoltMagic
Wyn's Avatar
Joined Apr 2007
Does anyone have a cellpro 10s (or any other IR or impedance tester) and an iCharger? I'm curious about the IR readings of different chargers/testers on the same battery, under the same conditions.
note: I'm not complaining about any chargers IR methodology, just interested in the data.
Old Mar 16, 2009, 07:48 AM
ebnöter is offline
Find More Posts by ebnöter
Joined Jan 2009
USB port issue after V3.09 ubtate
hi Guys.
i have sucsessfully update my 1010B+ to 3.09.
however, now i cant connect my charger with the pc anymore, i have
reinstall the USB driver many time again ,but see the picture it wont reconize
my charger again, also to upgrader will not work anymore, no connection...
Any idees????
ebnöter is offline Find More Posts by ebnöter
Old Mar 16, 2009, 02:00 PM
Belgium
Joined Nov 2002
wrong temp sensor
Originally Posted by chris verheyden
If I plug it in, and try to charge, it stops straight away because of temperature. It's measuring between 60 and 70 ° C (ambient is only 15 - 20°C)
Hi Junsi,
it seems my charger came with an LM34 (Fahrenheit) sensor instead of an LM35 (Celsius).
Can you send me a correct sensor please ? I sent my mailing address in a PM to you.
Chris
Old Mar 17, 2009, 03:28 AM
rizky_p is offline
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
What does firmware 3.09 do in regard to fan setting? can i set fan speed manually?
rizky_p is offline Find More Posts by rizky_p
Old Mar 19, 2009, 02:57 PM
V0RT3X is offline
Find More Posts by V0RT3X
Slovenia (EU)
Joined Mar 2009
Is the 106B+ able to charge two 3s 5000mah lipos at 1C? (or somewhere there)
V0RT3X is offline Find More Posts by V0RT3X
Old Mar 19, 2009, 04:13 PM
kgfly is offline
Joined May 2006
2 x 3 x 3.85 x 5 = 116W charging power required. The 106B+ is 250W/10A capable so yes, it certainly can.
Old Mar 20, 2009, 06:50 AM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
I may buy one of these, probably the 106, but what is the minimum input voltage for charging 2S or 3S at 10A? Can I charge these batteries at 10A with a 12V lead acid battery on the field?
The specs talk of 13.5V input voltage for high power charging; with a 12V battery that does not seem very possible, as much as I know. Maybe for a short time, with a freshly charged battery.
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
