Old Mar 06, 2009, 07:57 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by Bill Bergman
Also are there any plans for the pc connection to control the charger?
Hello Bill,
Thank you for your appreciation. But sorry to say that now we do not have any plan for the pc connection to control the charger.
Regards,
Junsi
junsi is offline Find More Posts by junsi
Old Mar 06, 2009, 08:07 PM
Bill Bergman is online now
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Thank for the reply Junsi, pc control is not that big of a deal when it comes to just charging batteries
Bill Bergman is online now Find More Posts by Bill Bergman
Old Mar 06, 2009, 08:25 PM
grimgrinnin is offline
Find More Posts by grimgrinnin
I think I like vanilla...
grimgrinnin's Avatar
USA, AZ, Surprise
Joined May 2007
Originally Posted by write2dgray
Nope, that shouldn't be it. What type of power supply are you using and what gauge charge leads are you using (both at battery and from charger)?
- David
Ding ding ding!
I re-wired my A123 pack with 10 gage wire, and it'll now charge up to 10 Amps.
Thanks!
grimgrinnin is offline Find More Posts by grimgrinnin
Old Mar 06, 2009, 08:41 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by gonzalix
I can not get much from logview as my conection breakdown comes just few seconds after I confirm the number of cells and before the display show the charging process.
It happens too in the storage or discharge modes, balance chg, fast charge, etc.
I f i go for Monitor mode I can see that the input Voltage switches between 13,957 and 13,963 volts normally each 6 seconds, but not always each 6 seconds. It is a Ripmax Pro-Peak regulated power supply 13.8 volt 0-20 Amps.
Hello gonzalix,
Would you pls change a steady input power supply and have a try? Or you can use a Lead-acid accumulator. Pls tell us the result after you test it.
Regards,
Junsi
Old Mar 06, 2009, 10:38 PM
Kostya is offline
Find More Posts by Kostya
Sydney, Australia
Joined Feb 2009
Originally Posted by Kostya
I am sorry...
Probably it was discussed.. But I could not find it...
Can I take this twin 2x3S->6S cable
http://www.hobbycity.com/hobbycity/...ead_(2_x_3S)6S_
to charge two 3S batteries with 106B+ charger?
Is there any reason not to do it?
Originally Posted by BlueAngel2000
You can use it, but not for more than about 2A charge current.
Thanks. Is it much slower then a single battery current? What current can I use for a single battery?
Kostya is offline Find More Posts by Kostya
Old Mar 06, 2009, 10:48 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Up to 10A. The rate at which you charge a battery depends on many factors including the chemistry, capacity, quality, rating and your preferences to trade off speed of charging for battery lifetime.
kgfly is offline Find More Posts by kgfly
Old Mar 06, 2009, 11:41 PM
Kostya is offline
Sydney, Australia
Joined Feb 2009
Oh, sorry
I was talking about 2200 mah 3S LiPo 20C battery. Really don't know what is recommended current for it.
Old Mar 07, 2009, 12:05 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Oh, sorry
Do You mean it really seriously?
I think that then You really should read the sticky at the top of this forum!
http://www.rcgroups.com/forums/showthread.php?t=209187
coro is offline Find More Posts by coro
Old Mar 07, 2009, 08:20 AM
Kostya is offline
Sydney, Australia
Joined Feb 2009
Sorry for a stupid question. Read a lot in past few days. But not everything.
Thank you for pointing in a right direction.
Old Mar 07, 2009, 09:54 AM
ayash is offline
Find More Posts by ayash
Joined May 2008
What is a reasonable charger temperature?
deleted
ayash is offline Find More Posts by ayash
Old Mar 07, 2009, 12:18 PM
magudaman is offline
Find More Posts by magudaman
Joined Jun 2005
With the wire cutter feature, it seems we could use this basically as a variable power supply. For example I have some LEDs that need a very specific current. I should be able to use the 1010B+ to drive at a specific current.
I wouldn't be damaging the charger doing this would I?
magudaman is offline Find More Posts by magudaman
Old Mar 07, 2009, 01:11 PM
gonzalix is offline
Find More Posts by gonzalix
Joined Mar 2007
Hello gonzalix,
Regards,
Junsi
Just tried with a lead-acid accumulator and the problem persists.
Regards
gonzalix is offline Find More Posts by gonzalix
Old Mar 07, 2009, 01:45 PM
Wyn is offline
Wyn
Find More Posts by Wyn
Wyn
VoltMagic
Wyn's Avatar
Joined Apr 2007
Gonzalix, is there any possibility that the main charge leads (from the banana jacks at the charger) have an intermittent/poor connection somewhere? Perhaps this charger is more sensitive to alarm for this then other chargers.
Wyn is offline Find More Posts by Wyn
Old Mar 07, 2009, 02:22 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi!
I tried this too, but it did not work. Before switching on, the charger produces a small voltage like 0.5V. When it senses current then, it ramps up the voltage.
But .5V is not enough to power any LEDs, so no current.
Anyhow, I was at the field today and charged a couple of A123 Packs, and I like the 3.09 update a lot. The fan is quieter now, and I did not get any errors, too.
Thanks, Junsi!
Cheers,
Julez
Julez is offline Find More Posts by Julez
Old Mar 07, 2009, 02:31 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Yes, I have noticed as well that the fan speed is GREATLY reduced or turned off completely now with v3.09 during all of the different charges I have performed. Internal temp. is still kept well under control. Excellent job Jun-Si!
- David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
