Saratov, RUSSIA
Joined Sep 2007
Hello!
Thank you KGfly, Junsi. Quote:
I think, that almost all users of your charger make a own charge lead, and no problem to make another one. |
Joined May 2008
If I want to build the A123 myself, Where can I find to buy connectors for both JST and TP balance adapters? BTW - can't I bypass the board altogether and connect the pack directly to the connector that goes into the adapter boards of the iCharger boards? |
Joined Nov 2004
connctors and balance boards
I bought my boards and connectors from BP hobbies. http://www.bphobbies.com/view.asp?id...9&pid=C2096935
I also bought a bunch of the board to charger balance port connectors for my large packs. I plan to cut them in half and switch the positive around on one of the plugs. I'll solder extensions to extend the leads and end up with two balancing connectors. I'll then connect my A123's packs (7s to 10S) direct to the 1010B balance port. Daryl |
Thanks Julez.
I understand the spark (it is just like whenyou connect the lipo to the ESC), what I don't understand is why sometimes (often) there is no spark at all. Is the charger precharging the capacitors to the selected battery voltage? If yes, why isn't it doing it all the times ? regards Marcel |
Joined Jun 2007
How would one rate this charger vs the cellpro 10s?
I bought the cellpro 10s from them around nov 20 and the package was lost via UPS. According to the tracking the package was supposed to be delivered dec 1. FMA put in a lost package notification and said I had to wait for the determination by dec 22. UPS driver came by with a card for me to sign I check marked other and put not received. UPS closed the case. I called up after finding out and they said they are reopening the case but it will take another 8 to 10 days. I called FMA and they will not be able to do anything about this until UPS gives them a determination. I'm a bit fed up. I have had lost packages before and the vendor usually takes care of it right away. I ordered this for my b-day on the 6th and here it is 3 days before x-mas. I have no doubt that if I wait I will not be receiving this until the first week of the new year. This problem and having to cancel my credit cards because of their breach is ridiculous. Sorry for the rant but after all the praises about this company and the experience I have had I'm ready to reverse the charges and order a better charger for less. I can get the iCharger 1010B+ for $170 from hobbycity or the Mega Power Infinity-960SR w/ Balancer 12S for $169. Any recommendations? |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
