Melbourne, Australia
Joined May 2006
I am not too fussed since IR measurement is indeed simply icing on the cake to keep us data junkies happy. There are many different ways to measure IR and you will get different results for the same cells/pack at different DoD and temperatures so as mentioned, the value is in relative measurements on the same pack over time. |
QLD, Australia
Joined Aug 2008
Hi,
I recall someone talking about getting a little zap when touching their power supply and/or the iCharger. But can't remember where it was and can't find it again. I have got two PSU's to use with my charger's and i'm getting this little zap when i touch just about everything and i'm concerned (plus its damn annoying!) and want to see if i can find out if it is dangerous and if i can fix it. Does anyone have a better memeory and can link me to the start of those posts/topic? cheers |
QLD, Australia
Joined Aug 2008
thanks kgfly. I new it was in this thread but coudlnt find it, its to big! The PSU's i got are the A20 from hobbycity http://www.hobbycity.com/hobbycity/s...y_for_Chargers
When i get home this arvo i'll have a read back through this thread. |
Australia
Joined Mar 2004
prolly has been mentioned plenty times before. Ive done about 20 charges so far on the 300w version. charging 10s 5000mah.
Likes -charger stays cool -simple -well presented -small -powerful. dislikes -I would like all my cells to be 4.2 volts at the end of a charge, they are always ranging between 4.18,4.19,4.20. As long as they are not over 4.2 im not overly worried, but would be nice if it was more acccurate. -When charging a 99% full pack, it seems the charger ramps up the current at the begining, then it figures out the pack is full, and slowely ramps the current back down. Bit worried that this high current on a full pack may shorten the life of the packs. -Also again im not sure how critical it is, but many other chargers like my orbit microlader pro ramp the current up more gently, instead of applying 0 to 5 amps in 2 seconds if you know what i mean. my 2 cents |
Joined May 2006
Which charge program are you using ? If "Charge" this explicitly does not balance the cells. Use "Balance" to balance the cells. If the cells are still not as close as you would like it is possible the packs are no longer as well matched as some others. You could try setting the Balance Speed to "Slow" and running a "Balance" cycle, which should bring the cells all very close.
Right now I'm using a 14v, 5A laptop power supply, simply coz I don't go over 2s in my lipo. |
Hi, I advise to set the balance speed to "slow", and the "balance tickle" option (or something like this) to "on".
This will make the charging process last longer, but as the final current is extremely low, all cells will be charged as full as possible. I use this mode all the time, but I do not neccesarily wait until the charge is completely finished. When I am in a rush, I take the pack although it is only 95% full. |
QLD, Australia
Joined Aug 2008
hyperscorpic,
G'day Yep thanks mate. I remember reading your posts as you were dealing with it real time, and its those i was trying to find ( have found them, all good). I know an electrician or two so i'll get them to suss it out and see if they can find a problem and fix it. Don't have any other pSU's and i am TOTALLY sick of using a car battery while charging at home. So yeah, i really want to use them as they seem like great units this issue aside.
kgfly, got any links to that PSU u mentioned? |
Joined May 2006
This one (3-15V Regulated 23 Amp Heavy Duty DC Power Supply = 345W, $149) is a nice linear supply, but large and heavy: http://www.dse.com.au/cgi-bin/dse.st...uct/View/D3800
This one (Lab Power Supply 13.8V DC 23A = 317W, $99 but often on sale for less) is a nice SMPS. I don't like buying open cage SMPS and then spending money to make them safe with children in the house so am happy to pay for one in a case with a switch and connectors: http://www.dse.com.au/cgi-bin/dse.st...uct/View/Q1755 BTW there is a typo in the specifications online which should read: "Current : 23A continuous (25A for 1 min, 50% duty cycle)" The 345W linear supply should run the iC1010B+ at its full rated 300W output. The small 317W SMPS will probably only support up to about 275W charger output power. |
Saratov, RUSSIA
Joined Sep 2007
Hi!
I have received my 106B+ from UH. Very interesting toy ![]() I wish to say many thanks to all man who write this very long tread, and make for this charger so many. Hi Junsi! may be you will add some function... As I understand, disharge with external resistor work with only Li chemistry. May be add to all chemistry accu? When used external resistor, internal not used, that is? May be made as is in Schulze? external added to internal. For example: set disharge rate at 10A external can dissipate 8A, internal added 2A. External 7A- internal add a 3A. At other side, if used external resistor, charger do not have high temperature, and me is quiet ![]() If I use external resistor for discharge, why I limited with 7A? for selecting or test accu I need at list a 10A, 30A is better Second quiestion... When I use LogWiew with cycle function, after first stage chg or dchg, when new stage is begin- the main window of programm when placed chart become clear, and chart start as first run. May be do not clear chart after first stage of cycle? Third question. 6S- 10A is about 220Wt of power. Maybe redistribute power is possible? For example: with parallel charging as Jules and phisics wrote, charge current must be combined... Power is I*U, P is constant, Can you increase Current and decrease Voltage? For example 220Wt=7.4V*30A(for 2S accu) As I known, modern tranzistors marked with not only A(current) but and Wt. Right now, I thinking about second hand for my Duratrax Ice. Jog dial is very nice... I will miss without them. And I think about second charger. First pretender is MegaPower Infinity AKA Robbe PowerPeak III. Three positives have this charger. Big display, jog dial... and 10A 12S balance charging. Second pretender is 1010b+. Say please, maybe in future, with software update 12s charge is possible? In any case, thank you very much for your attention and time. I have recomended your charger to my friend. Sorry for my bad english. Pavel. Russia, Saratov. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
