Old Nov 29, 2008, 01:39 PM
natterjak is online now
Find More Posts by natterjak
Asks too many questions
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
Originally Posted by kgfly
Working from memory since mine is not to hand, once in Lithium mode, hit Start, the "LiPo" in the top left corner will blink. Now with Up/Dwn you can cyle through LiPo, LiFe and LiIo.
Thanks kgfly - I knew it would be something obvious...!
natterjak is online now Find More Posts by natterjak
Old Nov 29, 2008, 02:11 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi Chewy!
I belive there are main leads with alligator clips included.
I think it is hard for the manufacturer to include the correct leads: One person flys Deans, I fly Multiplex, the next flies 4mm/3.5mm/2mm bullet connectors, the next one BEC
The included main lead would be wrong in 90% of the cases.
I make all my leads myself
Julez is offline Find More Posts by Julez
Old Nov 29, 2008, 09:14 PM
akshaw is offline
Find More Posts by akshaw
United States, PA, Plymouth Meeting
Joined Jan 2006
Is there any need to connect the icharger to a power supply when using the usb cable to connect to a pc?
akshaw is offline Find More Posts by akshaw
Old Nov 29, 2008, 09:19 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
No, not when updating the 1010B+ or 106B+, but they should all already be running the latest version software V3.08.
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Nov 29, 2008, 09:26 PM
akshaw is offline
Joined Jan 2006
Thanks. You just saved me a step. I was about to load the upgrade. So far I like this charger. Pretty much just plug and play.
Old Nov 30, 2008, 01:29 AM
lost is offline
Find More Posts by lost
lost's Avatar
USA, FL, Hobe Sound
Joined Dec 2006
2 Questions
Just ordered my 1010B+ and downloaded manual to get familiar. I noticed in manual that there is nowhere to enter the number of cells in ni-cad/nimh charging and discharging. How does the charger know if there is a bad or weak cell in the pack, and how do I know it does not charge an 8 cell as a 6 cell or a 4 cell pack as a 6 cell.
2- I downloaded logview and selected English but lots of info is still in German and the help menu is all German. Is this normal and is there an english help menu somewhere. Thanks
lost is offline Find More Posts by lost
Old Nov 30, 2008, 01:51 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
I found the same thing. I think the English translation is very limited to just the main menu.
kgfly is offline Find More Posts by kgfly
Old Nov 30, 2008, 06:11 AM
bruno95 is offline
Find More Posts by bruno95
Joined Apr 2007
Hi,
I'm new owner of 1010B+ charger but got one issue on Internal resistance measurement on individual cell of lipo battery...
Ir is wrong on the 2 first channels...
Let me explain:
On brand new 6S 5000 lipo packs, the 2 fist channels were always giving me really low Ir value (like 2m Ohms, 4 mOhm where other channels are in the level of 12mOhms)
I could reproduce this for every pack measured.
So i made antother test:
For this test, i'm using 2 3S2500 packs connected in series.
Here is the measurement with 2 packs in series in 1st order
Here is now measurement when inverting the packs in the serie order (1st pack becomes second).
Normally measurement of cell 1,2, 3 of 1st measurement should be now shown on cell 4,5 and 6 but as you can see it is not the case...
Any suggestion or feedback is welcome because actually this functionnality is not accurate and then not usable.
I'm using version 3.08 of the software (but was same on previous version 3.07)
Bruno.
bruno95 is offline Find More Posts by bruno95
Old Nov 30, 2008, 06:12 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
There is no need to know the cell number to make the delta peak termination work right. The delta peak termination only compares the different voltages over time, so the differences in voltage, and not the absolute voltage is important.
But I think the charger estimates the cell count judging from the voltage it has to provide while charging.
When you use a voltage-sensitive charge algorithm, like the forming charge mode, you have to enter the cell count manually.
Old Nov 30, 2008, 07:49 AM
kgfly is offline
Joined May 2006
Note that LogView 2.4 (2.4.5.203) is now available. Support for the Junsi iChargers is now integrated into the standard distribution.
Old Nov 30, 2008, 02:23 PM
lost is offline
lost's Avatar
USA, FL, Hobe Sound
Joined Dec 2006
My worry is that If I charge an 8 cell2500mh pack that unknowingly has a few bad or weak cells and the charge terminates early, my pack is not really charged to its capacity and could cause a crash. Or if I charge a 4 cell and the charger charges it as a 5 cell, would I not damage my Battery.
I have read all the posts in this thread and my knowledge is far from yours but it worries me. I have many other chargers and either I have to enter the number of cells or the charger automatically displays the number of cells that is connected, and if wrong it can be changed by user. Maybe I am wrong about this but it is very hard for me to understand.
Would it be very hard for Junsi to incorporate this feature in the charger.
I think that in one of your early posts you mentionned that it would be a nice feature when you were helping designing this great charger.
Old Nov 30, 2008, 05:36 PM
tantive is offline
Find More Posts by tantive
Joined Mar 2008
@Junsi: Thank you for the new firmware.
Just curious about 8s lifepo charging...
Given a PS with > 13.5V, then charging at 8s and 10A will run into current limitation, right?
So the charger will draw more than 10A at the input side for e.g. given 14V input and charge up to (8*3.6V) at the output?
For 4s, 10A lifepo charges I can see about 11 Amps being drawn at the input (14V).
tantive is offline Find More Posts by tantive
Old Nov 30, 2008, 06:58 PM
kgfly is offline
Joined May 2006
The charger is a power converter. Due to losses, the input power will always be greater than the output power. I find assumine 80% efficiency is a useful working figure to estimate the input power.
To estimate the input current divied the estimated input power by the input voltage.
Pin = Pout / 0.8
Iin = Pin/ Vin = Pout / (0.8 x Vin)
So in your examples:
8S A123 @ 10A --> Iin = 8 x 3.45 x 10 / (0.8 x 14) = 25A
4S A123 @ 10A --> Iin = 4 x 3.45 x 10 / (0.8 x 14) = 12A
Now when the input and output voltages are similar the efficiency will tend to be higher than when there is a large difference. So your observed "about 11A" for the 4A A123 case makes sense.
Old Nov 30, 2008, 07:01 PM
Joined Dec 2006
Yes, 4S*3.6V = 14.4V, 14.4V*10A = 144W. At 14V supply this would require 10.3A + a certain allowance for efficiency, usually 10-20%.
At 6S lipo, 25.2V and 10A charge = 252W, assuming a 15V power supply this requires 16.8A (252W/15V), let's say 21A min. to be on the safe side assuming 80% efficiency (16.8A/.80=21A).
From page 3 of the 1010B+ manual:
Two input power choices: DC jack with auto-resetting fuse (maximum input current 7A) and butt-welded alligator clips with 4mm bullet connectors (25A)
And page 3 of the 106B+ manual:
Two input power choices: DC jack with auto-resetting fuse (maximum input current 6A) and butt-welded
alligator clips with 4mm bullet connectors (25A).
Looks like the main inputs are good to at least 25A, which is about the max. it would see when working from a 13.5V supply. 25A*13.5V=337.5W, which is just about what you would need to pull on the 1010B+ to run it at max. power.
- David
Site Sponsor
Old Dec 01, 2008, 03:51 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by bruno95
Hi,
Hello Bruno,
We will make more improvement on Internal resistance measurement, but maybe it's a little bit difficult to get a more accurate data presently.
Regards,
Junsi
junsi is offline Find More Posts by junsi
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 03:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 01:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 04:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 09:55 PM
