Joined Jun 2007
Why can't you make your charger pluggable to an A/C outlet? How hard/costly can it be? A $200 plus piece of electronic "wonder charger" and can't even be plugged directly to A/C!?
Hello everyone,
The 3.07 version software of 106B and 1010B upgrading software is releasing now. And this is update notes: http://www.jun-si.com/UploadFiles/Re...s-iCharger.txt Regards, Junsi |
Toronto, Canada
Joined Jul 2008
I've never gone through the process yet, but isn't there supposed to be an .exe updater to use the .bin files with? I can't seem to find it. Edit: JunSi has added a link to a .rar file that contains the .exe updater now. Thanks!
Son, Norway
Joined Sep 2004
I got my 1010B (v3.06) two days ago. The internal inspection showed non of the known issues except the mark in the heat shrink of the coil. Some minutes with a Dremel fixed that, but there is still some pressure on the PCB since there is not enough space between the top of the coil and the case.
I balance charged a 6S and 10S A123 without any problems. Same with a tired 4000 4S Lipo. One thing I noticed is that charging current and cell voltages are not up to date at all times on the display. In CV stage, the charge current is pulsing slowly (the load on PSU varies and cell voltage on a DVM goes up and down), but the displayed values are always the high ones. I hope that capacity numbers are calculated based on more real values. The same goes for the upcoming data output. I'm impressed by the accuracy of the balancing circuit. On the 4S pack i measured it to 3mV difference! None of my packs have connectors that fits the balancing board, so I did what I have done for the rest of my balancers; make a universal adapter. This time I added 7 pins in parallel to the 11 pins. Now I can serial charge two packs (with overlapping balancing taps) or parallel charge two packs (2-6S). Will connect the pin rows by some small 2-3A fuses later for added safety! Fred |
I just updated the 106B to 3.07, and I like it. The discharge current reduce works really nice.
When I set the delta peak to 1mV, my 4s 2000mAh Eneloop pack terminated too early at 600mAh. The I restarted the charge with 2mV, and this time it terminated ok, and the pack was not as warm as previously on 3mV
So. Cal.
http://www.jun-si.com/UploadFiles/upgrader.rar Firmware for your 106B: http://www.jun-si.com/UploadFiles/iC106B_V307.bin |
anyone tried the 1010b 3.07b and upgraded successfully. Just tried for the first time and when I try the BIN file it says file format error. Downloaded it twice now.
-------------------- Third time lucky... now have 3.07. that was painless. thanks to everyone involved with the upgrade pdf... It was easy thanks to you guys... Puffer |
West Linn, Oregon
Joined Mar 2006
106b+ Usb?
Good day Junsi,
Is the USB connectivity featured for the iCharger 106B+ a "virtual com port" i.e. a USB to RS232/TTL interface embedded in the iCharger. Logview currently only supports serial communication which is also I believe a requirement of the JUNSI FW updater. Also, I attempted to download the user manual for the 106B+ which results in repeated Acrobat Reader (V7) fatal errors ? I was able to download the manual after re-installing the adobe reader so my questions have been answered by the manual Best Regards Guenther |
Lab, Slovak Republic
Joined Jun 2008
JunSi, thank you for hard work
![]() Guys, where can i get usbdriver mentioned in iC106B+_en.pdf manual? Quote:
Sorry to say that the communication port of 106B is used in other way, thus it can not support the “Open Format” data of the “logview” software. Regards, Junsi |
Son, Norway
Joined Sep 2004
(http://www.rcgroups.com/forums/showp...postcount=1409) Fred |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
