Severe Discharge
Guys,
I am experiencing a troubling problem with my 1010B (ver 3.06) when charging two 5S A123 packs in series using the adapter board. I don't get this issue when just charging one pack, but since I run the two packs in the same bird as 5S2P, it is convenient that I charge them together. (and the reason I bought this charger) With the charger off (as in not plugged in) I get a severe arc across the main discharge wires to the point where it welds the deans connector! I have already had to replace two pins on the adapter board because it would arc across them as well. I have since adopted this sequence for connecting the packs: 1. Disconnect the adapter board from the charger and then connect the two 5S packs to the adapter board 2. Connect the series dean adapter plug on the discharge wires of the batteries and then connect the series adapter to the charger -slight arc happens at this point -similar to plugging in an ESC to a battery. 3. Lastly, the adapter board is plugged back into the charger and then the charger is plugged into the input voltage source. This is quite annoying, as I don't have to unplug the board from the charger and the charger from the input source when just charging a single. Anyone else experience this? Cheers, Steve |
Hello Steve,
See post #300: http://www.rcgroups.com/forums/showp...&postcount=300 I have melted some deans and the adapterboad aswell. When connecting them as described in #300 it works perfectly. regards /Hans |
Cheers, Steve |
Hello,
I have a problem with my 1010b/v3.06. When balance charging a 3s LiPo at 1c the charge process will not end. (Safety timer ends the process after 2h) It dosen't seem to be any problem with the LiPo after safety timer ends the process, no overcharging or anything... Is there a workaround to this issue? regards /Hans |
Toronto, Canada
Joined Jul 2008
Oh but I just realised the pricing on eHeli is a lot more expensive than Hobbycity. I am aware that eHeli prices is in australian dollars (I think), and Hobby city in USD, but eHeli price is about 2 times the prices shown on Hobbycity. But USD to AUD is not even 1.5 times, let alone 2 times! |
According to your description, I suggest you wait for the releasing of our new upgrading software. Moreover, if you charged it for the first time, it will be longer to end the process, so don't worry about it. Regards, Junsi |
Toronto, Canada
Joined Jul 2008
So for $100-ish you can get 95% of a great charger, and for around twice~ more you can get 105% of it, hehe. It's kinda steep pricing, so it's not an easy decision to make. Took me a few days to accept it after the initial expectation of "a $100 charger," but I don't regret getting it from eHeli. The charger is excellent and this way I'm 100% confident I won't be in the market for a new charger for quite a few years, as this one is completely future-proofed for now. ![]() Of course, you can save money and get it from HC, but keep in mind all the limitations of buying from there. If you're fine with those, then of course HC is a much better deal. P.S. A little note to those familiar with psychology, I think this post is prabably an excellent example of Cognitive Dissonance, hehe. P.P.S. USD and AUD are a lot closer than you think. It's about 1 to 1.15 or so. Keep that in mind (I found out the hard way). |
Son, Norway
Joined Sep 2004
Fred |
Son, Norway
Joined Sep 2004
Looking forward to get the data logging capability in the future .Fred |
West Linn, Oregon
Joined Mar 2006
Hi Junsi,
I purchased the 106B charger to charge LiPo and LiFe batteries safely and efficiently, not to break in brushed motors, cut foam, or function in a crippled fashion as a "lab" power supply. My iCharger 106b, FW revision is 1.06, is fraught with problems of charge completion using "balance" charge options for both LiPo an LiFe. It is incomprehensible to attempt rationalizing how all cells within a battery pack should be discharged simultaneously during balance activities. It appears that whomever the engineer is responsible for the operational code for the iChargers should be sent back to school - maybe absorb the information that the instructor was trying to convey instead of daydreaming of rewards for incompetent performance. I urge you/Junsi.com to forgo adding/supporting divergent features (i.e. foam cutting, motor breakin, etc) and address the issues of product deficiencies with the charger. I am not a happy customer - I would really appreciate having a battery charger that performs as promoted/advertised |
Belgium
Joined Oct 2005
1010b failure after 1 week use?
Hi Junsi,
After a few days of testing I was very pleased with my 1010b charger until yesterday evening.... After selecting the correct charging parameters and pressing the start button, I get the battery check screen and the confirmation screen correctly. When I confirm the celcount, the charger doesn't start the charge, but restarts itself: - there is a very brief blink of the display (backlight off, no text) - I get the "system check, please wait" screen (same as on startup) - I get the screen with system version (3.06), charger type (1010b) and at the right, a triple A (AAA) (same as on startup) - then I'm in the regular menu (same as on startup) I tried with 3 types of batteries (A123 3s, LiPo 3s2200mAh, NiCad 5x1700mAh) all with the same result. I tried different charging/discharging/storeing cycles, all with the same result I tried with and without balancer plug connected, all with the same result I disconnected the charger from the power supply several times, again no result. (The charger comes up with the correct cell count after battery check and gives an error message if no pack is connected, so there is a connection between charger and battery pack) Is there any way I can get this charger up and running again? Thanks, Wim. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
