Old Aug 11, 2008, 04:02 AM
Smeagle is offline
Find More Posts by Smeagle
Munich, Germany
Joined Nov 2003
Originally Posted by whisperdancer
Are these chargers (1010b and 106b) accurate?
I once had an ICharger IC6 and it ALWAYS overcharged my cells (ex: 4.17, 4.00, 4.23 volts on termination, although it always showed 4.20v for the 3 cells on the charger).
I had to sell it, as I was only buying FlightPower Lipos and didn't want them to go bad.
This charger was not "inaccurate", it was BROKEN. And it was really not nice to sell it. You should have sent it back or dump it.
How about these new chargers? I will only charge lipos, and accuracy of the balancer is a major priority...
I have testet 7 different units of 106B and 1010B. The all had perfect accuracy. I compared with my Fluke DMM. Differences were in the range +/-0,005V - that's what I consider "no difference".
- Oliver
Smeagle is offline Find More Posts by Smeagle
Old Aug 11, 2008, 04:11 AM
Smeagle is offline
Munich, Germany
Joined Nov 2003
Originally Posted by tantive
Hello Junsi,
I bought a sealed lead-acid battery (gel cell) to be able to charge my lipos/lifepos at the field.
At home I now have to charge the lead-acid. Using the PB mode of the charger I noted that the charge end voltage is too high and the battery starts to produce gas.
Yes, you should really not charge PB with the iChargers in the state they are now. They chose the "maximum shorttime" voltage (2,45) as CV-voltage, which will kill nearly every PB battery in the long run. It is spec'ed as the voltage, at which the transition between fast charging and standby charging (13,8V) should happen.
So the question is:
Is it possible to make the charge end voltage per cell adjustable in PB mode (as it is for lipo lifepo...)?
I discussed this a short time ago and Junsi is working on it.
- Oliver
Old Aug 11, 2008, 09:47 AM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
- Oliver
Junsi and others that are interested may want to take a look at the following article on Lead-acid battery charging.
Charging the lead-acid battery
The adjustable voltage is a needed change, but it also seems the charge algorithm may need to be modified.
Phoenex is offline Find More Posts by Phoenex
Old Aug 11, 2008, 03:36 PM
Funflyer 112 is offline
Find More Posts by Funflyer 112
Austria
Joined Aug 2007
problem with small 2s Lipos
Hi
I have the iCharger 106B (V 3.05) and i really like it but i have a problem :
When I charge my small Hectronic 350 and 460 mah 2s Lipos in balance mode
the Charger don't finish !
I charge them with 1C
I must dissconnect them because the charger puts in about 600 mAh and still
charges (with a current arround 0,15A) and doesn't finish......I worry about overcharging !
Anyone with the same problem ?
Funflyer 112 is offline Find More Posts by Funflyer 112
Old Aug 11, 2008, 05:09 PM
badger-b is offline
Find More Posts by badger-b
Badger
badger-b's Avatar
UK
Joined Jul 2008
Originally Posted by Funflyer 112
Hi
I think you may need to set the balance mode to be active in CV phase, and "fast". (User settings).
badger-b is offline Find More Posts by badger-b
Old Aug 11, 2008, 10:50 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Hello Phoenex,
Thank you for your provided information and your constructive suggestions.
Our engineer reads it specifically, and deduced that it seems not necessary of the float charge in RC chargers.
And about the settings of the voltage limits, we will collect more opinions and feedback from more users, then give you the most satisfied answer.
Thanks again for your idear!
Regards,
Junsi
junsi is offline Find More Posts by junsi
Old Aug 12, 2008, 04:45 AM
Julez is online now
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
I would make this an option, like the tickle charge. So the user can decide wether he wants float charge or not.
I practically only float charge my PB batterys. This leads to a very long life.
Cheers, Julian
Julez is online now Find More Posts by Julez
Old Aug 12, 2008, 09:32 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Cheers, Julian
Hello Julian,
Thank you for your great suggestions.
We decide to add this feature:
If the voltage is more than float charge voltage, that is 2.25V, then the trickle charge will start automatically.
If the voltage is less than 2.25V, then the trickle charge will turn off immediately.
Thanks again for your support.
Regards,
Junsi
Old Aug 13, 2008, 03:46 AM
Smeagle is offline
Munich, Germany
Joined Nov 2003
As I told, I do this, too. In the link given by phoenex they say:
The topping charge [=CV at ~2,4V/Cell] takes another 5 hours and is essential for the well being of the battery.
This is new to me. What do you think about it? I always thought, its better for the "well being" to only float charge / standby charge (whatever you may call it...) at ~2,25-2,3V...
But in every other aspect the text sounds very sharp and to the point, maybe I will have to revise my standpoint..
- Oliver
Old Aug 13, 2008, 03:52 AM
Smeagle is offline
Munich, Germany
Joined Nov 2003
So you will introduce a set able CV-Voltage fpr PB and depending on that voltage float charge or not...
Very good solution for me!
But how will you do the transition from the set voltage down to float voltage? If you stop charging at 2,4V it will take several minutes until the battery comes down to 2,25V so there will be no current flowing for a "long" time... I would suggest display something like "DONE - Standby Charge" and just wait for voltage to drop...
- Oliver
Old Aug 13, 2008, 04:00 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Three stage in ideal deep Cyle Pb charging.
Bulk 2.46 V per cell
Absorption 2.36 V per cell
Float 2.26 V per cell
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Aug 13, 2008, 04:49 AM
deininju is offline
Find More Posts by deininju
deininju's Avatar
Oftersheim, Germany
Joined Aug 2008
Usb
Hello, i am new in this forum and first would like I all user to greet. There my English not perfectly is please I already in advance around apology . Now to my questions:
The new Icharger 1010 is equipped with a USB connection. Can i update The Chareger over this connection ?
Is a driver necessary and where can i found them?
What kind of more functions/possibilitys this USB connecting have ?
best regards
Jürgen
deininju is offline Find More Posts by deininju
Old Aug 13, 2008, 05:03 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
best regards
Jürgen
Hello Jürgen,
You can give your PM to us, then we will send you the software for upgrading.
Best regards,
Junsi
Old Aug 13, 2008, 06:03 AM
Julez is online now
Julez's Avatar
Germany
Joined Dec 2003
Hello Julian,
Regards,
Junsi
Hi Junsi,
I think you mixed this up accidentally
If the cell voltage is more than float charge voltage, that is 2.25V, then the trickle charge will turn off immediately.
If the cell voltage is less than 2.25V, then the trickle charge will start automatically.
This way, it should work very well.
Cheers,
Julian
Old Aug 13, 2008, 08:14 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Hi Junsi,
Julian
Hello Julian,
Yes, you are right. I mixed it up when I wrote this post.
Kind regards,
Junsi
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
