Old Aug 07, 2008, 05:00 AM
beans07 is offline
Find More Posts by beans07
hamilton Vic
Joined Jun 2006
Originally Posted by Smeagle
I think, you have a very bad pack. At all my testing (even with old defective packs and after dicharging only single cells etc.) I have never seen a cell go over 4,22V. And even 4,22 was only for some few seconds, while the charger was already ramping down current. I started with Version 2.9 if I remember right. What's your version?
- Oliver
The pack is a brand new Flightpower pack. It has had only 12 cycles on it and never discharged below 50%.
Nothing wrong with the pack, the charger was playing up as it did this on 4 seperate packs (2 different brands and all 4 brand new).
beans07 is offline Find More Posts by beans07
Old Aug 07, 2008, 05:09 AM
tuxian is offline
Find More Posts by tuxian
tuxian's Avatar
Austria
Joined Jul 2008
Originally Posted by flarssen
That doesn't sound good! Can you measure to see if the charger discharges cell #1 when not powered up? If so, it will be pretty hard to fix in firmware .
Fred
Yes but i was my fault.
Never keep batteries connected for longer time when the charger is not connected to power.
Yesterday I charged cell 1 alone and discharged then the whole pack with about 7A and got 1900mAh out from this 2100mAh pack.
Looks good but later I will try it in my Acromaster with draws up to 40A and I will see if this pack still has performance or not.
tuxian is offline Find More Posts by tuxian
Old Aug 08, 2008, 04:13 AM
kyalamikid is offline
Find More Posts by kyalamikid
kyalamikid's Avatar
Kyalami, South Africa
Joined Jun 2006
Junsi, any ETA on the Ver 3.07 firmware please?
kyalamikid is offline Find More Posts by kyalamikid
Old Aug 08, 2008, 09:27 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Hello kyalamikid,
Thank you for your frequent focus on our chargers.
Sorry to say that the being-about-to released chargers are still under modification as we have to collect opinions and more feedback from our testers. So please wait it patiently and give us more time to better them.
Thanks again for your full understanding.
Regards,
Junsi
junsi is offline Find More Posts by junsi
Old Aug 09, 2008, 03:56 AM
guggelmux is offline
Find More Posts by guggelmux
Joined Aug 2008
Hello world ....
Do not know if your charger will welcome me like that.
Just want to say you found another one who has trust in what your crew is doing.
Thanks guys, looking forward to get it.
guggelmux is offline Find More Posts by guggelmux
Old Aug 10, 2008, 03:27 PM
whisperdancer is offline
Find More Posts by whisperdancer
Portugal, Porto District, Maia Municipality
Joined Aug 2008
Are these chargers (1010b and 106b) accurate?
I once had an ICharger IC6 and it ALWAYS overcharged my cells (ex: 4.17, 4.00, 4.23 volts on termination, although it always showed 4.20v for the 3 cells on the charger).
I had to sell it, as I was only buying FlightPower Lipos and didn't want them to go bad.
How about these new chargers? I will only charge lipos, and accuracy of the balancer is a major priority...
Thank you.
whisperdancer is offline Find More Posts by whisperdancer
Old Aug 10, 2008, 03:51 PM
MadMax389 is offline
Find More Posts by MadMax389
MadMax389's Avatar
Central Florida. USA
Joined Mar 2008
Can a few hundredth's of a volt really make that much difference? If most of the electronic components used in either chargers or voltmeters are say .1% accurate over the measurement range wouldn't you get a cumulative error potential in the same range as what you're measuring?
Just curious...
MadMax
MadMax389 is offline Find More Posts by MadMax389
Old Aug 10, 2008, 04:17 PM
thomanie is offline
Find More Posts by thomanie
thomanie's Avatar
Trondheim, Norway
Joined Jun 2003
@whisperdancer:
Your questions have already been answered. Please go read the thread once more.
The accuracy question was one of the early ones answered. You will find the answers around post #112.
And if you go back and read post #199 again, you'll see that the IC6 has nothing to do with the 106B and 1010B.
FWIW, my 1010B has worked very well for me, and IMHO Junsis continued support to the user community has been nothing but impressive.
T
thomanie is offline Find More Posts by thomanie
Old Aug 10, 2008, 05:50 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Notes about performance/accuracy: http://www.rcgroups.com/forums/showp...&postcount=126
In my testing of 4 units over the past few months they have all delivered according to the claimed specifications. The only significant variation is the reported input voltage which shows the voltage sensed after the input FET and hence is lower than what you measure at the output of the power supply. This offset varies with load due to the resistive drop across the FET. However it should be noted that it is in no way a problem and the really critical voltage measurements, those of the cells, are all within the specified tolerance.
As mentioned earlier the "ICharger IC6" is an unrelated product and its performance says nothing about the iC106B/1010B.
MadMax - Your point is very valid and often overlooked. However LiPo cells are quite sensitive to overvoltage so a "few hundredths of a volt" can indeed make a difference to long term performance and to safety. The difference between 4.17 and 4.20 can be 20 to 50% lifetime reduction. The difference between 4.29 and 4.3? can be a fire. I think genuine 10mV precision and accuracy is an appropriate specification for a safe and good quality LiXx charger. Many claim it, not all deliver it. Based on my measurements I believe that the iC106B and 1010B do.
kgfly is offline Find More Posts by kgfly
Old Aug 10, 2008, 06:47 PM
Joined Aug 2008
Originally Posted by thomanie
@whisperdancer:
T
Thank you very much.
I just entered this topic, and there are quite some pages.
This line of chargers look promissing.
Old Aug 10, 2008, 11:15 PM
madhun1 is offline
Find More Posts by madhun1
QPower 18650
madhun1's Avatar
Sunshine Coast
Joined Jun 2006
@whisperdancer:
T
Did you happen to notice there is nearly 1600 posts in this thread?
It would have taken just as much energy, and consumed just as much bandwidth to answer the question.
madhun1 is offline Find More Posts by madhun1
Old Aug 11, 2008, 01:43 AM
tantive is offline
Find More Posts by tantive
Joined Mar 2008
Hello Junsi,
just another feature request.
I bought a sealed lead-acid battery (gel cell) to be able to charge my lipos/lifepos at the field.
At home I now have to charge the lead-acid. Using the PB mode of the charger I noted that the charge end voltage is too high and the battery starts to produce gas.
So the question is:
Is it possible to make the charge end voltage per cell adjustable in PB mode (as it is for lipo lifepo...)?
Kind regards
Michael
tantive is offline Find More Posts by tantive
Old Aug 11, 2008, 01:54 AM
tuxian is offline
tuxian's Avatar
Austria
Joined Jul 2008
Hello,
i had the same problem:
http://www.rcgroups.com/forums/showp...postcount=1498
Junsi wrote that this feature should come with the new firmware:
http://www.rcgroups.com/forums/showp...postcount=1519
Old Aug 11, 2008, 02:41 AM
sayad is offline
Find More Posts by sayad
Joined Feb 2008
icharger 1010B higher than set charge current - that aint that beter stuff to use .
1010B charge current set to 0.5A in balance charge mode, charge current jupms up to 2.7A
It is just better at its High capability, stable current, high-performance circuit power conversion
sayad is offline Find More Posts by sayad
Old Aug 11, 2008, 03:09 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Anyway, I would like to know if it's discharging cell1 and in what situations (charger powered off, powered on, ...). Sounds like the current was relatively high also. Could easily damage a pack if left on the charger after a discharge.
Packs discharged that deep may become fat after a short while, but I hope yours survive.
Fred
flarssen is offline Find More Posts by flarssen
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
