Go Back   RC Groups > Aircraft - Electric - General > Batteries and Chargers
Old Mar 26, 2008, 12:43 PM   #1
iCharger
junsi's Avatar
Send a message via MSN to junsi
10S 10A 300W charger/discharger ( iCharger 1010B+) --206B, 208B release!
I’d like to recommend you a newly produced Charger iCharger 206B,206B is a Synchronous Balance charger/discharger with a wide input voltage range for NIMH/NICD, Lilo/LiPo/LiFe (built-in Lithium battery balancing function) and Lead Acid (Pb) battery packs.
Synchronous buck-boost DC/DC converter technology---an advanced charging technology, we are the first manufacturer to use the technology to design balance charger--- assure up to 93% power transfer efficiency. Not only save the power but also make the charger size very smart, easy to use and convenient to take.
The following lists are their main specifications:
Code:
                                208B               1010B+               106B+
Input voltage range         4.5 – 32.0VDC     10.0 – 18.0VDC     10.0 – 18.0VDC
Charge current range        0.05 – 20.0A       0.05 – 10.0A       0.05 – 10.0A
Discharge current range     0.05 – 20.0A       0.05 – 7.0A        0.05 – 7.0A
Maximum charge              350W@input         300W@input            250W@input
power capacity               voltage            voltage               voltage
                             >18V              >13.5V                >13.5V
Maximum discharge             30W               30W                   20W
power capacity
Maximum extern
discharge power             600W@30V/20A       280W@40V/7A        170W@25V/7A
capacity
Current drain                  <350mA            <300mA              <300mA
for balancing
Balance accuracy               <10mV              <10mV              <10mV
Lithium(LiPo/LiIo/LiFe)
battery cell count              1—8              1—10               1—6
(series)
NiCd/NiMH battery               1—25             1—25               1—17
cell count (series)
Pb battery
cell count                     1—18               1—18              1—12
(series)                      (2—36v)           (2—36v)            (2—24v)
Log Files storage        16Mbit (36 hours)              do not support
Battery setup
Memories  (sets)                                    10
Intelligent
temperature control                                 Yes
PC Connect                                        USB port
Dimensions                   143*97*26           143*97*26            134*83*25
(L*W*D)(mm)
You can find detail information and their related products in the website http://www.jun-si.com/Enproducts.asp and download 1010B &106B's user's manual in the website http://www.hillrc.com/UploadFiles/iCharger-english.pdf
106B+'s manual http://www.hillrc.com/UploadFiles/iC106B+_en.pdf and CD-ROM here: www.hillrc.com/UploadFiles/106B+_CD-ROM.rar
1010B+'s manual http://www.hillrc.com/UploadFiles/iC1010B+_en.pdf and CD-ROM : www.hillrc.com/UploadFiles/1010B+_CD-ROM.rar
208B's manual http://www.hillrc.com/UploadFiles/iC208B_en.pdf and CD-ROM: www.hillrc.com/UploadFiles/208B_CD-ROM.rar
206B's manual http://www.hillrc.com/UploadFiles/iC206B_en.pdf
You can download 1010B &106B's upgrading software in the following website:
iCharger upgrader: http://www.hillrc.com/UploadFiles/upgrader.rar
iCharger 1010B's upgrading software:
http://www.hillrc.com/UploadFiles/iC1010B_V311c.bin.
iCharger 1010B+'s upgrading software:
http://www.hillrc.com/UploadFiles/iC1010B+_V311c.bin.
iCharger 106B's upgrading software:
http://www.hillrc.com/UploadFiles/iC106B_V311c.bin
iCharger 106B+'s upgrading software:
http://www.hillrc.com/UploadFiles/iC106B+_V311c.bin
iCharger 208B's upgrading software:
http://www.hillrc.com/UploadFiles/iC208B_V311c.bin
and update notes:
http://www.hillrc.com/UploadFiles/Re...s-iCharger.txt
and download its upgrading instruction in the attachment of the PDF.file of update information.
The iCharger 1010B+ & 106B+ support the "Open Format" data of the "logview" software and can display, plot and analyze the charge and discharge data by it. (See detail information about logview in the following website: http://www.logview.info)
iCharger User Calibration steps is attached, pls check it when it is useful for you.
Connection Sequence
According to our engineer, the main charging port and the balance port has reversed polarity protection respectively.
If the balancing connector has correct polarity, and then connect the main charging port, there is no problem; but if balancing connector has reversed polarity, and then connect the main charging port, it will burn.
Recommended connecting way:
1. Connect iCharger's input power supply, and turn on it.
2. Connect Li batteries' balance port
3. Connect the main charging port's positive pole to cells' positive pole, and then connect negative pole to cells' negative pole (this will avoid striking fire while connecting Li cells).
4. Start charging and discharging...
5. After finishing charging and discharging, pls disconnect the cell and charger, and then turn off the charger's power supply.
Gratitude to Julez and Kgfly for their hard working on upgrading instruction.
Upgrading steps posted by Julez!http://www.rcgroups.com/forums/showp...postcount=1187
See upgrading instruction(iC106B_1010B_Upgrade_Guide[1].v1_4.pdf) by Kgfly!
iCharger Expanded Discharge tool--Spreadsheet posted by Trug, see the Attachment below.
And here is Trug's blog: http://www.rcgroups.com/forums/showthread.php?t=737144
Another table posted by Kgfly to help with designing simple resistor arrays for (nearly) optimal discharge rates, you can play with the resistor power rating to find the best fit. See details in Attachment.
if you have any questions,please contact with szjunsi@163.com directly.
  • Name: 106B+.jpg
Description: 106B+ External structure 106B+ External structure 63.8 KB · Views: 2270
  • Name: 1010B+ connection.jpg
Description: 1010B+ External structure 1010B+ External structure 69.0 KB · Views: 1975
  • Name: 208.jpg
Description: 208B External structure 208B External structure 16.5 KB · Views: 945
  • Name: iCharger 206B.jpg
  • Junsi:iCharger Logo--hill Junsi:iCharger Logo--hill
junsi is offline Find More Posts by junsi   Reply With Quote
Old Mar 26, 2008, 02:02 PM   #2
Permanently Banned
How Much ?
hall woo is offline Find More Posts by hall woo   Reply With Quote
Old Mar 26, 2008, 03:55 PM   #3
Location: Greensboro/H.Pt/Win-Salem P.T. Intl, North Carolina, United States
Looks like it limits LIPO up to 1C although it certainly appears to have the power to charge many packs at a much higher rate.
NCguy is offline Find More Posts by NCguy   Reply With Quote
Old Mar 26, 2008, 04:52 PM   #4
if its 200W max does it really charge 10S at 10amp?
theShark is offline Find More Posts by theShark   Reply With Quote
Old Mar 26, 2008, 09:49 PM   #5
Hill icharger
Send a message via MSN to harrief111
Charger 1010B can charger maximum 10 series LIPO at a time,1C limit is just for LIPO battery, according to LIPO battery’s manufacturer standard, usually LIPO’s current are limited within 1C. Questions are welcome!
harrief111 is offline Find More Posts by harrief111   Reply With Quote
Old Mar 26, 2008, 10:05 PM   #6
Hill icharger
The charge current is different with the charge voltage, for example, if you want to charge 10s LIPO batteries, LIPO’s maximum charge voltage is 4.2V/cell, in this condition, the charge current should be figured in this way, (amp=200W/(10*4.2V)) and its charge current is about 4.2amp, is it clear? Questions welcome!
Old Mar 26, 2008, 10:06 PM   #7
Hill icharger
The charge current is different with the charge voltage, for example, if you want to charge 10s LIPO batteries, LIPO’s maximum charge voltage is 4.2V/cell, in this condition, the charge current should be figured in this way, (amp=200W/(10*4.2V)) AND ITS CHARGE CURRENT IS ABOUT 4.2amp, is it clear? Questions welcome!
Old Mar 27, 2008, 05:04 AM   #8
iCharger
junsi's Avatar
Originally Posted by hall woo
How Much ?
hello hall woo,
First ,thank you for your interest in our products, now I want to give your the market price list in the attachments,the price is closely changeable with your order quantity, if you want to be our agent, we can give you special price, you can contact directly with szjunsi@163.com for detail information! We hope to discuss business with you at your earliest convenience.
Best wishes!
Junsi
For the quatation,please contact with us directly.
Old Mar 27, 2008, 05:52 AM   #9
Renewed interest
ozace's Avatar
Looks and sounds like. I do like the white though.
http://www.chargery.com/index.asp.
Care to comment ?
ozace is offline Find More Posts by ozace   Reply With Quote
Old Mar 27, 2008, 11:51 AM   #10
Where's my beer, and my pants!
mt_100's Avatar
I actually like the specs on the iCharger106B shown in that document. Where and when can those be purchased?
mt_100 is offline Find More Posts by mt_100   Reply With Quote
Old Mar 27, 2008, 11:52 PM   #11
iCharger
junsi's Avatar
Care to comment ?
Thanks for your closely attention to our product iCharger 1010B,the website you give is one of our partners,we also expect more co-operation partners to join us,Thank you!
See detail information in the website:http://www.jun-si.com or http://www.hillrc.com
Old Mar 27, 2008, 11:59 PM   #12
iCharger
junsi's Avatar
Thanks for your attention!
  • Name: 106.JPG
Old Mar 28, 2008, 12:59 AM   #13
...removed incorrect statement..
The pricing is pretty sharp if it is for single units (rather than a carton full) and the chargers can live up to their specifications. Of course there is shipping to consider. The 1010B is a head-to-head competitor on features and performance to the TP1010C+210V but integrated, smaller, lighter and about $100 cheaper.
My compliments on the graphic design, more eye-catching than the plain blue of the original Chargery units.
Last edited by kgfly; Apr 01, 2008 at 10:22 AM. Reason: Remove erroneous statement
kgfly is offline Find More Posts by kgfly   Reply With Quote
Old Mar 28, 2008, 03:00 AM   #14
iCharger
junsi's Avatar
Originally Posted by kgfly
Chargery is the OEM supplier (aka partner) to Jun-Si.
Here we don’t want to talk any Commercial Confidential Information with you ,but we can ensure you that we have the right to design, modify, and produce the original 1010B and 106B.
Thanks for your comments.
Old Mar 28, 2008, 03:18 AM   #15
What accessories come with the charger for $180 ? Input leads, output leads, balance port adapters, temperature probe, PC interface and software etc ?
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 01:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 04:29 AM
WTB Good charger/discharger 10 + cells khen Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 09:55 PM
Best charger/discharger $ can buy namancio Batteries and Chargers 22 Aug 09, 2002 12:52 PM
Bored? Want to fight?
Join the RCGroups clan!
