Old Mar 26, 2008, 02:49 AM
haikuomega is offline
Find More Posts by haikuomega
Joined Feb 2008
2.4G Lama V4
Hi everybody, listen I was checking out all your great info and I came across a new release. It's the 2.4G Lama V4. So I did a Google search and finally found a price on it. ($115.00 to $160.00) quite a difference ah... Check out the link below...
Anyway I know it's new but does anyone have any info on it? And how does it and the old Lama compare to the BCX2? Thanks in advance for all your input...
http://www.superfastrc.com/esky-24ghz-lama-v4-.html
haikuomega is offline Find More Posts by haikuomega
Old Mar 26, 2008, 04:22 AM
DWJL511 is offline
Find More Posts by DWJL511
DWJL511's Avatar
Joined Jul 2007
Can someone pls explain to me in layman terms what the benefits of 2.4G are? Is it really necessary (cost wise also) for a co-ax? tks.
DWJL511 is offline Find More Posts by DWJL511
Old Mar 26, 2008, 05:52 AM
puma1824 is offline
Find More Posts by puma1824
puma1824's Avatar
A 2.4GHz system will allow you to fly without the worry of being on the same channel as another flyer. You DO NOT need crystals. With a traditional system if more than one R/C pilot/driver wanted to fly/drive at the same time they had to be on separate channels REQUIRING a different set of crystals (additional cost) or for non-crystal systems would REQUIRE manual change on the TX/RX onto a different channel (not automatic).
Another benefit of 2.4GHz systems is typically eliminates glitching.
puma1824 is offline Find More Posts by puma1824
Old Mar 26, 2008, 09:28 PM
DWJL511 is offline
DWJL511's Avatar
Joined Jul 2007
Ok I see thanks.
I normally fly alone, so I guess I don't really need a 2.4GHz, although it would be nice to have if not for the extra $$$.
Old Mar 26, 2008, 09:46 PM
puma1824 is offline
puma1824's Avatar
Ok I see thanks.
oh yeah another 2.4GHz benefit(s) shorter antenna, typically less batteries in TX.
Old Mar 26, 2008, 10:25 PM
Shoalwater is offline
Find More Posts by Shoalwater
i don't think there is any advantage to the 2.4 for an indoor coax.........i would say 99.9% of the time they are flown indoors alone and inside you can keep your antenna as short as a 2.4 antenna and it is aok, hype in my opinion for this size / type of bird..............
soft landings
Shoalwater is offline Find More Posts by Shoalwater
Old Mar 27, 2008, 12:01 AM
rawfuls is offline
Find More Posts by rawfuls
Heli and Car Addict
rawfuls's Avatar
Woodland Hills, CA
Is it possible to fly more than one 2.4ghz heli/car/etc in one spot and not have any glitches? I have a crapload of 2.4ghz computer electronics since I am well, a computer nerd. And my phones used to use 2.4, and there were quite a bit of glitches (still are).
rawfuls is offline Find More Posts by rawfuls
Old Mar 27, 2008, 08:53 AM
allena99 is offline
Find More Posts by allena99
Wisconsin
Joined Jul 2005
The Futaba and Spektrum 2.4ghz systems use a communications process that "binds" the receiver to a specific transmitter. Once bound, the receiver will not respond to any other transmitter or signal source. The 2.4ghz band restricts all devices to low power, and because of the relatively high frequency employed, static discharges and other interference is not a problem. I don't know anything about the 2.4ghz system that Esky is using in the new 2.4ghz heli's. I use the Spektrum system in all of my Honey Bee and Blade CX2 heli's and RC planes, and like it a lot. I like being free of the antenna wires too. Is it necessary? Not where I live. I just ordered a Lama v4 on 72mhz. I didn't want to spend the extra $25-$60 just to get it on 2.4. If I like it, I might stick a Spektrum receiver in it later.
allena99 is offline Find More Posts by allena99
Old Mar 27, 2008, 10:49 AM
Bing44 is offline
Find More Posts by Bing44
Bing44's Avatar
United States, OR, Independence
Joined Feb 2008
snip some neat info
Here is a good example: my cousin bought a Blade 400 2.4gHz and I bought a HB King II 72 mHz. We both crashed on our first flight.
lol
jim
Bing44 is offline Find More Posts by Bing44
Old Mar 29, 2008, 04:17 PM
Greg336 is offline
Find More Posts by Greg336
Joined Dec 2004
Better pricing maybe.
Hi, I just kind of jumped in here and didn't read all of the threads but there might be another web site with a better price for you. I'm not sure on there shipping costs but take a look at www.xheli.com. Right now the Lama V4 is selling for $88.00. Hope this might help a little.
Greg336
Greg336 is offline Find More Posts by Greg336
Discussion E-Sky 2.4G Lama V3, is it true? bluesdaddy2 Coaxial Helicopters 12 Apr 14, 2008 01:41 PM
Discussion lower rotor head lama v4 and cx 2 rapala Coaxial Helicopters 1 Feb 19, 2008 05:30 PM
Discussion 2.4ghz LAMA V4 IN STOCK!!! quadracer111 Coaxial Helicopters 21 Feb 07, 2008 02:49 PM
Discussion 2.4g Lama V4 userrc Coaxial Helicopters 0 Jan 22, 2008 11:07 AM
Discussion Esky lama V4 mode 1 to mode 2? mbt1760 Coaxial Helicopters 3 Nov 14, 2007 08:29 PM
