Old Mar 25, 2008, 09:53 PM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
A little help pleas EDP300 motor system???
Hello all
I have two of three things I need. I have the motor and prop, and motor mount for this combination
http://www.gws.com.tw/english/produc...tem/edp300.htm
What is the correct GWS part number for the propeller to motor shaft adaptor and or spinner
Tom
Majortomski is offline Find More Posts by Majortomski
Old Mar 25, 2008, 10:29 PM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Tom,
You need the rubber spinner, "GW/SPN001" to fit both propeller and the 2mm motor shaft. It comes with 6 spinners in 3 different hub hole sizes, they are 1.5mm/0.059", 2.0mm/0.079" and 2.3mm/0.091".
There's a shaft adapter, GW/DS001 in line, but its shaft might still be thinner than the hub hole of the propeller you have, the EP4540 or EP4530 or EP5030.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Mar 26, 2008, 08:01 AM
Joined Aug 2000
Thank you! Off to my LHS!
Help! a little help with a motor plate. geneween Electric Heli Talk 7 Feb 09, 2007 11:28 PM
Need Help on Electric Motor System joe1 Power Systems 10 Dec 27, 2004 10:20 PM
Need Help Selecting Motor System joe1 Electric Sailplanes 1 Dec 23, 2004 08:26 AM
Partenavia Motor System Help!!!! LNL Power Systems 4 Jul 29, 2004 12:31 AM
problem with motor system...help! sdcfish Power Systems 7 Feb 02, 2003 01:14 PM
