This thread is privately moderated by Minibichus, who may elect to delete unwanted replies.
Old Mar 25, 2008, 02:08 PM
Minibichus is offline
Find More Posts by Minibichus
MB-Commander
Minibichus's Avatar
Joined Feb 2008
The M.B. - 1
UPDATE: *DECOMISSIONED*
The final setup is as follows:
The MB-1
-Losi 8750 kV brushless main motor.
-Micro 3.5 grams outrunner brushless tail motor.
-2x Feigao 6A ESC
-Main ESC => brake OFF, soft cutoff, softest start, low timing.
-Tail ESC => brake OFF, soft cutoff, normal start, highest timing.
-Spektrum AR6300 Rx without the plastic wrap.
-ESky Heading Hold Gyro.
-HH mode: Set at 65% gain in the DX7 pitch channel as STUNT 1 & 2
-Rate mode: Set at -49% gain in the DX7 pitch channel as NORMAL
-Fully CF reinforced 4#3 frame with strenghtened swash guides.
-130mm x 3mm Aluminum tail boom.
-Custom fabricated tail motor holder.
-3 blade, 50mm EDF Fenestron/Fantail propeller.
-CF reinforced and metal ball links blade holder.
-Flybar made with 1mm piano wire.
-Custom fabricated landing gear (0.65 mm piano wire) welded front support.
-Small.Planes. Aluminum rotor head, fully balanced and aligned.
-7T parma slot racing car pinion 64 Pitch. (this could change...)
-Custom fabricated battery tray and straps.
-Upgraded swash plate bearing for increased rigidity.
-Full Spainman's spring mod for the rotor head.
I think this is the entire setup as far as I know. I'll post some pics of it tonight.
Cheers.
MB.
Minibichus is offline Find More Posts by Minibichus
Discussion My final setup Luisfc1972 Beginner Training Area (Aircraft-Electric) 8 Feb 22, 2006 01:56 PM
Micro-Flash final setup. Xanderdude High Performance 14 Jul 17, 2005 11:55 PM
Final Setup on My Sirius jayman Electric Sailplanes 2 Jun 06, 2001 04:17 PM
