Jan 08, 2003, 12:49 PM
Redmond, WA
Joined Nov 2002
Changing Pinions Doesn't seem to Change Headspeed...
What does this mean? I have one heli under construction and I'm trying to get it into aerobatic specs. Details: VoyE, hacker B40-8L, schulze 12.46e (soft timing, lower speed DIP settings), 3000mAh 10 cell, CF blades +PEK.
I'm testing at 0 pitch, pinions 15 through 19 teeth, and a glowbee tach (I have a dental mirror attached to it so i can measure headspeed while it's laying on the ground). Throttle to max (I can tell it's max because I always start with throttle slider max, and the ESC powers up with a beep-beep indicating max throttle setting). I tried to make sure that the tach wasn't also hitting the flybar in addition to the blades.
The problem: at a 15 tooth pinion, I get a headspeed of about 1600. When I switch to a 19 tooth, I get a headspeed of about 1650. What does this mean?!?
The only way I've been able to get a significantly higher headspeed is when I switch the schulze to "higher speed" DIP settings. With a 15 tooth pinion, at 40% of the throttle setting, the headspeed overspeeds, greater than 2400RPM (it shook the fins off the tail!).
I looked at the ESC specs and it's quite similar to the old schulze 45ho, and right now, the only things I haven't tried are the ESC hard timing (not sure what that will do) or get a smaller pinion for the esc high speed setting (something I've never heard from other VE owners).
Thanks in advance.
