Espritmodel.com Heli Air
Old Mar 25, 2008, 12:21 PM
SirToU's Avatar
Hampshire, England
Honeybee FP - Brushless Conversion
Hi All.
Would this motor be too much power for the Honeybee FP.
Mystery RC 5000 Outrunner Brushless Motor and 30A ESC
I was either going to open the RX and do the mod - or buy the HDX convertor. - which is best?
Neil
SirToU is offline Find More Posts by SirToU
Old Mar 25, 2008, 12:48 PM
Better off Modified!
Tweekster's Avatar
Colorado
Joined Sep 2006
Originally Posted by SirToU
Hi All.
Neil
That's a pretty heavy setup for a FP.
Are you using the stock TX?
If so, I would recommend the ARC 80 from LightFlightRC, Phoenix 10 ESC w/ 10T RS4 steel pinion. More power than stock, lighter and longer run time. I've used this setup on several FP's with good results.
FWIW, do the RX mod, the converter is unneeded complexity.
Tweekster is offline Find More Posts by Tweekster
Old Mar 25, 2008, 02:30 PM
SirToU's Avatar
Hampshire, England
Thanks - Ordered an equivilant Brushless Motor and ESC, and will mod the 4 in 1.
Do you know anywhere, where there are pictures to Mod the 4 in 1 - or is it a simple case of matching colours - "paint by numbers style".
Thanks.
Neil
Old Mar 25, 2008, 02:48 PM
John 3:16 Still Applies
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Would that be this motor?:
ARC-20-27-80
• ARC 80 watt brushless motor
• Kv: 4500, io: 0.57A (8V), Rm: 100 (mOhms)
• Weight: 29g
• 2mm Shaft
• Dimensions: 20mm x 27mm (w/o shaft)
Also, why the Phoenix esc instead of the Suppo 10A ESC that they sell along with the motor? Just trying to sort out all the zillions of brushless/esc/pinion combos and get it right the first time.
Sammy70 is offline Find More Posts by Sammy70
Old Mar 25, 2008, 06:06 PM
Vario3's Avatar
Southeast PA
Joined Oct 2005
Instead of playing "Catch-up" to a stock HBFP,,,,, Why don't you look into spending your money on the CompyFP and get the most bang for your buck?
Vario3 is offline Find More Posts by Vario3
Old Mar 25, 2008, 06:46 PM
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Yah true dat. You will stop wearing out main motors with this setup but you will continue to burn up tail motors which after time will become a huge drag.
maarset is offline Find More Posts by maarset
Old Mar 25, 2008, 06:55 PM
stamper's Avatar
Bartlett, IL
Joined Jun 2002
Please keep us updated on how this brushless upgrade goes. I have had several FP helis and I am not sure the benefit of going brushless. The stock motor lasts a very long time as well as the tail motor on 2 cell lipos. Also with a fixed pitch heli, I am thinking that you can only have so much headspeed before making the heli unflyable, negating the brushless advantage. Hope it works.
stamper is offline Find More Posts by stamper
Old Mar 25, 2008, 07:47 PM
SirToU's Avatar
Hampshire, England
Thanks to all.
to answer a couple of the statements. Firstly, Esky parts are 10 a penny in the Uk and "everywhere" at the moment - Makes life easy to replace broken bits, as I have only been flying for 2.5 months (from scratch - no airplanes - nada) and I have kept the local hobby store in business.
I like tinkering, and want to build something - that I already have taken apart, but with upgrades before I start learning to fly the Belt CP I have.
But I looked at the compy and it looks pretty good, but I am desparate to get into flying CP and 3d. -Just because- + reliving my childhood by building a Airwolf replica.
The brushless upgrade I am doing is to try and counteract the additional Lexan Airwolf Body, but staying with FP at the moment.
When I do finally get to fly properly and build a good heli, I already have my eyes set on a 5 Bladed EP100 flybar less, with a scale Seaking Shell. with working winch set up.
I know I'm just a dreamer - but dreamers make the world go round!
thanks again - Neil
Old Mar 25, 2008, 07:52 PM
Vario3's Avatar
Southeast PA
Joined Oct 2005
thanks again - Neil
Congrats!! Big dreams = Big results!!! Good luck and keep us posted of the StockFP/brushless idea!
Old Mar 25, 2008, 07:53 PM
Vario3's Avatar
Southeast PA
Joined Oct 2005
Weight will do you in at this time.
Old Mar 25, 2008, 09:33 PM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
Whaaww...!
I'm looking at one of those too, but a little larger to fit a Compy. I'll be going for the MD500 look. Scale-ish is just way too cool!
Have fun!
murdnunoc is offline Find More Posts by murdnunoc
Old Mar 25, 2008, 09:36 PM
Kamov's Avatar
CA
Joined May 2007
i also have been thinking of the BL route...i don't want to keep replacing brush motors every month and a half...i've worn out 2 so far and about to wear my third i get 30~40 hrs of flying time per month...
and im only using 2s lipos...though i have a couple of 3s 800mah if i use that i'll wear the stockers even faster like 1 motor a month!! at about $10 per replacement thats $120 a year..ouch!!
BL almost last a lifetime if you don't overheat them or wear the bearings out w/c is unlikely on this heli...
money and performance wise i thinks an ARC 80 watt would be better for me i'll try Tweekster advice and see how that goes
Kamov is offline Find More Posts by Kamov
Old Mar 25, 2008, 09:38 PM
Canada
Joined Nov 2000
With the BL main you will need either a Direct drive Tail motor OR a dual setup yr choice. Also using a pair of M24 blades will add significant stability to flying.
After having "been there an made all the mistakes"
I suggest one learns to fly the thing ..Before ...Modding, as it is a Detour with little profit Untill flying skills warrant the upgrades. But as yr seemingly committed to it at least do the ones that will keep it flyable ..and a BL main with the Stock tail drive imo will Not.
Bare is offline Find More Posts by Bare
Old Mar 26, 2008, 04:17 AM
SirToU's Avatar
Hampshire, England
Fair comments, looks like a dual tail then.... :-)
Neil
Old Mar 26, 2008, 09:16 AM
Sammy70's Avatar
Central Ohio
Joined Feb 2008
I was wondering if you could elaborate on the usage of the Phoenix ESC versus the much cheaper Suppo unit they sell? Also, where would one find the "Rx mod" instructions? I'm not looking for more power as the stock setup flies just fine for my usage. I'm all for longer laster motors and longer run time if at all possible...
Question Honeybee FP mode 2 to one conversion Hoot Micro Helis 3 Feb 09, 2008 12:02 AM
Question YIKES! * Brushless motor questions for Honeybee FP Slyster Micro Helis 17 Dec 27, 2007 09:39 PM
Discussion Twister / HoneyBee Fp to CP conversion SMaric Micro Helis 0 May 06, 2007 02:47 PM
Discussion Honeybee FP & brushless Fearless Flight Micro Helis 10 Jan 25, 2007 10:28 PM
Discussion Brushless Honeybee FP: What Pinion Xptical Micro Helis 6 Jan 17, 2007 02:22 PM
